Question about Astar LTV-3201 32 in. LCD Television
My power supply started smoking and appears to have spit out some dark liquid
I am wondering if there is a comman capicitor or something that goes wrong with the power supply on an Astar LTV-3001. The fuse on the power supply is fine, but there was some dark liquid that was obviously ejected from something on the power supply board and started to smoke. Can I just fine a new power supply module for it? Thank you very much.
Joe
  • Anonymous Nov 24, 2008
    This is the second time my Astar unit has done this. I think its a lil over 3 years old. I was'nt home the first time and my daughter freaked and turned it off. It has worked fine the last 4-5 months since that incident. then tonight I turned it on to put a movie on for my youngest. Suddenly the screen froze up and smoke started coming from the top of the unit. Smelled of burned plastic. :( I havent tested i agaion yet. Letting it cool down and see what happens in a little bit.
SOURCE: Astar LTV-3001 30 inch
cuando prendo el televisor sale la voz y no da imagen,tambien cuando trato de prenderlo no prende por favor nesecito ayuda
Posted on Jan 29, 2008
  • 2326 Answers
That was the power supply failing on yout TV.
You will need to change it or get it repair.
Posted on May 18, 2008
SOURCE: astar LTV-20PW
your lcd plug fried company sent me replacement first time now I have to find a place to sell me one also make sure tv is on a good power surge protector, can't say it won't happen again. cause i've been tere done that.
Posted on Jul 28, 2008
  • 1779 Answers
SOURCE: where can i buy a power supply
You might try suppliers in china, none here in the US.
Posted on Aug 11, 2009
  • 2326 Answers
SOURCE: I need a replacement circuit board for my Astar
The failures on these LCD's are due to defective capacitors in the power supply. There are about 23 capacitors that will need to be replaced to restore the LCD power supply functionality. Check the picture to see where the capacitors are located, the power supply on your LCD is not the same but similar to the one on the picture just the capacitors are place in a different order.
Let me know if you required further assistance.
Posted on Mar 12, 2010
Sony Kdl 70r520a is stuck in loop on start up. Sony logo appears then the screen goes dark, then repeats this cycle.
Go to badcaps.com because a bad capacitor on the powder supply board will cause this. There can be other reasons, but all involve taking that Sony apart.
Oct 23, 2014 | Televison & Video
White smoke belching out but will not start
white smoke is usually water, grey=oil dark grey=other fluids. with the belching and other symptoms i would be inclined to believe you have a blown head gasket.
Nov 15, 2011 | Cars & Trucks
It fire's up run's for 30 second's act's like it will die spit's out bunch of smoke start's it all over again!
You have an air conditioner that is spitting smoke?-- That sounds pretty dangerous!-- and likely FINAL!
I wonder if you are talking about something other than an Air Conditioner?
Your Problem is listed under Air Conditioners--
Maybe you can give us more clues, and more exactly what make and model we are talking about-- Maybe we can be more helpful then?
Mack B
Jan 27, 2011 | Heating & Cooling
DELL 2208WFP LCD-Comes on normally, but almost immediately goes dark You can see something on the screen if you look closely. Turn it off and back on you see it then dark. any help?
I believe the power led button is still on while the screen goes dark, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes dark after that
Since the power led button is on, It means the picture board on your monitor is faulty that is why it appears for a second and goes dark.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Dell UltraSharp 2208WFP 22" Widescreen LCD...
Boss RT 1045 not powering up
HES PROBABLY TALKIN ABOUT A CAPICITOR CAP IT ACTS A POWER SUPPLY A SECOND BATTERY IF U WILL IT HELPS TO NOT DRAIN UR POWER FROM UR MAIN BATT.
Feb 10, 2010 | Boss RT-1045 Car Audio Amplifier
Ford C4 Auto gearbox spits oil
It sounds like it could be overfilled, but that will be easy enough to check on the dipstick. Should be checked with the engine idling in neutral. Otherwise, the trans could be overheating, causing the oil to expand to the point that it spits out the breather. Pull the dipstick and check the fluid condition, if it's dark and smells burnt, the trans may be slipping or overheating for some other reason, and it's probably time to get a trans shop involved. You should probably run an auxiliary cooler at the radiator area in the type of application you describe, especially if you're gonna be using the gas pedal fairly heavily! Sounds like a sweet car, lots of fun to be had in something like that.
Oct 25, 2008 | 1983 Ford Fairmont
Won't power up
MY TV died over a year ago and for some strange reason I never got rid of it. I recently (today) replaced two capacitors and it works great again! It wasn't difficult to solder them on- and this was the first time I've touched a soldering iron. Open the back... you will see which capicitors are bad because they will be swollen. I ordered new capicitors online (Radio Shack didn't carry them). Just make sure that you solder them on in the right direction. The first time I tried the capicitor immediatley blew, the TV started smoking, and it left the room smelling of funk for a few hours.
Jun 09, 2008 | Insignia IS-LCDTV32 32 in. Television
Astar LTV-3201 32 in. LCD Television Logo
374 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
