Question about Philips 51PW9303 51" Rear Projection HDTV-Ready Television
Broadcast Channels not picked up
Hi. I recently moved from California to Texas. Where I live, I don't have cable tv. I have broadcast channels. It only picks up one of the channels, but does not display it clearly. It works fine on the DVD players. I don't know how to get it to recognize the other channels. It is the 51pw90303/17f television. The remote works. Some of the buttons on the TV are broken a long time before the move, but the operation of the TV has not been effected by this.
Thank you!
Cindy
  • cmlivengood Aug 20, 2008
    The menu does not come up properly when I try this. :( I don't know. Maybe a new remote?
  • 138 Answers
Go into the add/delete channels and add them then program the setbagain.
Posted on Aug 19, 2008
  • Lawrence Smith Aug 21, 2008
    If the remote is bringing up the menu then it is working fine. Now when you say it does bot come up properly is it distorted and is the tv picture distorted also?
What does RF CH mean?
What is the difference between a RF channel and a virtual channel? The RF channel is the channel that the TV station uses to broadcast its signal. Before the conversion to digital, TV stations were normally identified by their channel number, and most people knew that a particular network was on a specific TV channel. While analog broadcasting was being phased out and all TV stations were converting to digital broadcasting, it was necessary for the TV stations to continue to broadcast their analog signals on their original RF channels, and also broadcast their digital signals on a different RF channel. However, since the TV station used their broadcast channel as part of their identification, they wanted to keep using the same channel number. To allow this to happen, the new digital television broadcasting standards (ATSC) provided TV stations the ability to continue to use their original channel number and also tell the TV set to tune to the new RF broadcast channel when their virtual channel number was selected. The original channel number is called the virtual channel number, and it will be followed by a period and a second number (3.1, 7.1, etc.).
One of the benefits of converting to digital for the TV stations is that they now have the ability to transmit more than one program at the same time on the same RF channel. The number of additional channels they can broadcast is determined by the resolution of the program (SD vs. HD, text only, music only, etc.). The second number in their virtual channel number indicates that one of the additional programming sources from the same TV station is being viewed (10.2, 10.3, 10.4, etc.).
When selecting an antenna, it is important to understand the difference between the RF broadcast channel and the virtual channel. Antennas are designed to receive specific ranges of RF channels, and the antenna needs to be selected for the RF channel you wish to receive. TV stations broadcast in two broad frequency ranges, called VHF and UHF. RF channels 2 through 13 are considered VHF, and RF channels 14 through 51 are considered UHF. In order to pick up the channels, the antenna has to be designed for the correct frequency range. It is very common today to find that TV stations using virtual channels 2 through 13 are actually using RF broadcast channels in the UHF range. Although not as common, some TV stations using virtual channels 14 through 51 are actually transmitting in the VHF range. An antenna designed for only UHF channels will not work effectively for RF broadcast channels in the VHF range, and an antenna designed for only VHF channels will not work effectively for RF broadcast channels in the UHF range.
Apr 09, 2015 | Televison & Video
The picture looks like it's moving in slow motion...
Ur tv incomming broadcasting tv channels signals are pick up and using are Free over the AIR broadcasting tv channels pick up are by a Antena signal wright?Not signals by a pay cables or satalites tvs incomming broadcasting input signals?Yes?This tv causes are low and weak ranges of a tv Antena incomming recieving broadcasting tv channels signal.Buy a better design Antena like a Digital Antena and used it will solved this problems.Plug it in ur Digital Antena and rescan ur Free over the AIR broadcasting tv channels again.
Aug 15, 2011 | TruTech PVS31170S1W 17 in. LCD Television
New aerial etc, but TV says no signal for any station. I have moved to a different town.
You need have the television scan for new channels since you have moved. I'm assuming that you don't have cable. It the television set up menu, there should be an option to have the tuner scan for available channels. After this is done you should be able to receive the digital channels that are being broadcast from your local stations.
Jul 18, 2011 | Televison & Video
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
I got a used Toshiba CZ32T31without a user manual. When I hook up the cable all I get is snow. I also can't get local broadcast when I move the channel to the station number.
If you are in the USA, all free broadcast channels are digital, so you won't get anything without a digital converter box. In Canada, some channels are still available without the box till August 2011.
The tuner may be defective. Use a VCR or cable converter with audio/video outputs and connect them to the appropriate inputs on the TV, use the VCR or converter to change the channels.
Jan 04, 2011 | Toshiba CZ32T31 TV
My tv wont pick up any channels i have a 42 inch lg tv and its connected to the household antenna but wont pick up any channels i have tried other ariels and still have the same problem?
have you switch the broadcast to Air from Cable using the remote go to this and also let it scan for channels auto...hopefully this will do the trick
Jul 26, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Vhf is not picking up signal, no image
Well since all TV is now broadcast in High Definition that might be why you are no longer able to tune in a station. You will need the converter box.
Aug 19, 2009 | Casio Televison & Video
Olevia is not picking up my cable channels. Anyone know how to do a channel search or scan on this TV
pick up the remote turn on tv....press menu...setup....tv....then channel scan....(note your tv should also be on cable broadcast not air)...hope this is helpful
Jun 20, 2009 | Syntax Olevia 537H Television
Sony Bravia does not see my digital channels
Hi buck lite,
Your cable company is telling the truth, you have digital cable. When auto scanned for digital channels the tv is lookig for OTR(over the air) signals. These are broadcast signals you will need an antenna to receive. Depending where you are and the type of antenna you use you probably could pick up some digital channels. Let me know if this helps and please rate this solution. Lone99star
Jan 20, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Can't program channels past 14
select cable as a source not broadcast its looking for UHF channels instead of cable up to say 100. go to setup select cable not antennea or broadcast. do a scan afterwards and ghave it find your channels
Dec 08, 2008 | GE 32GT740 32" TV
Philips 51PW9303 51" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
