Question about Lands Phones
My son threw up on my razor it didn't get very wet. I took out the battery and dried it with a blow dryer it all seems to work except the key pad every time I push a button it trys to go to internet
  • 131 Answers
It sounds like you may have dried a chunk or two where the Internet shortcut, (or another) key is. I suggest Home Depot or Lowes Electrical person showing you where the contact cleaner is. get a couple it's great for this stuff , water on expensive electronics. Alternate is CRC or QD contact cleaner usually at car parts places, also a couple cans of compressed air. make sure the contact cleaner is plastic safe .
1) Open and remove everything including rubber cover plugs and anttena, battery, memory card...... EVERTHING.
2) Read Can This Stuff is cold when it sprays and gets onyou but with no fire present and open wires. so outside, absolutely fill and fill all orifices you can see use small plastic tube in usb charge port, all through the body from rear, where battery goes.
when full and more full, (you get the idea by now). Now hold phone and swing arm down after it soaks about 10 secondsflip phone repeat. now use canned air in all accessable spots paying alot of attention to the bad design of the buttons blow under all keys well.
3) I have also used a toothbrush when soaked with good results.
now it is clean and you can pry to have renoed whatever was stuck under the button in question.
4) warm but no oven . set on das incar on a sunny day or a heat lamp for awhile then give it a go.
good luck~!
Phonedude
Posted on Jul 11, 2008
I was in heavy rain and my phone got wet. I took the battery out and let everything dry. everything works except for touch screen
The digitizer maybe bad. You may want to leave it out without the battery in. use a blow dryer but do not heat it up it will crack the screen. If that doesn't dry the screen out then the digitizer will have to be replaced. hope this helps.
Oct 23, 2010 | LG Vu CU920 Cellular Phone
My son dropped the DS in the bath last week. I
Let it dry out for another day or two too make sure it's completely dry inside. Or you can you a hair dryers to blow out and dry the excess water inside.
In case none of this will work, it needs repair.
Feb 23, 2010 | Nintendo DSi Blue Console
My son went swimming with his samsung gravity. it worked for a bit after drying out and now it won't turn on. The battery seems to charge ok. How do I take it apart to clean the key pad?
Dont need to do that. Use your hair dryer without heat and blow into the phone. Do it for a few minutes many times. It should work when all traces of water have eveporated.
Aug 10, 2009 | Cell Phones
One key pad not working on LG Voyager
I don't know if this will work for sure but when that happened to be a few days ago my keys didn't work either but i took my Battery out and dried them both off for 2 minutes on warm and cold and cool if that doesnt work i don't know what to tell you
May 26, 2009 | LG VOYAGER VX10000 Cellular Phone
LG VU screen doesn't work after water damage
I was cleaning the pool when my LG Vu took a dive. I fished it out in about 2 minutes...should have jumped in and it would have been in only seconds.....anyway. Dried it off with my shirt and pushed the lock button to unlock and see the screen...it was on but said Emergency Download. I took the battery out and dried it off also took out the SIM card and memory card. Shook the water out; some drips here and there, fortunately it wasn't water-logged. I let it sit for about an hour and got on the internet to find a remedy. I took advice to put back the memory and SIM cards and plug in to charger....the screen directed me to put in the battery....so far so good. The screen said the battery was charging. I waited patiently for that to finish. When complete, unhooked the charger and hit the unlock button again....what do you know the screen came up! I was estatic! But....the touch screen would not work!! Back on the internet for advice. Decided to do the hair dryer trick. I set the dryer on cool setting and let it blow on the screen. I also opened up the chargers portal and let air blow in there. I took the cover off the back to the battery and let it blow on there....being very careful not to let the battery fall out and not let the phone get hot. I did this for about 30 minutes. There was some fogging of the screen so I focused more on drying the screen with the dryer. The fog cleared up and when I touched the touch screen the top of the screen started working first...bottom still not responding...a little more of the dryer and all worked!!! Screen fogged again in about 20 minutes...dryed it again with dryer and it has been dry ever since. I have gone to every application, etc. on my phone and everything works just like it did before it took a dip! Hope this helps some of you! Key is patience, and some drying with TLC! Best of Luck!
Apr 29, 2009 | LG Vu CU920 Cellular Phone
Wet cell phone
try taking the battery cover off removing thre battery and sim card and if possible take the front cover off and wipe keys down with a baby wipe and them blow dry with hair dryer all pieces of phone for 5 minutes let sit for a bout 8 hours with all pieces still removed from phone
hope i was helpful
Jun 26, 2008 | Motorola Mobility i880 Cellular Phone
Keys do not respond
Your phone might have water damage. I had the same problem I took the battery out. I took a blow dryer and blowed dryed all of the keys. Try this is might work
Mar 02, 2008 | Motorola Mobility RAZR V3
Dial out problem
you just have to change the key pad and dry the inside of the phone.
Feb 09, 2008 | Motorola Mobility RAZR V3
RAZOR V3
HAS IT BEEN WET? IF SO OPEN BATTERY DOOR AND REMOVE BATTERY THEN POUR RUBING ALCOHOL NOTE MUCH THEN VACUME NOW PLACE IT UNDER POWERFUL FAN OVER NITE.TRUST ME IT WORK'S...
Feb 01, 2008 | Motorola Mobility RAZR V3
My razor
yes, if your phone gets wet dry it out before turning it on. once dried if still not working properly take to repair shop or replace keypad yourself
Nov 20, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Lands Phones Logo
95 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
