Question about Brother IntelliFAX 560 Plain Paper Fax
Will not make a copy
The copy function does not work, I cannot copy a document.
Help
  • Brother Master
  • 5,568 Answers
If it won't copy, it is unlikely to handle faxes either since those functions use the same scanner. If your received faxes are coming out blank, then it is a problem with the ink system; if you can get faxes printed but not copy a document, the scanner may be at fault.
Have someone send you a fax to check this function (printing) and then try sending one back to check the scanner.
If either one fails, then hyou know where the problem lays.
Posted on Nov 13, 2008
I typed a lengthy article on email to a friend. Now I want to transfer it to my Documents file. How do I do that?
Select the article and use copy function.
Open a new word document and paste the article in that word document..
using save function in file menu , save the word document in my documents...
Sep 03, 2011 | Computers & Internet
Can't work out how to use the multiscan? I press scan and it comes up with multiscan and I put the first piece of paper in but don't seem to get asked for any more sheets and it therefore just scans one...
Anita,
Put the pages in the "multiscan" all at once, not just one sheet at a time. The Automatic Document Feeder (ADF) will feed one sheet of your document at a time untill all of the pages are scanned...
Thanks for using FixYa!
Oct 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Black bar printed in the center of copied document
try copying the document to your computer and then from computer take a print out.
Aug 23, 2009 | HP Photosmart 2575 All-In-One InkJet...
Scanner failure when faxing of coppying
I need help also my black ink stop working also but think it is dry and that is why it won't wor. but still have same fax and copy problem exactly even the grinding noise
Fred
Feb 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Canon MultiPASS F50 won't copy but will scan
Does the copy function work if you place the document to be copied on the platen (open the cover and lay it on the glass)? If so, check the area to the left of the platen. There should be a strip of glass with a clear plastic cover over it. This area is used for scanning when feeding paper through the automatic document feeder (ADF) from the top. This area must be clean. If this area is clean and clear, it's possible that the scanner element (below the glass) is no longer going all the way to the left when using the ADF. This would be a problem that would require servicing.
Oct 15, 2008 | Canon MultiPASS F50 All-In-One InkJet...
Copying function not working
para imprimir la hoja de calibracion no la jala
Oct 10, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Copy function
well you gotta provide the details in scanners configuration where you want the scanner to copy your Documents to .i.e. whether you want it to scan and store it as a image or open it with some Application or you want it to print just assign any one task with proper configuration it will definately work.
Thanks
Nov 17, 2007 | Canon CanoScan LiDE 30 Flatbed Scanner
Printing - using the 'copy' mode of the scanner
This suggests the the 'copy' element of the software is not VISTA compatible. In VISTA help in my computer - check out the 'compatibility' options and select an operating system that the copy function did work under
Aug 31, 2007 | Canon CanoScan N640P Flatbed Scanner
Brother IntelliFAX 560 Plain Paper Fax Logo
111 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
