Question about Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine
Follow-up question Hey - thanks a lot for your response! Makes sense. The question now is, where do I get a new touch sensor and how would I get that replaced? Do I have to send it in? I don't know much about their repair service / guarantee. Thanks in advance for any addition help!
  • 515 Answers
You have to get to a Saeco service center to get a new one, the part number is 224890850 if you have 230V
Posted on Jul 11, 2008
Yamaha PSR S900 keyboard failure, in touch response mode when I hold one key (G) and touch another the second key produces a sound that is full volume just as if the "touch response mode "...
That is NOT touch response, but velocity sensing. Each key has two contacts and one closes before the other to facilitate measuring the key velocity. In your case, it sounds like the key you are holding down has a bad disconnect diode in the key matrix and is holding the "first contact" signal true so the next key senses max closure speed. If you are not electronically adept, you need to take it in for servicing... however first tip the thing and vibrate it as some contamination MAY be shorting a line in the key matrix. Staples and paper clips are notorious problems with keyboards when they get into the key area.
Oct 31, 2010 | Yamaha Music
Touchscreen is broken
Hi,when a touch screen is broken, it makes the touch response not to function again.
You will need to replace the touchscreen sensor pad.
You can take it to a Skill- full personnel for assistance.
Take care.
Aug 30, 2010 | Samsung Jet S8000 Cell Phone
Intake a cam position sensor slow response
Can you rephrase that...what you put makes no sense at all.
Nov 07, 2009 | 2007 Jeep Compass Limited
Reverse Sensing System doesn't sound
To test the speaker touch the wire terminal a 9 volt battery tester, make this by soldering wires to any 9 volt battery, then touch momentarly the battery leads to the speaker, the cone will move and make a slight pooping noise.
Oct 16, 2008 | 2005 Ford F-150
I see others have had the problem I have but where are the solutions you recommend? I have a Maytag M7DH665B2A Dehumidifier that freezes solid and has a corroded sensor that's fallen off the coils.
Hi Bonsia,
Does this unit freeze in warm weather?
How old is it?
You said, I have a Maytag M7DH665B2A Dehumidifier that freezes solid and has a corroded sensor that's fallen off the coils.
My recommendation is replace it!
Here is an interesting article I just read!
.Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Sep 22, 2008 | Maytag M7DH45B2A Dehumidifier
Fridge/freezer not cool.
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
I believe your problem is an old thermostat or compressor !
How old is it?
My advice is do not put good money into bad!
A new fridge will pay for itself in a few years by using a lot less electricity!
Here is an interesting report I just read!
Repair or replace?
Please remember to leave me a rating before you sign off!
Thank You, HUUUM
Sep 20, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Washer vibrates on spin cycle and is falling apart,
Hello
Welcome to fixya.
You say, your door is cracked.soap dispenser is cracked and falling apart?
How old is the washer????????????
Waiting for your response!
Repair or replace?
When to pull the plug on your old washer
The answer depends mostly on the age of your washer,
If your washer is under warranty or less than four years old ,
Note that washers under warranty might require service from a factory-authorized technician;
If your washer is out of warranty and is four to seven years old,
given that today's models have added features.
The repair costs more than half the price of a comparable new washer.
Data also shows that it doesn't pay to fix a less-expensive washer
of washers you replace are likely to end up in a landfill.
Thank You, HUUUM
Aug 27, 2008 | EuroTech EWC177 Front Load Washer / Dryer
C10-NGT RA+DEC clamps and the motors
Holy man.. response is kinda slow. Good thing I tried it myself.
Sure as heck, you can leave the Right Ascension and Declination clamps tight while using the motors!
It makes a lot of sense, and many things much easier....
Thanks for the.. reply? lol. Just joking.
Jan 04, 2008 | Celestron Advanced C10-NGT (600 x 254mm)...
LG DLG 2524W gas dryer
call svc tech under warrenty, also sensor rellies on clothes touching two shiny strips to sense the dryness of the clothes ussaly in front or rear of drier drum or rather back or front wall inside wet clothes short the bars and stalls timer when they are dry does not short bars so sensor knows dryness by resistance of short tilt drier front or back where ever bars are to make shure clothes main tain contact lots of time this cures the promblem
Nov 18, 2007 | LG DLE2532W Electric Dryer
Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine Logo
64 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
