Question about Samsung Refrigerators
Fridge freezer has power but compressor does not kick in. Distinctive click from rear every 30 seconds or so.
  • 254 Answers
You may have a bad start relay or capacitor on the compressor.
Posted on Jul 10, 2008
Frigidaire Refrigerator is warm on top of the frig and freezer but fine on bottom.
Remove the rear lower panel on the unit check to see if the compressor is hot or if its running, should feel the vibration, also listen for any clicking noises.
Oct 15, 2008 | Frigidaire FRS26H5AS Side by Side...
Freezer on bottom, cold, fridge not cold,ice on
Probably the difusser door that allows cold air from the freezer into the fridge portion, either stuck or control dial faulty
Aug 22, 2009 | Refrigerators
Fridge and Freezer won't cool.
The evap fan is running - but is your compressor motor running -t his is what i'm concerned about - 82F ? That is very high - this suggests to me there is no cooling AT ALL - only the fans are working - and my gut tells me your compressor is not running AT ALL - I would rule out thermostat since when it kicks in and your evap fans turn on, your compressor should turn on too. If this fridge has electronic controls, have your motherboard / control boards checked, have your compressor checked. If your compressor is running and you can hear its distinctive humming sound, then you have a sealed system problem, a major one :) Have those two things checked.
Aug 19, 2009 | GE Refrigerators
Amana side by side
either compressor is jammed or the starting relay with capacity is faculty
Jan 13, 2009 | Amana ARB8057CSL Bottom Freezer...
Came home sunday night and our side by side fridge freezer was not working, just the fan is running, how do i locate a repairman, since this monday is a holiday. i have frozen buckets of water, and placed...
Any frost on back wall of freezer section. If so you have a defrost system problem. If you can hear a hum followed by a click the problem is with the compressor. In back of the refrigerator is a removable panel. remove it and carefully check if the compressor is hot. A cold compressor indicates no power to the compressor which would be related to the temperature control or defrost timer.
Defrost timers are normally located in the area of the temperature controls. Locate the timer and rotate the clutch head screw clockwise slowly until it makes one click. If the timer is the cause of no power to the compressor the compressor will restart. If the problem is defrost related this same action will start the defrost which should take place in 18-22 minutes. If defrost of the freezer coil takes place and the compressor does not restart after the time indicated (wait 30 minutes) rotate the screw slowly one more click and the compressor should restart. If you had to rotate the screw the second time the problem is your defrost timer.
May 19, 2008 | Maytag Refrigerators
Amana bottom frezzer refrigerator
Gazzo, You are on the right track. I've been finding a lot of compressor failures on these Amana's. It's possible that the overload and relay for the compressor failed, but Im more inclined, from what I've seen, that the compressor is the problem. The compressor is covered under warranty, parts and labor for 5 years. I would call for warranty service...Catriver...post back.
Jan 04, 2007 | Amana ABB1927DE Bottom Freezer...
Fridge and Freezer working intermittently; not getting cold and making a vibrating sound
Dave, what you are hearing is the overload kicking out on the compressor. It's one of two things, either the compressor is failing or PTC (overload, relay) is going bad. I haven't seen too many PTC's fail on Frigidaire, but I have seen a lot of compressors failing. Your refrigerator will have a 5 year warranty, parts and labor if the compressor is at fault. You would have to do some tests on the compressor to determine which one is at fault. If you have a clamp on ammeter you can see how many amps the compressor is drawing during start and run. The compressor should have a label on it with the amperage information. You could just replace the PTC, part number 218721119 and see if the problem goes away but you could be throwing away money here if the compressor is the problem. With out being there, my guess would be the compressor itself. Catriver...post back.
Dec 08, 2006 | Frigidaire FRS23R4C Side by Side...
Refrigerators Logo
59 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
