Large office air conditioner
In my office, the ac does not have any air coming out of the vents. I went up on the roof and found that the unit was on and the fan was spinning at full speed. Is there an internal fan that moves the air? The thermostat is functioning fine. I switched it out for an identical in another place in the building. Help we are cooking!
Mark
  • 828 Answers
Shut off the cooling and leave the fan in the on position. If the A/C cooling coil is frozen over it will stop air circulation. After you shut the cooling off look down through the fan on the roof top unit and look for any sign of ice on the big line going to the compressor. This would be a sign of the frozen A/C coil. After about an hour or so you should start to feel air movement.
To prevent the coil from freezing up operate the fan in the on position while the air conditioning system is in the A/C mode. Not automatic.
Posted on Jul 11, 2008
Can I recharge a Duo Therm 600315.001 RV Roof mounted air conditioner? It uses R22 refrigerant. If not, where can I find a replacement or can it be serviced somewhere?
I would suggest that you visit an ac specialist shop as all air conditioners( car, truck , house and yours all use the same principle of operation
because it is roof mounted in an RV may be a caravan repair shop that has an ac specialist in the workshop or a truck service shop that installs ac units in truck cabins would be a good place to start
Mar 13, 2016 | Dometic Heating & Cooling
My carrier ac roof top ducted unit started spitting out small amounts of water now and then, I changed filter. Now with ac in off position I am hearing a humming noise coming from the unit, what can this...
Don't really understand what you mean by roof top duct unit .if it's a roof top unit and water is leaking down your vent then you have a clogged drain line .
Mar 02, 2018 | Dometic Rooftop RV Air Conditioner
Cool air, but no fan, electrical smell inside house
most like it the motor windings are burn and you need to replace the blower motor
Sep 27, 2009 | Ruud UBHC Air Conditioner
The ac works great except the vents have no air coming out of them just the main vent
You will have to go into the Roof space and see if the Distribution flex pipe is detatched from the conduit.
Regards,DT
Aug 29, 2009 | Dometic Rooftop RV Air Conditioner
How do i remove a coleman air condidioner from pop-up
If you are removing the unit permanently, then remove the inner cover of the AC. You will 120VAC coming into the unit from either an extension cord or power cord. Remove the connectors for the 120VAC. Depending on the model, you will have a duct running from the upper unit to the lower unit, remove this duct. Unplug the 9 pin connector that connects the upper unit to the lower unit. Now, remove the four bolts the hold the upper to the roof (one in each corner). The ceiling pack should now be free. Push up on the a/c and it should be loose. Carefully remove it from the roof as it weighs nearly 100lbs. The fill the hole, you should be able to go to any local RV facility and pick up a standard roof vent. Install the roof vent in the hole and coat it with roof coating.
Hope this helps,
Jeff
Jul 11, 2009 | Coleman Heating & Cooling
Friedrich AC through the wall ac leaking water out front vent
pull it out and check for packaging left in ac unit, and make sure drain is clear and large enough for water flow ,,,go ahead and tilt ac unit more and see if that doesnt do the trick
Jul 04, 2009 | Friedrich CP12C10 Wall/Window Air...
Heating & Cooling Logo
111 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
