Question about Daewoo KOR-860A Microwave Oven
Time Run but microwave does not cook
My microwave is a Daewoo and it is in my 2000 wildwood camper. It has power and it works as far as the timer when you hit start but it doesn't cook. At first when I moved the microwave it would turn on as long as I held it in one spot but now it won't power up and do anything.
  • Daewoo Master
  • 9,098 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 12, 2008
How do I know wattage for 1974 recipes and convert cooking time to todays microwave (1200)
A 1974 Microwave Oven is probably not putting out more than 600 watts. You need to do a power test to determine it's actual power output. Place a 2 cup glass measuring cup with exactly 500 mL of cold water. Record the starting temperature of the water. Run the microwave on 100% power for 18 seconds, using a watch or timer, not the timer on the unit. Take the water out and stir it to make sure that there are no hot or cold spots in the measuring cup. Record the new temperature. Example: 78.4-64.1= 14.3.
Multiply 14.3 X 38.75= 554.125. The power output is 554 watts IEC. If the recipe is set for a 1200 watt unit, and your is almost 600 watts, obviously, you would double the cook time. Since this is rough, you need to experiment a bit. If the cook time is 10 minutes, check your product at 8 minutes. Be sure to push the stop button before you open the door when it is in cook mode. This will save wear and tear on door switches and leave the remaining cook time on the timer. Let me know how this works out for you..
Oct 11, 2013 | Panasonic 1974 Microwave Oven Cookbook &...
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
Burns my popcorn constantly. is there a different setting i can put it on?
HELLO.
Solution to your microwave problem is given as below.
* 1 Set your Daewoo microwave on a countertop near an electrical outlet and plug it in. Open the door and place the circular roller guide in the center of the oven cavity, then place the glass cooking tray over it.
* 2 Set your food on a microwave-safe dish and then put the dish on the cooking tray and close the door. Make sure that it latches properly.
* 3 Turn the upper knob to select a power level. Power levels include "Defrost," "Med-High," or "High." If your Daewoo has a touch pad, touch the "Microwave" button once to set the highest power level. Touch it consecutive times to lower the power level.
* 4 Turn the lower knob to set the cooking time. For cooking times less than two minutes, turn the knob up past the two-minute mark, then back to the correct time. For touch pad models, enter in the cooking time with the numerical keys and then press "Start."
* 5 Open the door at any time to stop the cooking and check the temperature of your food. Shut the door to automatically continue cooking, or turn the timer knob to the right to add more time. For touch pads, press the "Stop/Clear" button, then key in a new cooking time and press "Start."
* 6 Open the door when the timer reaches the "Off" position and take out your food.
Thanks.
Sep 24, 2011 | Daewoo KOC-925T Microwave Oven
Moved the mirco wave, then the only buttons that work now are the time set, but it only shows 12hr and 24 hr, and will not set the time. none of the buttons will work now for the cook time. if the power...
i cant work out if its broken or not over the years i do remember seeing a sanyo microwave that would not cook untill the time was set though have not seen another since (cause its a silly idea) but try setting the time and it might work
Oct 14, 2010 | Daewoo KOR-860A Microwave Oven
Occassionally (about 5% of the time) the microwave continues to cook and buzz after the timer has run out and the fan stops running.
sounds like the program bord is faulty,, when your finished cooking leave the door open a little that will save the microwave from trying to cook nothing?
Aug 28, 2010 | Whirlpool GT4175S Microwave Oven
Microoven model 860A is not getting heated
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101p][p[]p
Feb 25, 2010 | Daewoo KOR-860A Microwave Oven
Microwave GE MD JVM140K Spacemaker yr= 1994 NOHEAT, DISP/TIMER OK
Call GE answer center 1-800-626-2000
ask for tech help
Have you model # off your data plate ready.
May 10, 2009 | GE Profile Spacemaker Over-the-Range...
Daewoo microwave that won't cook
More than likely a door switch inside the unit is misalligned or faulty. Crack it open and check for proper allignment and good open/closed circuits with a VOM.
Sep 24, 2008 | Daewoo Microwave Ovens
Timer will run, but won't cook
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Aug 24, 2007 | Frigidaire FMV156EM Microwave Oven
Daewoo KOR-860A Microwave Oven Logo
564 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
