Question about Hampton Bay 54 In. Flemish Pewter Ceiling Fan with Heater
Hampton Bay 54in. Covington with remote...
Anyone know how to get the fan to run the opposite direction??? this fan is really unfriendly if you do not have the owners manual, and you might as well forget ever getting a replacement ballast for the light system, its nearly impossible. Thanks for any help
I have this fan with the remote. The top right-hand switch on the remote says fwd/rev and that does, in fact, reverse the direction of the blades. The manual says to make sure the fan is still moving when you press this switch or it won't reverse direction.
Posted on Aug 22, 2008
Reverse
Do you want to sell your Covington Ceiling fans? I may be interested in purchasing them. If you live in Atlanta, I could remove the old ceiling fans and install your new ones if you need.
email me at:
myatlhomes@comcast.net
Aug 02, 2009 | Hampton Bay 54 In. Flemish Pewter Ceiling...
We have a hampton bay ceiling fan model 54cvt. We cant figure out how to change the light bulb or change the direction of the blades. We dont have a manual for the fan.
This fan is also known as the Hampton Bay Covington 54 Ceiling Fan. You need to turn the globe anti clockwise until it comes out. The full instruction manual can be found here.
http://lightingworldbay.com/hampton-bay-covington-ceiling-fan-54-cvt-manual/
If you have another fan model other than the Hampton Bay 54CVT then try here
http://lightingworldbay.com/hampton-bay-ceiling-fan-manuals/
Jun 28, 2009 | Hampton Bay 52 In.Carriage House II in...
How do I reverse the direction of the fan blades to counter-clockwise on the fan? The fan is a Hampton Bay ''Clarington'' with a remote control.
There is a small black switch on the switch housing directly under the blades. When the fan is completely off, move the switch to the opposite direction.
Mar 31, 2009 | Universal Remote Control Hampton Bay...
Hampton Bay Covington 54" Ceiling Fan Light Does Not Come On
Try taking the lighting kit completely off it make sure the blue wire and white wire are both firmly connected.
Does the remote work on the fan part ok? Do you have the black, white, and green wire on the house side connected to the side of the receiver with the same wires?
You know the black and blue are hot for the fan and lights (blue for lights). If the wiring connections are ok it had to be either in the remote or receiver. Are the dip switches set for the same on each?
Jan 19, 2009 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Fan running & stops then goes the opposite direction
Your Hampton Bay combo probably was installed incorrectly. A frequent cause of erratic operation is a conflict between the remote control and the wall switch.
Sep 09, 2017 | Hampton Bay 52 In. 5-Blade Fan, Aged...
HOW TO CHANGE DIRECTIONS OF BLADES ON HAMPTON BAY MODEL #70226
There is a switch on the side of the fan motor housing. Slide it the opposite way to reverse it. Make sure you wait until the fan comes to a complete stop to do so. Never reverse it while it is running, you could overload the motor and ruin it.
I believe they don't put the reversing switch on any remotes for that very reason.
Sep 15, 2008 | Universal Remote Control Hampton Bay...
Hampton Bay 54" Covington Ceiling Fan light problem
Solids state fan controls don't work correctly with fluorescent bulbs. If you check the tail end of you remote's instructions it will say something like "Max light watts: 300 (incandescent only). So replace your energy saver bulbs with 60 watt "regular" bulbs to solve your problem.
Aug 22, 2008 | Heating & Cooling
Hampton Bay 54in. Covington with remote control
Make sure the power wires from the ceiling mount are still in the electric box. Then have them come from the side near the screw mounting area. In otherwords, not through the center hole. In the center of the black metal part - there is where you put the reciever. It will fit literally resting on the black metal.
Aug 31, 2007 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Hampton Bay 54 In. Flemish Pewter Ceiling Fan with Heater Logo
321 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
