Question about Dryers
Gas propane gas to natual gas any diff
  • 254 Answers
Yes you need to convert the machine for the right gas.
Posted on Jul 10, 2008
Convert from lp to ng
orifice sizes will increase since goin from lp to nat gas.......to convert appliances you will need diff gas valves, nat gas and propane will have diff pressures
Dec 05, 2013 | Heating & Cooling
Maytag neptune gas dryer Model # P MD64000AWW converting to propane and would like to convert back to natural gas
NEED TO CHANGE GAS ORIFICE. THEY ARE DIFF. BETWEEN NATURAL GAS AND PROPAIN THATS ALL YOU HAVE TO DO.
Oct 06, 2013 | Maytag Neptune MCG8000AW Gas Dryer
I have a Coleman Natual gas forced air Model 7970C856 The poilet light stays on but furance burner does not kick on. What could it be?
Hello, this could be a problem with the thermocouple or gas valve. Start by replacing the thermocouple since it is very inexpensive, if that does not get it going sounds like the gas valve will need to be replaced
Oct 04, 2011 | Coleman Propane Forced Air Heater...
I have wall mounted Vulcan gas heater (made around 1970), with Single, flued, Currently connected to LPG gas bottle. Will be connnecting to natual gas shortly. Do i need to get a converter from LPG to...
there is a difuser where the gas comes out and there is a different part for each type of gas. the gas regulator should stay the same you will need a new difuser. dont know if i spelled it right but that is what it is
Mar 26, 2011 | Heating & Cooling
BOUGHT A STOVE FROM A FRIEND, HE USED PROPANE I HAVE NATUAL GASS. HOW DO I SWITCH OVER.
Generally to accomplish this you need to change the orifice(s). The two gasses supplied at different pressures requiring the orifices to be changed if at all possible
Mar 12, 2011 | Magic Chef Microwave Ovens
Turbo STS grill, converting to propane from natual gas, orafices arn't available from Turbo
I would like to convert my Turbo STS grill from propane to natural gas. Where can I find the correct sized orifices?
Jun 17, 2010 | Barbeques Galore Turbo STS 4-Burner with...
New BBQ chaged from propane to NG
Hello. The conversion of any gas appliance usually requires changing orifices, regulator and burner. Then once those changes are made you can adjust the gas flow. The difference in the orifices is this.
Natural gas orifices are larger than liquid propane orifices simply because the gas pressure for the natural gas is lower.
I would double check to be sure that you have installed the correct orifice. Also, you can adjust the amount of gas by turning the orifice in or out, using that socket.
Please call the uniflame technician directly if you still have a problem 800-762-1142 Joe
Mar 11, 2010 | Uniflame Corporation LP Gas Outdoor...
Convert propane dryer to natual gas
You need the NAT gas orifice and the stem under the cap on the burner needs flipped over
Jun 08, 2009 | Whirlpool GGX9868J Gas Dryer
Dryers Logo
62 people viewed this question
Top Dryers Experts
