Question about HP Color LaserJet 2600n Printer
Error message on HP 2600n
My HP Color Laserjet 2600n worked flawlessly till the first year was up. I never turned it off I never did anything but put paper in the tray and replace toner cartridges. So far only black has needed to be changed. I have plenty of toner. I get a error message stating I may be on a VPN thus causing my printer to to "talk with"my computer. After much hunting I find that VPN stands for virtual private network. I have the printer plugged in via an earthlink connection to my Link-sys wireless router, and I access my printer wirelessly via that link sys router. It was working fine and then for no apparent reason if fails to print. Now it seems I have a $300 tempermental paper weight. Until now I swore by HP......now all I do is swear @ my HP. Help....I know it's got to be something really simple. I can manually print test pages and such but it will not print on command from my dell inspiron 1300 laptop. Namroch@aol.com
Connect to it through usb/parallel from your laptop, If this works then check your settings through your wireless connections,Hope that helps
Andy
Posted on Jul 22, 2008
How to fix sensor error on hp color laserjet 2600
54.06
Error message
54.06
Description
Color density sensor error
Action
  1. Power cycle the printer.
  2. Calibrate the printer. Click here to view the document "HP Color LaserJet 2600n - Calibrating the printer" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314525).
  3. Change the Print Density settings through the HP Toolbox. Click here to view the document " HP Color LaserJet 2600n Printer - Change Device Print Settings in HP Toolbox" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00310627).
  4. If the problem continues, contact HP Customer Support Center for technical assistance athttp://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Apr 02, 2014 | HP Color LaserJet 2600n Printer
I get an HP error message on 2600n printer saying "57 Fan Error". Is it fixable?
57 Fan Error
Turn off then on
The device has experienced a problem with its internal fan.
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.The fan is not replaceable. Replace the engine.
Jul 11, 2011 | HP Color LaserJet 2600n Printer
Hp color laserjet 2600n displays error 55.1 turn off then on
hello friend i have a printer HPColor Laserjet 2600n it displays Erroe 55.1 Turn OFF/ON. How do i over come this problem?thx
Feb 18, 2010 | HP Color LaserJet 2600n Printer
HP 2600n
50.2 Fuser Error Turn off then on Description 50.2 Slow fuser error. The device has experienced an internal hardware error. Action
  1. Turn off the device, wait at least 25 minutes, and then turn on the device.
  2. If a surge protector is being used, remove it. Plug the device directly into the wall socket. Use the power switch to turn on the device.
if no result,
Fix this with a new FUSER Assembly for HP Colour Laserjet 2600/n (200/240v) Part Number: RM1-1821-240CN or Fusing Assembly – RM1-1820(110/120v )
Oct 05, 2009 | HP Color LaserJet 2600n Printer
Hp 2600n error 51.22 magenta cartridge, says turn on and off, hel
51.22 is a Magenta laser scanner error.
Try removing the magenta restarting the printer and reinstalling.
If that does not work you likely need a laser assm.
You might want to call a tech. to replace.
Apr 01, 2009 | HP Color LaserJet 2600n Printer
Sensor error, turn off then on
Check the level of your toner or TOP errors. If the problem persists, let me know
Nov 12, 2008 | HP Color LaserJet 2600n Printer
Printer HP ColorLaserJet displays Fuser Error
My HP Color Laserjet 2600n Printer is giving me error as
" 50.2 Fuser error " . then every time i have to reatart my printer.
please give me suggestion.
thanks and regards.
ajinmumbai
Dec 05, 2007 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
114 people viewed this question
Seeker5211
Seeker5211
