Question about 2wire 2700HG-B Router (2700HGB)
Internet conection when i try to set up an internet conection it goes through the stages then it says it cant find atm what is the atm
  • 1 more comment
  • wastedlife69 Jul 11, 2008
    hi i'm with tiscali.co.uk i have a 2 wire 2700HG-B
  • salswals Jul 11, 2008
    I have the same problem. I finally got my 2wire router working and when I connected my DS I found I can no longer connect to my laptop. The router shows on my network connections but when I press connect it tries for ages and then all networks disappear and it tries again, yet won't connect. It knows the network key so that's not the problem. My DS can also still connect to the router but my laptop won't connect to the router. What do I do as I can't even access the router setting page anymore.
  • Anonymous Mar 25, 2014
    ATM Pin reversal
    Novelist:
  • 143 Answers
ATM means Asynchronous Transfer Mode. it's a protocol used to transfer data. it could be that when you are running the setp cd, ATM mode is selected. and if the connection provided by your ISP is not on ATM mode, it'll provide the message that it can't find it. you can check the type of conenction you need to use from your ISP or you can provide me who is your ISP and the model of your modem so i can check it out for you.
ciao!
Posted on Jul 10, 2008
  • aila tanada
    aila tanada Jul 12, 2008
    with tiscali as your ISP, most probably, you should setup your 2wire to pppoa connection. follow the steps below on how to
    1. 1. Open a web browser and type http://192.168.1.254 on the address bar
    2. Click "Run System Setup Wizard"
    3. Login with preset password: admin. Or change password: click "I forgot the password." Under question "Here’s a hint for the password wedding date", click "I still can’t remember the password.". Then Reset System Password by enter System Key which locate on back of the Router (like: [1234567890]), and your new password, then click "Submit"
    4. "Set Up Your 2700HG-B Gateway" screen. Keep default "Key Code". Click "Next"
    5. "Time Zone". Select your time zone,then click "NEXT"
    6. "Set Up Connection Info". Enter "PPP Authentication" information provided by internet service provider. "Username from ISP", "Password from ISP", and "Confirm Password", then click "NEXT"
    7. Screen "Connecting" running...
    8. Auto turn to screen "2700HG-B Gateway Setup Complete", click "FINISH", or "EXIT" to complete setup or "Register" to register with 2WIRE on line.
    hope this'll help you
    ciao!
Reset pin for the zillions jr. atm
My Zillions Jr. ATM only has a 3 digit pin. I have tried the "default" which I've determined via internet is supposed to be 1234, but it is wrong. Any 3-digit guesses, besides the obvious 123? That doesn't work either.
Oct 29, 2012 | Summit Appliances Division Youniverse...
Im trying to conect to the internet but cant. how do i conect?
is it a DSI or a DS lite????
it only works for a DSI!!!
Jul 30, 2010 | Nintendo DS Lite Console
2wire 585 forgot password and need 2 config have no phone number to change password
f you don't know the system password for the twowire it has a factory reset button near the lan ports
* Hold down the reset button on the back for 30+ seconds.
* Upon releasing the reset button, the router resets itself to factory settings.
* Connect a computer to the 2700HG-B and browse to the URL http://192.168.1.254/
* Enter a new password, confirm it and enter a password hint at the bottom of the page, in case you forget the password.
* At this stage you might receive a "Page Not Found" error, but the password appears to be set successfully.
* To continue, manually browse to the url http://192.168.1.254
* Home Page (summary)
* Run System Setup Wizard
* Enter key code 5225 2374 WG62 22AS BJ7P (from http://www.2wire.com/?p=268) to set up manual config
-> Next
Choose TIme Zone -> Next
* Enter ISP set up details
* For most UK ISPs this will be
Connection type = PPPoA
VPI = 0
VCI = 38
ATM Encapsulation = VC-Mux
For Be /O2 users only
VPI = 0
VCI = 101
ATM Encapsulation = LLC
Exit Registration when connected to Internet
If this helps you plese rate and vote
Feb 25, 2010 | 2wire 2700HG-B Router (2700HGB)
Trouble setting up my belkin N150
Do you have a user name and password to connect to the internet?
If you have that then you will need to set the router to PPPOE connection.
If not , then you will need to set the router to DHCP mode.
First make sure that your computer will be able to go online through the modem. It is very simple and you don't need the CD.
You can set up the router like the DSL connection.
Click Here for more info on how to set up the router.
Oct 14, 2009 | Belkin (F5D8231-4) Wireless Router...
Cant conect to internet using wirles with Windows Vista
This method will hard reset the wireless drivers back to default settings, but before you perform this remove power from the modem and router for 2 minutes reconnect power and wait another 2 minutes for them to settle down.
Right click "computer" select "manage" and then "device manager", a list will populate, then click on the + sign next to "network adapters" and right click on the wireless adapter and "uninstall" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again.
Good luck.
Aug 30, 2009 | Microsoft Windows Vista Home Premium with...
D-Link modem is dead.
Try to configure the settings of the d-link modem. Make sure the atm circuit identifier goes along with the settings required by yopour isp. If not, try to check it with them. Normally, internet connections make use of vpi as 8 and vci at 35 for ciruit identifier. Try that. You can change the settings of the modem by pulling its interface.
Hope that helps.
Jun 24, 2009 | D-Link DSL-2320B
Rebooted my laptop and there is not wireless conections
It means your driver of Wireless (Wi-Fi) is not properly working or configured... try downloading proper drivers of it also and configure it according to your network settings...i am sure then you get access of internet... rate this solution if it is really helpful to you
Apr 24, 2009 | Dell InspironTM 1501 Notebook
Looks like conected but i cant get internet
Router might not be set up with the modem. Your router broadcast wireless signal when it is powered on, so even if it is not connected to a modem(where you get your internet from)you will have a local connection. That's normal. You need to set up the router. Call linksys technical support, if they cannot help try http://technicalsupport.blog.friendster.com
Feb 24, 2009 | Linksys Wireless-G Broadband Router
2wire 2700HG-B Router (2700HGB) Logo
193 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
