Question about Whirlpool Dryers
The dryer just stop completly do not hear any noise as far as the timer checked fuse changed the fuse and the dryer still will not turn on.
  • 254 Answers
Check you door switch.
Posted on Jul 10, 2008
Haier dryer ticking noises
ticking you hear is the timer motor,drive motor is most likley geeting too hot.check vent ,dryer pushed back too far?hose kinked ?stopped up?too long?vent should be short,straight and of hard pipe.clean vent twice a year,heating element will love you.you will not love to replace it.
Mar 15, 2014 | Haier HLP140E Electric Portable Dryer
Dryer will not turn on and i hear a clicking noise by the timer plus if the fuse needs changed how would i do that
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 15, 2010 | Kenmore 67632 Electric Dryer
My dryer is not turning on..I hear a click as though it is trying to but nothing happens
I'm guessing your hearing the timer making noise...if its the timer making noise you need a multi-meter to check the thermal fuse and links.
There is a long fuse that can go bad and cause the motor not to start. The thermal fuse is behind the back panel. remove panel and check fuse's
May 20, 2010 | Whirlpool WED5900S Electric Dryer
Buzzing noise when i turn the timer switch
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 06, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Kenmore Dryer won't turn on
Hi...
This are the tipe on how to Troubleshot dryer follow the steps below
IF the dryer is noisy
Level the dryer
Check the drum belt
Check the drum support rollers
Check the idler pulley
Check the glides
Check drum bearings
Check the blower
Check the baffles
If the dryer tumbles, but there is no heat
Check for proper air flow
Test the safety fuse
Test the thermostats
Test the centrifugal switch
Test the timer motor
Test the heating element
Good luck !!!!
Regards
PCmania
Jul 03, 2009 | Kenmore 63942 Dryer
The dryer heats and shuts off in about 30 seconds repair guy has changed a thermo fuse? and i still have the problem i've checked my ducts no blockage it runs on air and delicate fine but on reg heat in...
its your timer that needs replacment. not the thermal fuse.
if the thermal fuse was ever tripped, it would not start at all. you would only hear the ticking of the timer.
if other cycles work its the timer not any of the sensors or fuses.
dryers are very basic, and are completely controlled by the timer (or control board for digital models)
Jun 16, 2009 | Dryers
Frigidaire Model FSE446RHS0 Dryer won't start.
its sound like the belt could have broken off or overheated normally when a belt breaks the machine no longer runs except for the timer noise you hear remove clotche from dyer turn the drum manually if it turns freely by hand that meens your belt is broken thanks from gilles
Mar 15, 2009 | Dryers
Will not start; makes no noise
check the humidity sensor this will prevent the motor from starting
Sep 22, 2007 | Maytag PYE2300AY Electric Dryer
Open Questions:
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
