Question about JBL PB10 Subwoofer
Dont know how to turn it on
I cant find a switch anywhere on the subwoofer to power it on i wasnt for sure it just automatically powers on when plugged on or what
  • 3 Answers
Just plug it in to an outlet. The lights on the front should be red (or standby mode). When it gets a good sound signal, it turns green (that's when it's on). It does not have a power switch.
Posted on Jul 24, 2008
No power to the speaker
Power Mode (rear-panel): This switch can be set to either On, Off, Auto. If the switch is in the Off position, the subwoofer will not power up. If the switch is in the On position, it will constantly remain on. If the switch is set to the Auto position, when a signal is present the subwoofer will turn on and will automatically turn off several minutes after a signal is no longer present.
Jun 10, 2014 | Energry Speakers Energy Speakers S8.3...
Sony xplode 1000watt amp. Was playing music turned up louder and sub cut out. Checking wires found ground wasnt crimped completely to connector so redid that. Now as soon as I put fuse in power line box I...
Isolate the problem by testing the subwoofer to make sure it isn't fried. If the problem isn't the subwoofer then your amplifier must be checked at an audio store.
Nov 19, 2017 | Car Audio & Video
Polk Tweeter on RT 1000i
it sounds like its the cross over
Mar 25, 2013 | Polk Audio RT1000I Speaker
MACKIE SRM450V2 WONT TURN ON AT ALL, WHAT SHOULD I DO? I OPENED THE AMP BUT DONT KNOW WHICH PART TO REPLACE
1) try a different power cord.if that doesn't work, unplug it for steps 2&3.
2) if you have a multimeter, check the switch to make sure that it's good.3) you should find a fuse on a circuit board if you have the amp opened, check it.If none of these work,send me a good,clear pics of the boards in the amp section. I'll try to ID everything for you. Those are workhorse speakers, well worth fixing.
Mar 01, 2012 | Mackie SRM-450 System
I have a kenwood radio and the radio wont switch off demo mode no matter what i do. I have looked at all wires etc and it still wont save preset stations or settings.. Its driving me mad! When i bought...
if it isn't saving stations you need to make sure the yellow wire is going to a constant power source. without knowing what brand or make of radio you have, it is hard to say how to turn off the demo mode.
Mar 22, 2011 | Car Audio & Video
Need the cable to conect my subwoofer for VR-407......HI i recently change to another house, and in the moving i`ve lost the cable that conects the subwoofer, i dont know were to get it. Or how can i make...
You don't identify the subwoofer so we have to guess.
Since it only supports a powered subwoofer I would guess you just need a standard single RCA cable available anywhere hifi cables are sold.
Apr 20, 2010 | Kenwood VR-405 Receiver
I cant seem to get the sub woofer to put out sound
Hello, are you using the subwoofer output on the receiver?
Did you turn the subwoofer on within the receivers onscreen setup?
this requires going into the menu selecting speaker setup and telling the receiver that you do have a subwoofer connected.
if you have done all this I would try to fist make sure the sub is working. easiest way is to plug a source directly into the rca inputs of the sub and see if it powers up. A CD player or even an ipod with the right connector will work.
if the sub powers on and produces sound then the issue is in the receiver and you will have to play with the setup. Its possible that the output jack is bad, I've had that happen when I pulled on an RCA cable and pulled out the socket but that's rare.
Is the subwoofer set to turn on automaticly when a signal is sensed?
does it have a switch to select high or low level inputs (speaker jacks or RCA connections on the back)
hope that helps
remember start by making sure the sub works then figure out why the receiver isn't sending a signal.
Feb 19, 2010 | Yamaha RX-V661 Receiver
The subwoofer just quit working I don't know if i turned something off. I check the various levels and found one that said "sub woofer off/ on and switched it to "on" but it still doesn't work. any...
1) Check your power outet - make sure you have power.
2) Check the cord going to sub-woofer, check power strip if using one, we want to make sure you have power going to the subwoofer.
3) If so check to see if you have a fuse installed in the subwoofer, replace if needed.
4) Make sure your audio wires are attached to subwoofer, inspect audio wire, if it is old wire then replace.
5) Trace your wire back to your system make sure it is connected to the Subwoofer terminal.
6) Check your menu options on your audio system, make sure the subwoofer is enabled.
Aug 30, 2009 | Audio Players & Recorders
This may seem silly, but where in the world is the On/Off switch on this thing? I cant see it anywhere.
Most likely doesn't have one, Many fax machines don't have them. Just the power cord for power on and off.
Mar 03, 2008 | Brother IntelliFAX 2800 Laser Fax
JBL PB10 Subwoofer Logo
217 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
