Question about Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony trinitron KV-30HS420 HDMI
Can I connect my PC to the Tv via HDMI?
  • 1 more comment
  • Anonymous Mar 30, 2014
    power button blinks but does not come on
    power button
    power button blinks
Yes. As long as your PC has an HDMI port as well (or at least a DVI port and a DVI-to-HMDI converter dongle).
Posted on Sep 07, 2008
Sony Wega KV-30HS420 input problem
Just reset the TV to its factory settings and check. To do this you have to enter its service mode option. How to enter the service mode option is described in one among the posts at the site linked here.
But, before doing this reset, just connect the HDMI cable to the TV, and input an HDMI signal to it. If there is no input signal, the set will display as 'no input'. Check this first. If you wish to get further assistance from me, come over by FiXya comment.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 17, 2014 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony KV-30HS420 stand by light flashes red 7 times
this is a lamp issue please replace the lamp this always happen and best thing is you don't' need a technician to help you yo can do it by your own
Mar 04, 2013 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Im trying to connect my hp pavilion laptop to my 2003 Sony trinitron color tv KV24FS100
Hi gg_fan_03
Between your laptop and the TV ,
• you may need a PC to TV Converter
like one of these:
instruction is on the web page.
• to enable on your laptop, set your Sony TV as secondary monitor.
• use the Video driver control panel.
Sep 11, 2012 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Does the sony KV-30HS420 TV used a lamp..if yes where to lacate it
the KV-30HS420 model is a CRT based set and thus has no "lamp". What is hte proble with the set?
Mar 06, 2011 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Hi there, we have a sony KV-30HS420 30 inch fd Trinitron that is blinking 7 times and then shuts itself off. We can turn it on again but this problem is understandably quite anoying. What do you think...
There is a power supply fault causing the EHT to rise above 33KV.
High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Hope that points the engineer in the right direction.
Mar 02, 2011 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony WEGA KV30HS420 shuts itself off
Sony KV-30HS420 TV shuts off, indicator light blinks 7 times
Sep 23, 2009 | Sony FD Trinitron WEGA KV-30HS420 30" TV
HDMI Video not working on kv-30hs420 but audio works
AmigaDude posts how to reset the video to factory settings here:
The instructions are as follows: 1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Once reset, you'll connect your RCA cables (Red/White/Yellow) and set up the PS3 display settings. To get there from the XMB bar, go to Settings > Display Settings. You might have to disconnect the HDMI cable from the PS3 before the RCA cables work. I don't remember entirely.
Select Video Output Settings > HDMI > Automatic. If you can see the prompt about a max resoultion of 1080i (with your HDMI cable plugged in) you should be good. Select Yes and press X to continue. You can set up the audio but it's not necessary. Select Finish and you should be good.
Jul 12, 2009 | Sony FD Trinitron WEGA KV-30HS420 30" TV
HDMI port does not work on the KV-30SH420
I dont have a TV with HMDI input but i do have a computer moniter. To change i have to press a button that changes from VGA to HDMI. My computer supports HDMI and when i tried it, it works. Try looking in your manual for a way to switch input methods.
Jan 20, 2009 | Sony FD Trinitron WEGA KV-30HS420 30" TV
dont use high volt arcing can do lots of damage. unless you can be sure comtng from speaker.
Nov 20, 2008 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony FD Trinitron WEGA KV-30HS420 30" TV Logo
933 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
