Back to:
Tags:
RCA D52W20 52 in. Rear Projection HDTV-Ready Television
I have serial number hd52w59
posted by mmccann on Jul 10, 2008
I am having the same problem as the hd52w20. The convergence is not an option any longer on our set up menu. Do you happen do have any information on this serial number? Would it be the same type of "fuse" repair as you described on the hd52w20? Thank you very much.
Mary McCann
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 11, 2008
Not Rated (0)
willtab
Rank:Guru Guru
Rating: 89%, 399 votes
the fl231 fuse problem will apply to any itc222 chasis set. The hd52w20 is an itc22 chasis.. although i have not seen it in that set if you do not have the convergence option in setup. that is my first choice in possible problems. a simple ohm chech of that fuse can determine if it open. Warning this television can generate potetial leathal voltages care should be taken when working with set with back off.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on I have serial number hd52w59:
I don't want to Accept this solution
Can you Help with these Projection Televisions problems?
RCA D52W20 52 in. Rear Projection...
After the TV has been on for a while, it will start...
Hello Willtab, I have a RCA HDTV Model D52W27D. Similar to...
I think a color tube, but I'm not the repairman. Grass on...
have you found anything else it can be?
The t.v turns on but after a few minutes the image fades...
Loading problems.
Repair Service
Find Projection TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
