Question about Fisher and Paykel Fisher & Paykel Washer
Fisher paykel washing machine GWL15
This is the second time the drum has come off the springs or side frame.... how can I fix it myself without waiting two weeks for the repairman???
  • 1 more comment
  • kkmauldin Oct 13, 2008
    When I did a load of towels the other day, the buzzer kept going off when it reached the Spin cycle. I tried again, only to have this happen again. I unplugged the washer and let it sit, then tried again. Eventually, I un-loaded the washer and power vac-d the water out. The tub seemed off balance, and I noticed that 3 of the 4 springs that hold the tub in place were missing. I have only had this washer for 3 months, and it is brand new from Lowe's. I don't want to wait for them to schedule a repairman to come out. Where can I order the springs?
  • pntrmount Feb 16, 2009
    I havea fischer paykel eco smart washer about 3-4 years old model #gwl11 , I can see 2 of the springs are gone , can hear a rattle is it easy to replace them or check them? this is the third time in the last year to have it repaired, 1st the motor, then something stuck in the drain pipe, the repair people are great but now I,m laid off and would like to try this myself. thanks forany input.
  • Anonymous Mar 27, 2014
    control bottom not opperating
  • 246 Answers
Without your model number I can't answer for sure, but for most models of f/p washers, this is the easiest way. First lift the lid and once it is straight up, pull it towards the cealing, it should slide straight up. On the right and left hand sides there are generally 2 "half moon" shaped peices of rubber. Pry these up with a small flat head screw driver. Underneath are phillips screws. Once these are out, the top of the washer should lift up from the front and let you get to the tub (and springs) underneath. If you are still having trouble. Drop me a note back.
Posted on Jul 11, 2008
  • Toby Norton
    Toby Norton Jul 11, 2008
    Sorry, if you are still having trouble, drop me a not back with your model number. (generally on the back side of the console)
Our gwl11 fisher paykel washer will start to fill for about 5 seconds then stops
This is either your lid switch not working or your out of balance switch the latter being located under the large motor controller board under the controll panel.That should fix it.Kind Regards Stefan.
Jul 08, 2009 | Fisher Paykel EcoSmart GWL15
Machine stops and will not move to next cycle--spin
Sounds like it it not recognizing that the lid is closed, could be a bad lid switch.
Apr 14, 2009 | Fisher and Paykel Fisher & Paykel Washer
The spring on the tub of my Fisher and Paykel came disconnected
THE SPRING GETS CONNECTED FROM THE LEFT FRONT STRUT TO THE OUTER TUB COVER BY WAY OF A RED BIAS CLIP.
Apr 07, 2009 | Fisher Paykel EcoSmart GWL15
Getting inside the Fisher-Paykel GWL15 washer
thats it , remove those 2 screws and the top will flip back, the new "clothes guard"( neck ring), will snap right into place, be sure to rehook the spring to hte left front susension rod!
Mar 25, 2008 | Fisher Paykel EcoSmart GWL15
Fisher & paykel smart drive washing machine leaking water
If your washer is still under warranty, I would call the company and have them send someone down. If the leak is from either the drum itself or a seal then I don't think you could handle it yourself. But, first make absolutely sure that it's not from any hose connection. Tighten all the connections, especially those to the drain pump. And check the pump itself for any leaks.
Mar 02, 2008 | Fisher Paykel EcoSmart GWL15
Help!!!!!
Check to see if you have a blocked filter. Regards Engineer
Jul 28, 2007 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
550 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
