Question about Frigidaire Heating & Cooling
Frididaire AC Gallery need to change plug from 110 to 220 How to do this?
  • amattiel Jul 11, 2008
    HI THe AC is listed at 230 Volts.....and it was suggested to change the plug.
    Thanks
    Art
  • 828 Answers
First check the name plate for the proper voltage. If it is rated for 115/120 volts there is no reason to change the plug and if done can result in burning out the unit.
Posted on Jul 11, 2008
  • James Helmer
    James Helmer Jul 11, 2008
    In the new plug there will be one green wire screw, attach the green ground wire to that screw. The other two wires can go to ether of the other two screws. If the new plug has a clamp for holding the cord make sure it is secure. Then you should be good to go.
HOW DO I TAKE BOOTOM BURNER OUT FRIDIDAIRE GALLERY CFES 388REB1
Hello rdbal - Most bake and broiler elements are typically held into place with 4-6 screws or fit(s) in a bracket like connection and then needs to be screwed down. However every unit is different so please contact a professional to move accurately for more information due to safety and liability reasons.
Nov 11, 2012 | Frigidaire Gallery GLEFM397DS Electric...
Frididaire gallery has power to lights but nothing runs
More than likely the compressor grounded out blowing the switch, which I've seen a few times dealing with that brand. The times that I've ran across this situation, the main control board inside the refrigerator had to be replaced as well because the compressor sent a surge up to that section severely burning the board.
Jun 21, 2012 | Frigidaire Gallery Series GLHS269ZDB 36"...
Were is the drain plug located on a 2007 chevy 5.3 on the passenger side of engine . is it behind the ac unit. i want to put a engine block heater in.
The block drain is on the passenger side of the engine, in the center of the block near where the oil pan attatches to the block.
Engine Block Plugs/Sensors
100 - Engine Block
100 - Engine Block
101 - Oil Gallery Plug - Front
110 - O-Ring
111 - Oil Gallery Plug - Rear
112 - Oil Gallery Plug - Side
113 - Washer
114 - Engine Coolant Heater
115 - Washer
116 - Oil Gallery Plug - Side
117 - Washer
130 - Transmission Housing Locating Pin
145 - Washer
146 - Engine Block Coolant Drain Hole Plug
701 - Crankshaft Position (CKP) Sensor
702 - O-Ring
718 - Knock Sensor
718 - Knock Sensor
739 - Bolt
739 - Bolt
750 - CKP Sensor Bolt
Oct 19, 2010 | Chevrolet Silverado 1500 Cars & Trucks
-F9- Clean Frididaire Gallery Series
F9 code means Control has detected a problem with the motor door latch assembly Soultion: Check wiring, replace the motor door latch assembly if necessary
May 06, 2009 | Frigidaire 30 in. Electric Gallery Series...
Loose handle on frididaire gallery series dishwasher
Handle needs to be replaced part# 154537303 (blk). Un plug unit, take 4 screws from behind blk control panel out. Panel will fold down, remove two torx head screws from door latch, replace with new one and put it back together and your done.
Dec 12, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Frididaire gas oven won't light
Does the cooktop burners work? if they do then the problem is either the safety valve or the glow plug (even though it glows). Try tapping the safety valve. If the oven lights up change the glow plug.Otherwise change the safety valve
Regards
Nov 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Freezer leaking water
The drain is plugged just below the coils in the back of the freezer. My fridge had the same problem and I found the hose (which can be accessed from the rear bottom) was plugged with mold. Also, i noticed the hose was connected to the water holding pan and was too close to the bottom and easy to plug. I removed it from the connector and just let it dangle in the holding pan.
Aug 30, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Would like to download owner;s guide for a frididaire gallery series slide-in stove Model # CGDS378DS1, serial No. 34315072
go to www.firgidaire.com click on the customer service tab at the top and select manuals you cah download it from there
May 13, 2008 | Kitchen Ranges
Heating & Cooling Logo
71 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Donni Steen
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
