Question about Kitchen Ranges
All 4 surfaces of my cooking rangw Model JBP64BBH2WH ARE INOPERATIVE
Yesterday used my oven to bake a chicken.
After I finished I tried to turn on my to cooking surfaces but no heat came out. the Hot top light, burner ON lights, and the clock come on but no heat on the surfaces.
What can I do?
Thanks
  • 2 more comments
  • ndsam Jul 10, 2008
    the maker of my range is GE
    The model is JBP64BBH2WH
    THE MAKER OF MY RANGE IS gENERAL ELECTRIC AND THE MODEL IS JBP64BBH2WH
    All 4 surfaces of my range are inop.
    The hot top light, the burners on light and the clock light come on but no heat,
    The maker of the range is GE appliances and the model is JBP64BB2WH'
    Please tell what can I do ?
  • ndsam Jul 11, 2008
    I opened up the heaters holder and checked all electrical connection and found to be in normal condition.
  • 19,396 Answers
Apart from checking connections at eyesight, you should thest them with a multimeter, did you do this?
Posted on Jul 11, 2008
    Novelist:
    Scholar:
  • 96 Answers
There are only two causes for this: When a surface unit fails it will usually "open" the electrical circuit and no further heating will take place. When this happens, the surface unit simply appears to have stopped working.
Or,
In some rare instances the element, within the surface unit, will "short-out" against the sheath which is the outer visible part of the surface unit. This will cause the sheath to rupture and sparks may occur for a few seconds. The sparking ceases after a few seconds. There may also be a "burning plastic" odor at this time.
  • 161 Answers
That's an electric cooker? I urge you not to open anything inside unless you know exactly what you're doing. The risk of electirc shock is very possible, anything not connected properly could heat up and start a fire and burn down your house. Refer to the TROUBLESHOOTING portion of the manual the oven came with, and try those remedies. If that doesn't work, you could use the warranty and get a free repair or even replacement, that is depending on what your warranty covers and how long it lasts.
  • john yray
    john yray Jul 11, 2008
    I meant ELECTRIC OVEN, not ELECTRIC COOKER. Sorry bro. Let me know how it goes.
    Scholar:
  • 135 Answers
Dear customer,
Thank u for ur inquiry reg ur product
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • thank u
      Genius:
    • 1,226 Answers
    Try if some conection are ok. open and look for the connection in the heater maybe disconnected.
    melnavz
    Posted on Jul 10, 2008
    • Emelio Navaja
      Emelio Navaja Jul 14, 2008
      hello again,
      You need to test the connection using the tester since it was appear to be good but it is busted.
      melnAVZ
      Master:
    • 555 Answers
    What is the maker and model of your oven range?
    Nuwave doesn't get up to 350 degrees
    NuWave Oven Reviews - Is it a Scam or Legit? - HighYa
    www.highya.com/nuwave-oven-reviews
    Getting started with the NuWave Oven is simple and easy. ... Also, because it doesn'trequire any preheating or venting, it won't heat up your ... with "HI" being the maximum, which roughly translates to about 350 degrees in a standard oven.
    Moist, Juicy and Flavorful Boneless Skinless Chicken Brxxxts
    busy-at-home.com > In the Kitchen > Recipes > Grilling
    Rating: 4.4 - ‎5 votes - ‎25 min
    Feb 25, 2015 - Quick and easy dinner doesn't get simpler than this! ... I started out making lunch fixins' and ended up making a beautiful meat entree that you (or ... Using a fork, I place the chicken brxxxts in theNuWave oven on the 4-inch rack, laying ... is defaulted to this, unless you change it. high power is 350 degrees.
    Nuwave Oven - Nu-Wave oven is junk! Review 139470 Apr ...
    nuwave-oven.pissedconsumer.com/nu-wave-oven-is-junk-20090413147...
    Apr 13, 2009 - I bought the Nu-Wave oven-pro on sale before Easter to cook a fresh 8lb turkey brxxst. ... Gave up, put it in regular oven for 30 minutes to get it to 170 degrees.... For Frozen Chicken Brxxst I Set My Unit to 350? and Cook 13 Minutes .... The people who say it doesn't cook chicken, etc., need to check to make ...
    All comments on Can I Bake in the NuWave Oven - YouTube
    https://www.youtube.com/all_comments?v=_GBGgD9gFts
    (400 degrees) I took it out of the pan by flipping it over on a plate and the whole botto
    Feb 08, 2016 | As Seen On TV NuWave Pro Infrared Oven...
    I need to know the cooking times for my chicken
    Use a thermometer and measure the chicken, keep track of how long it takes then you have the time it takes to cook that piece. It is always best to use a thermometer when cooking meat.
    Generally I bake chicken at 350 degrees F. for 30 to 40 minutes. To be sure that the chicken bre asts are cooked thoroughly, use a instant digital Cooking or Meat Thermometer for the proper temperature of 165 degrees F.
    These links will help.
    Safe Minimum Cooking Temperatures
    Meat and Poultry Temperature Guide Food Network
    Internal Temperature of Chicken and Turkey How To Cook Perfect Chicken...
    Mar 23, 2015 | Kitchen Appliances - Others
    How long do you bake 1 1/2" X 3" chicken strips in sauce?
    The safest way to know is to use a thermometer. Since you are using a red sauce you cannot look for blood. You could brown the chicken first and then put it in the sauce.
    Sep 01, 2014 | Microwave Ovens
    Some problem in poultry cooking
    You have to kill the chicken first!!
    Seriously what are you trying to do???, if it's cooking a whole chicken in a microwave, it is difficult to get a thorouh cooking because usually whole chickens are hollow in the middle, so you need to put stuffing in it to get a better performance as microwavs tend to heat in the middle of stuff, (air is hard to heat) try a stuffing with lots of moist (water) it will steam kook the chicken with a lot of flavour... remember to avoid stuffing that contains beens or seeds as they could explode inside the chicken and ruine a good supper... personally I prefer my chicken oven baked (all night at a low temp) I know I'm not GREEN by saying that I only use my microwave to quickly heat up left overs LOL!
    Aug 10, 2011 | Microwave Ovens
    Whirlpool Super Capacity 465 oven won't turn on
    My Whirlpool Super Capacity 465 oven
    Mar 15, 2010 | Ovens
    Farberware Turbo Oven -- Model 360 + Manual
    The only thing you have to know is that pork and chicken cook at 325. Any baked goods with leavening in it cooks at 75 degrees less than what the recipes calls for but no lower than 275.
    Feb 16, 2009 | Farberware T490C 1500 Watts Toaster Oven...
    HOW DO I ROAST A CHICKEN IN A AC925CHS
    Search the internet for “roast chicken recipe for microwave”
    Here is one just in case you don’t find one:
    Microwave Roast Chicken
    3 lbs. chicken
    1 tsp. salt
    4 tbsp. butter or margarine
    1 tsp. paprika
    Instructions
    Melt butter in a custard cup in microwave. Mix paprika into melted butter. Wash chicken (reserve giblets, these are best cooked conventionally). Sprinkle inside of chicken with salt. Cover ends of legs, tail, and wings with small pieces of saran wrap or wax paper. Place trivet on inverted saucer or small casserole lid in 12 x 7 inch baking dish. Place chicken breast side down on saucers. Brush with butter. Cover with waxed paper. Cook 12 minutes. Remove wax paper or saran warp from legs, tail, and wings. Turn chicken breast side up and brush with butter. Cover with wax paper and cook 12 minutes more or until meat thermometer registers 180 degrees (temperature will increase to 195 degrees during standing).
    DO NOT USE MEAT THERMOMETER IN OVEN WHEN COOKING!! Remove chicken from oven; cover with aluminum foil and let stand 15 to 20 minutes before carving. Note: For other weights of chicken, allow 8 minutes cooking time per pound.
    Jan 09, 2009 | GE JVM1860 Microwave Oven
    Maytag cook top too hot!
    Remove cooktop and check to see how much insulation is below the top, on top of the oven cavity, You may want to install some more insulation. The specs for this range probably allows this to happen. you should not put anything on the top after cooking in the oven, as glass breakage may occur.
    Dec 04, 2008 | Maytag MER5775Q Electric Kitchen Range
    Kitchen Ranges Logo
    252 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
