Question about Panasonic PanaFax UF-8000 Laser Fax
Broadcast fax How to set up and add fax numbers to an existing braodcast group
How to delete the memories of one-touch number and name?
Posted on Jul 21, 2008
How do I set up speed dialing on my HP Officejet 5740
While "Speed Dialing" or "Speed Dial" is listed in its fax specifications on some sites, it appears to be a mislabeled categorization of its group fax feature as HP's manual makes no other mention of it--save to say, the "fax to multiple numbers" (or multiple recipients) feature. There does not appear to be a speed dial list, but there is a phone book feature for adding contacts (individual numbers) & groups. (The following is detailed in a more explanatory way on pages 65-66 of the user's manual (http://support.hp.com/us-en/product/HP-Officejet-5740-e-All-in-One-Printer-series/6617253/model/6617254/manuals?cc=us&lang=en).
1. From the printer control display, touch Fax.
2. Touch Send Now.
3. Touch the telephone symbol to access its phone book feature.
4. Touch the person symbol for a phone book contact; or touch the multiple person symbol for a group of phone book contacts.
(Note: Contacts should be established before any of these could be added to any group.)
5. Touch + (plus sign) to add a contact/group; or touch the gear symbol (edit) to edit/delete a contact/group.
6. Touch Name.
7. Changes to contacts/groups:
•Adding a contact/group: type the name, & then touch Done.
••Adding a fax number to a contact: Touch Fax Number, enter this contact's fax number, & touch "Create".
••Adding a contact to a group: Touch Number of Members, select all of the contacts to add to this group from this printer's phone book, & touch Select followed by touching "Create".
•Editing: Select the contact/group name, & then touch Done. Then...
••Editing a Contact: touch Fax Number, enter the fax number, & touch Done.
••Editing a Group: touch Number of Members & deselect the contacts to remove from this group or touch + (plus sign) to add contacts to this group. Then touch Done.
•Deleting a contact/group: Select the name, & then touch Delete followed by touching Yes.
Feb 25, 2015 | HP Office Equipment & Supplies
How do I send one fax to multiple receipents?
you need to set up a group to send to. So if the group is always changing this may not help much.
Groups allow you to send the same fax message to multiple numbers (broadcasting). You can store the Groups on your One-Touch keys or SpeedDial locations and then broadcast by pressing a One-Touch key and Fax Start or by pressing Search/Speed Dial, the three digit location and FaxStart. First, you will need to store each fax number you wish to includein your Group as either a One-Touch or Speed Dial number. Then, you can combine these numbers into a group. Finally, you can have up to six Groups, or you can assign up to 131 numbers to one large Group. Each Group uses one One-Touch key or Speed Dial location. To set up a Group, please follow these steps:
1. Press Menu, 2 (Fax), 3 (Set Auto Dial), 3 (Setup Groups).
2. Press the One-Touch key on which you wish to store the Group or pressSearch/Speed Dial followed by the three-digit Speed Dial location where you wish to store the Group. The LCD will read SETUP GROUP:G0 ENTER & SET.
(from the Brother manual)
Nov 18, 2010 | Brother IntelliFax-4100e Fax
I don't understand the one touch dialing on the HP 2140
Hi Suzeo. Many HP fax machines have the function you are requesting. It is called the broadcast fax feature. Look in your owner manual for this feature. If I knew which model you have I would have researched it for you. IF by chance, your machine does not have this feature, it would be money well spent to replace your current machine with one that does. Depending on how many pages the daily fax is, I am estimating that you are spending an hour or more each day on this task. J.
Jul 03, 2010 | HP Office Equipment & Supplies
Cant install fax software for lexmark x5495 aio printer.
1. Unplug the printer from the PC
2. Uninstall all the software related to the All-in -One ( that is on the PC)
3. Connect the All-in-One again then follow the software instructions for reinstalling the printer.
From the instruction manual:
Sending a fax
Entering a fax number
1 From the control panel, press Fax Mode.
2 Enter a fax number using:
The text box Enter a fax number using the keypad.
Notes:
• You can include a calling card number as part of the fax number.
• Enter a maximum of 64 digits in a fax number.
• Press Pause / Redial to insert a three-second pause in a number you
are entering to wait for an outside line or get through an automated
answering system.
Speed Dial or Group Dial a Press Phone Book.
b Enter Speed Dial and/or Group Dial numbers.
• Press or repeatedly until the Speed Dial or Group Dial
number you want appears.
• Use the keypad to enter the number of the Speed Dial entry (1–
89) or Group Dial entry (90–99).
Notes:
• For instructions on how to add Speed Dial or Group Dial numbers
using the computer, see “Setting up Speed Dial” on page 118.
using the control panel, see “Using the Phone Book” on
page 108.
3 If you want to send a fax to a group of numbers (broadcast fax):
a Press .
b Repeat step 2, using any combination of the previous methods, until a maximum of 30 fax numbers have
been entered.
Sending a fax using the software
You can scan a document to the computer and then fax it to someone using the software.
1 Load an original document facedown in the Automatic Document Feeder (ADF).
2 From the desktop, double-click the Productivity Studio icon.
3 From the right pane of the Welcome Screen, click Fax.
4 Select the Document option.
5 Click Start.
6 Enter the recipient information, and then click Next.
Note: A fax number can include up to 64 numbers, commas, periods, spaces, and/or these symbols: * # + - ( ).
Faxing
103
7 Enter the cover page information, and then click Next.
8 If there are any additional documents that you want to send with your fax, add these now, and then click Next.
9 To send your fax:
• Immediately—Select the Send now option.
• At a scheduled time:
a Select the Delay sending until option.
b Set a time and date.
10 If you want a paper copy of your fax, select Print a copy of your fax.
11 Click Send.
Sending a fax using the control panel
1 Make sure the printer is on.
2 Load an original document facedown into the ADF or on the scanner glass.
Note: Do not load postcards, photos, small items, transparencies, photo paper, or thin media (such as magazine
clippings) into the ADF. Place these items on the scanner glass.
3 From the control panel, press Fax Mode.
4 Enter a fax number or press Phone Book to select a number from the Speed Dial or Group Dial list. For more
information, see “Entering a fax number” on page 103.
Note: To set up Speed Dial, see “Setting up Speed Dial” on page 118.
5 If you want to send a fax to a group of numbers (broadcast fax):
a Press .
b Repeat step 4 and press until a maximum of 30 fax numbers have been entered.
6 Press Start Color or Start Black.
Sending a fax while listening to a call (On Hook Dial)
The manual dialing feature lets you dial a telephone number while listening to the call through a speaker on the
printer. It is useful when you must navigate an automated answering system or enter a calling card number before
sending your fax.
2 Press .
3 Press or repeatedly until On Hook Dial appears, and then press . You can now hear the dial tone of
the telephone line.
4 Enter a fax number. For more information, see the related topic, “Entering a fax number.”
Note: Press the keypad numbers to use an automated answering system.
5 Press Start Color or Start Black.
Faxing
104
Sending a broadcast fax at a scheduled time
You can send a fax to a combination of up to 30 people or groups at a time you choose.
1 Load an original document facedown into the ADF or on the scanner glass.
2 From the control panel, press Fax Mode.
3 Press .
4 Press or repeatedly until Delay Fax appears.
5 Press .
6 Press or repeatedly until Delay Until appears.
7 Press .
8 Enter the time you want to send the fax.
9 Press .
10 If the printer is not set to the 24 hour mode, press or repeatedly to select AM or PM.
11 Press to save your settings.
12 Enter a fax number, or press Phone Book to select a number from the Speed Dial or Group Dial list. For more
13 If needed, repeat step 12 and press until a maximum of 30 fax numbers have been entered.
14 Press Start Color or Start Black.
Note: At the designated time, the fax numbers are dialed and the fax is sent to all of the designated fax numbers. If
the fax transmission is unsuccessful to any of the numbers on the broadcast list, the unsuccessful numbers will be
dialed again.
Receiving a fax
Receiving a fax manually
1 Make sure the Auto Answer light is off.
2 To receive the fax if you have not set up a manual answer code:
• Press Start Color or Start Black.
or
• Press * 9 * on the telephone after you answer it and hear fax tones.
3 To receive a fax if you have set up a manual answer code, enter the code on the telephone after you answer it
and hear fax tones.
Note: For information on how to set up a manual answer code, see the related topic, “Setting a fax manual answer
code.”
4 Hang up the telephone. The printer receives the fax.
Faxing
105
Apr 15, 2010 | Lexmark X5495 All-in-One &USB...
Group code
I believe what you want is at the bottom of this list.
If you frequently send faxes to the same group of telephone numbers, you can assign these numbers to a group.
Only Speed Dial and One Touch numbers can be assigned to a group. A maximum of 25 Group Numbers (WorkCentre Pro555) / 50 Group Numbers (WorkCentre Pro575) can be assigned (in the range 1-1999). Preset group numbers can also be used for polling.
The following information is included below:
  • Create a new group
  • Add numbers to an existing group
  • Delete numbers from an existing group
  • Delete an existing group
To print the Group Phonebook, see the Related Items below for additional information.
Create a new Group:
  1. From the Standby Mode, press the [Menu] (up arrow) button on the Control Panel, then press [3], [3].
  2. Use the numeric keypad to enter the Group Dial number (1-1999) you want to assign to this group.
  3. Press the [Enter] button. The screen will display a name.
  4. Use the numeric keypad to enter the Group Name (20 characters maximum), then press [Enter].
  5. Press the One Touch button you want to include in this Group, or enter the Speed Dial number, then press [Enter].
    NOTE: The One Touch and Speed Dial numbers must already be programmed. See the Related Items below.
  6. Repeat step 5 to enter additional numbers.
  7. When you have entered each number you want to include in this group, press [Enter].
    NOTE: Group Transmissions are easier if a group is linked to a One Touch button.
  8. To assign this group to a One Touch button, press the One Touch button. To skip this step, press [Enter].
  9. Press the [Exit] or [Stop] button to return to the Standby Mode.
To add numbers to an existing Group:
  4. Press [2] to modify this group.
  5. Use the numeric keypad to enter a new group name, then press [Enter], or press [Enter] to retain the old name.
  6. Press the One Touch button you want to include in this Group, or enter the Speed Dial number, and then press [Enter].
  7. Repeat step 6 to enter additional numbers.
  8. When you have entered each number you want to include in this group, press [Enter].
  9. Press the [Enter] button.
  10. Press the [Exit] or [Stop] button to return to the Standby Mode.
To delete numbers from an existing Group:
  6. Press the One Touch button you want to delete from this Group, or enter the Speed Dial number, and then press [Enter].
  7. Press [1] to delete this number.
  8. Press [Enter] to delete the number, or press the [Exit] or [Stop] button to exit without deleting number.
  9. Repeat steps 5 through 7 to delete additional numbers.
  10. When you have deleted each number from this group, press [Enter].
  11. Press [Enter].
  12. Press the [Exit] or [Stop] button to return to the Standby Mode.
To delete an existing Group:
  2. Use the numeric keypad to enter the number of the Group you want to delete, then press the [Enter] button.
  3. Press [1] to delete the group number.
  4. Press the [Exit] or [Stop] button to return to the Standby Mode.
elem_1_spacer.gif Related Items:> See AlsoHow To Print and Read the Group Phonebook Report
> See AlsoHow To Modify the Default Resolution and Contrast Settings
> See AlsoHow To Assign / Modify Speed Dials in the Phonebook
Dec 11, 2008 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Faxing to several numbers
Sending Broadcasting Faxes:
Using the BROADCASTING BUTTON on the control panel you can use the broadcasting fax feature. 1. Load the document(s) face down into the ADF. 2. Adjust the document resolution to suit your fax needs.Press BROADCASTING on the control panel.4. Enter the number of the remote machine using the number keypad. 5. Press enter to confirm the number.The display ask you to enter another fax number to send the document. 6. To enter more fax numbers, press 1 to select "YES" and repeat steps 4 and 5. You can add up to 10 destinations. NOTE: You cannot use group dial numbers for another fax number. 7. When you finish entering fax numbers, press 2 to select "NO" at a "ANOTHER NO" prompt.
The document is scanned into memory before transmission. The display shows the memory capacity and the number of pages being stored in the memory.
The machine begins sending the document in order of the numbers you entered..Hope this helps
Oct 08, 2008 | Samsung SF-560 Plain Paper Laser Fax
Is there a way to program it to fax to a group of numbers at one time
You can use the "Broadcast " feature to send one fax to up to 112 numbers listed in your speed dial. To set this up:
  1. Insert the original into the ADF.
  2. Press Quick Scan/Reports. The display should show how much memory is available.
  3. Enter the One-Touch or Speed Dial numbers for the recipients you want to send to (one after the other). You can also setup a group dial number.
  4. Press Fax Start. The machine will scan the document into memory and then dial all the numbers you've entered. If any are busy it will attempt to redial.
  5. Press Stop/Exit at any time to cancel the broadcast.
If you need further instruction on how to setup group or speed dial numbers, Brother provides the user manual online.
Hope this helps!
May 15, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Panasonic PanaFax UF-8000 Laser Fax Logo
75 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
