Question about Maytag Atlantis MAV6000 Top Load Washer
I have a Maytag Atlantis MAV6200AWW. It often does not empty out the tub when it is finished, and the water is still soapy after it is done. If I turn it back to spin it does and drains ok.
    Top Expert:
  • Maytag Master
  • 9,472 Answers
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.If the drain line isn't plugged, the problem may be with your pump.
Posted on Jan 06, 2011
SOURCE:
I have a Maytag Atlantis MAV6200AWW Washer agitates and spins. Water sometimes empties. Pump is fine spins freely and the impeller is fine. Could it be the belt ?
You will need to check for an article of clothing stuck between the basket and tub that may be partially blocking the drain hole.
Nov 22, 2012 | Maytag Atlantis MAV6000 Top Load Washer
I have a Maytag Atlantis MAV6200AWW. The washer
hi
the solenoid on the cold water is gone down or it is not fed with electric
Jan 29, 2018 | Maytag Atlantis MAV6451 Top Load Washer
I think my Maytag MAV6200AWW washer has a bad tub seal & bearing
if you have had this unit for over 5 years Then it is TOTALLY NOT worth the repair - if it is only a year or 2 old then call MAYTAG and they may offer a parts/labor concession. average life is 5-10 years now as sucky as that is!!
Nov 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Water Level and Water continues to drip after cycle has ended.
The water dripping into the tub is caused by the fill valve solenoid not closing completely. The fix is to replace the fill valve. The overfilling of the washer is caused by the pressure switch. Over time the diaphram within the pressure switch becomes fatiqued & fails. The fix for this is to replace it as well... Hope this helps... Bill
May 18, 2009 | Maytag MER5775Q Electric Kitchen Range
Maytag Atlantis MAV6200AWW Washer Problem?
I HAVE AN ATLANTIS MAYTAG WASHER . I HAD THE SAME PROBLEM AND I SOLVED AS FOLOLWS. REMOVED THE MOTOR, I APPLIED GENERAL PURPOSE GREASE ON BOTH SIDES OF THE SLIDING MOTOR SURFACE PLATE (MOTOR BASE) . THE GRASE HELPS THE MOTOR TO SLIDE BECAUSE AS YOU KNOW THE MOTOR DOES NOT HAVE ANY ADJUSTMENT. TRY IT PLEASE . GOOD LUCK
Feb 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Water Leak
Yes all you have to do is take off the front cover of the washer or the back cover, it it usually the front on top load washers. I believe your water pump may be cracked, but am not sure. What you need to do is remove the cover and start your washer and let it fill. Get a flashlight and pay close attention to where the water is leaking from. Then all you have to do is replace the part and your done. Any part dealing with water leaking will not be hard to change.
Sep 23, 2008 | Maytag MAV6200 Top Load Washer
Lint on clothes
hi thanks for the question sometimes a lot of suds in tub will cause this cause lint and suds stick to the outer tub and is difficult to remove try filling the tub with hot water and use vinegar in the water half bottle let stand for 4or 5 hrs . now drain the tub should work thanks for the question the appliance doc
Sep 03, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag mav6200aww removing inner tub
I broke a hammer removing the basket on a 6000 series today. These are known to be a real ***** to remove. Once those screws are out there is a seal nut to remove and the basket hub assembly is what it sits on. Look at 5 and 7 below.
Jul 29, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
85 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
