I have quicken 2006 and did an upgrade now I can't find quicken on my pc. My short cut doesn't work
Try Searching your computer for Quicken
Posted on Jul 11, 2008
Quicken unlock code
If you have it installed, the free Belarc Advisor may be able to show you the license key. Otherwise, you should have received a key when you purchased the software. If you have a Quicken account, see this... http://quicken.intuit.com/support/help/downloading--installing--upgrading-and-converting/how-do-i-download-quicken-from-quicken-com-after-i-buy-it-/GEN82217.html
Jul 27, 2014 | Intuit Quicken 2008 Deluxe Full Version...
Tip
Quicken will not print more than seven checks.
You may run into this problem if you use the 2005 or 2006 version of Quicken’s personal finance software (such as Quicken Basic, Deluxe, Premier, Premier Home & Business). If you try to print eight or more checks at once, they won’t print.
According to Quicken Help & Support, Intuit fixed this problem for both the 2005 and 2006 versions of Quicken. You’ll need to download and install the latest patch, which includes the fix for this problem. Quicken offers manual and One Step Update methods to update your version of Quicken with the latest patch. You’ll need an Internet connection to download the patch. If you have a dialup connection, connect to the Internet before you start any of the update methods below. Once you complete the patch installation, Quicken will be able to print eight or more checks.
To read Quicken’s solution for this problem, visit www.quicken.com, click Help & Support, and then select 2006 For Windows (make sure Quicken For Windows and Quicken 2006 appear in the Product fields). Next, type 2997 into the Search field and click Search.
Update Quicken 2005 manually
Visit Quicken Help & Support, select 2005 for Windows, and enter 3810 in the search field. Open the How Do I Manually Update Quicken 2005 For Windows To The Latest Release? link. This page has all of the patches for Quicken 2005. However, you only need to download the patch that has the highest R number. The latest patch carries all of the data from the earlier patches. In this case, you will want to download patch QW05R5PATCH.exe.
Click the file’s link. If you have Windows XP, a File Download – Security Warning may appear. Click the Save button. In the Save As window, choose a location to which you’d like to save the file and then click Save. When the download completes, simply double-click the file to start the patch installation.
(NOTE: This method involves downloading and installing a single patch file. If you don’t have an Internet connection but have a friend who does, you can download the file to his PC and then burn it to a CD [assuming your friend’s PC has a CD-RW]. Use the CD to transfer the file to your computer.)
Update Quicken 2006 manually
Visit Quicken Help & Support, select 2006 for Windows, and then enter 3796 in the search field. Open the How Do I Manually Update Quicken 2006 For Windows To The Latest Release? This page has all of the patches for Quicken 2006. However, you only need to download the patch that has the highest R number. The latest patch is QW06R3PATCH.exe and carries all of the data from the earlier patches.
Update Quicken 2005 Or 2006 With One Step Update
You can also update your version of Quicken using One Step Update. You can start the update by clicking Online Menu and then selecting One Step Update. Next, uncheck any checkboxes that appear and then click Update Now. The tool will download and install the latest update for you.
by: -micromaster
on Mar 19, 2008 | Intuit Quicken Basic 2004 (028287007543)...
I cannot get quicken 2002 basic to install on my new computer with windows vista.
That's because Quicken 2002 will NOT run on Vista. Quicken 2005 & 2006 will run on Vista, but will have issues and script errors. Intuit will only ensure Quicken 2007 and newer will work on Vista.
Aug 08, 2009 | Intuit Quicken 2002 Deluxe (78588)
Need to know which file launches my quickens program? I had to re-install my windows system and recovered my quickens files but can't launch the url for quickens to run the program.
If you reinstalled Quicken it should run from within the All Programs menu or any short cut that was created. Just click it and it should go - if it doesnt, Id say remove it using the add/remove utility inthe control panel and reinstall it again.
The trick will be to find and load your data file. You did make a separate back up on a stick or adifferent hard drive or CD or DVD, right?
Jul 08, 2009 | Intuit Quicken Deluxe 99 for Windows...
Using the same quicken file on two networked computers
After you install Quicken on both computers it is no problem. If you put the Quicken file (the data is on the file that ends in .qdf, on a flash drive (you should be able to get one for $15 or $20) , you can carry the file in your pocket on a key chain. Then any time you want to use the file just double click on the file and Quicken will open on either computer. Make sure yo password protect the file and also back it up to one of the computers frequently in case you loose the flash drive.
Mar 20, 2009 | Intuit Quicken® Premier 2006 Full Version...
Quicken 2009 premier Installation
a bit fuzzy here in your statements
you have win xp installed and the quicken program runs there perfectly
is that correct ?
now on another pc you have win vista and quicken is not running there
is that correct?
or do you have both win xp and vista operating systems on the one laptop and are trying to get quicken to work on both on the one laptop
maybe the problem is that quicken version you have works well win win xp as it is compatible with that OS but is not compatible with win vista in which case you need to go to the quicken properties tab , click on compatibility tab and tick the box and high light window vista and apply the change or get a download upgrade vesion from quicken web site
Jul 18, 2017 | Computers & Internet
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
