Question about Norcent Technologies LT-2722 27 in. LCD Television
No power---unable to turn on tv
TV just suddenly lost power and it wqon't turn back on. We left town for a week, unplugged tv. Upon return, we plugged it back in, but still no power. The dvd and surround sound receive power, but not the tv. Is there a way to boot it back up? Is there a fuse we need to change? Que pasa?
  • mking28 Sep 13, 2008
    I have sound but no picture. If the picture happens to come on, then it will pop off after a few seconds.
  • Anonymous Nov 30, 2008
    I have the same problem. TV was fine this afternoon and tonight went to turn it on and there is no power. I tried changing power strips and wall outlets and still nothing. Internal Fuse????
  • 734 Answers
There is no reset button on these new sets,your set has complete power problem since you have no lights no clicks,this might have happen because of lightning or power surge,either one creates a lot of damage,if you are familiar with tv service you can check the main fuse,he should be close to where the power cord comes in,if you find the fuse blown it needs to be replaced with an exact replacement for AMPS rating and VOLTS rating as well as size,if the fuse is blown black we might have more problems ahead in the circuit and it will blow up again as sonn as you plug the tv back in,if it blows again it will need a more involved repair,the problem could be in the primary side of the power supply,if you are not too familiar you should seek the help of a servicer a least for an estimate but if you suspect power surge or lighting damage dont invest any more on this set and get a new one.
Posted on Dec 02, 2008
How to fix problem with TV that has no sound or picture?
Take it to a Samsung repair centre. It boards that need replacing, and there are many. You have to swap out the right ones.
Mar 28, 2017 | Televison & Video
No picture on Vizio 60" E601i-A3
yes take it back 6 weeks i would return it
Dec 30, 2012 | Vizio 60" E601I-A3 Full HD LED-LCD TV
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
TV images have gone green
power might be to low for it
Apr 16, 2010 | Toshiba 32HFX71 32" TV
My Sony 52" LCD kdlw3000 tv, which is almost 2 years old, went to standby mode after our power had been off for two days due to a storm. TV worked fine before we lost power and it's plugged into a surge...
Just as our modern sets can remember user settings when the AC goes off, they well may record error conditions for an extended length of time too just as our cars do. Flash memory (used in such applications and only type used in digital cameras for example) can keep information for a very long time. Even if not used in your set, there is surely backup provisions that can keep info handy for days and possibly weeks by using components that mimic batteries to retain even standard memory for weeks.
Most PCs have provisions for discharging this kind of circuit which then resets possible stored error conditions and returns stored values to factory conditions.
Feel lucky this time I'd say.
Nov 02, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
53SBX10B; red light and screen won't come on most attempts/Snd:OK
my names bill fox and i have the same tv . i know a mark miller from rushville in. is this you. if so reach me a 2-1278 and we will discuss replacing your power supply from my tv that has a bad convergance boardbut the power supply works fine. i can fix this for half the estimated price youve already recieved.
Jul 10, 2009 | Hitachi 53SBX01B 53" Rear Projection...
Brand new LG plasma stuck on test screens
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | Televison & Video
Tv turned off for 1 week. When switching back on, can only get an intermittent red flashiinglight. So am unable to get any programmes.
Leave TV power cord unplugged for one hour, also unplug DVD, cable, sat etc.
If TV does not restart after plugging everything back , then you need a technician.
You can call the number listed on your owner manual.
Sep 06, 2008 | Televison & Video
No picture
this problem is caused by the interruption of the fuse .if you can replace it, you might solve the problem.(before removing the cover of the tv-set make sure you unplugged it.replace the fuse with an identical one,then plug-in the tv-set and turn it on).i hope that it will work.if no change contact the nearest repair shop.
Jul 19, 2008 | Sanyo DS27510 27" TV
TV won't turn on
When I try to turn the tv on, the green light flashes and eventually goes back to red. A very faint picture came across the tv a few times but didn't stay. The tv is only 3.5 years old.
Jul 10, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Norcent Technologies LT-2722 27 in. LCD Television Logo
287 people viewed this question
Top Norcent Technologies Televison & Video Experts
Computer Repairing
Computer Repairing
Jaime Hernandez
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
