Question about Whirlpool Dishwashers
Whirlpool dishwasher du945pwpq2 will not even turn on. verified there is current going to the dishwasher but aparently it gets lost somewhere.
  • 254 Answers
There's a thermal fuse in the control panel that might have blown. It's near the board.
Posted on Jul 10, 2008
I have a whirlpool dishwasher the normal and sani rinse and cancel lights are blinking. i cannont cancell the cycle and will not run The model # GU1100XTLT1
Shut breaker at circuit breaker panel that feeds the dishwasher for 5 minutes then turn on again and verify dishwasher has cancelled wash itself.
Jun 14, 2016 | Whirlpool Dishwashers
Dishwasher not cleaning properly
There are many reasons why a dishwasher does not work correctly. A repairman told me to always check for debris (food, coins,lids, hard things lost in the dishwasher). You can take the screw off the arm that turns on the bottom level and search under there for anything stuck (even pieces of bone) the dishwasher has several other food filters in the motor assembly but this first one is easy to get to. I would let a repairman fix the motor, but as he said this easy fix is a possibility.
Sep 08, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quiet partner 1 won't drain all the way suddenly
Hello.
HERE ARE TOOLS NEEDED AND INSTRUCTIONS ON HOW TO SOLVE THE DRAINING PROBLEM BELOW.
(A) Clean cloth(s)
(B) Wrench (if necessary)
Whirlpool brand dishwashers come in black, brown, stainless steel or white finishes and a variety of sizes as well. Most Whirlpool dishwashers are energy efficient, and many have features such as a sanitizing rinse, enhanced sound effects, large capacity tubs and adjustable shelves and racks. However, none of these features will help users much if the dishwasher is not draining. While this issue may require professional repair, some troubleshooting steps may help determine if there is a relatively simple cause for the problem.
1 Verify that the Whirlpool dishwasher has not lost power due to a power failure or motor overload. Wait a few minutes to see if the motor automatically resets and resumes operation. Reset the circuit breaker or fuse if necessary.
2 Press or select "Start" to resume the cycle if the dishwasher was stopped mid-cycle. Choose a new drain cycle if necessary to remove excess water from the unit.
3 Turn off the dishwasher and unplug it from power. Examine the connection between the dishwasher and the garbage disposer, usually located underneath the kitchen sink. Make sure the disposer knockout plug was taken out between the two.
4 Run the garbage disposer in the kitchen sink to remove potential blockages.
5 Remove objects that may be blocking the drain on the dishwasher. Clean out the drain hose at the rear of the dishwasher.
Thanks.
Nov 06, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
How to clean out pump drain on DU1050XTPQ1
Hello.
(A) Wrench (if necessary) (B) Clean cloth(s)
Thanks.
Nov 05, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher wont fill
I fit won't fill then apparently you're not getting any water to it, which means it not's fixed. Did you turn the service valve back on since the repairs were made? Sometime when you turn a service valve off they fail to re-open. Crack the inlet water line and verify that you have incoming water.
Jan 18, 2009 | Whirlpool 24 in. DU1050SS Built-in...
F8 is flashing. The drainage well in the bottom of the machine is full of water, so much be blocked somewhere.
It could either be the filter (most likely), the drain pump (likely) or the drain hose/tube (least likely).
Normally, there would a filter somewhere at the bottom of your dishwasher with the primary function of keeping large particles of food and foreign objects away from the impeller/pump. Most current dishwashers have self-cleaning filters and therefore regular cleaning is no longer a concern. However, some other dishwashers need to have the filter manually removed and cleaned regularly or as even in your case. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher and may cause the problem as you have described.
To check the filter and/or the drain pump, the bottom has to be exposed, the filter/pump located and cleaned.
There are pages online with illustrative description and detailed procedures on how to go about this. Perhaps you can try referencing here and/or here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 24, 2008 | Whirlpool Dishwashers
Whirlpool adg7540
check your hoses and your main water supply coming into the machine if the nut is loose tighten it up
Feb 17, 2008 | Whirlpool 24 in. ADG7540 Built-in...
Dishwashers Logo
371 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
