I am not sure how to get my modem to work on the main pc it works on the laptop?
  • 781 Answers
If it is external modem you need to install drivers for it to main pc.
if main pc has internal modem same applies drivers needed search google for them
Posted on Jul 10, 2008
Help, my dstv doesn't work since yesterday afternoon. The screen is black and there is no sound. Tried to reboot but doesn't work. Anyone who can help?
Try rebooting with your main modem. Just turn the modem off, count to 10 and then turn it back on again. You might also call the tech line for your service provider for advice.
Mar 10, 2015 | Computers & Internet
For no reason, my HP laptop stopped working the internet. It works perfectly otherwise. I hard connected the laptop directly to my wirelessouter as well as my modem, still it will not connect to internet.
Connectivity issues can be many.
I would start my first rebooting the main modem.
Once that is up, reboot the wireless router.
Once that is uo, reboot the laptop.
Try to connect.
If that does not work, eliminate the wireless router and connect the laptop directly to the modem via Ethernet cable and reboot the computer again and see if it works. If it does, then it is something with the wireless router. If it doesn't, i would contact the provider so they can verify that they can see your modem on their network. If they cannot, they will advise you further (hardware/cabling issue). This is all assuming that nothing has been changed on any settings of the laptop, router or modem.
Jul 21, 2010 | HP Pavilion dv6000z Notebook
My laptop as 5534-1096 did't recognise the modem
Hello pothapalu,
Assuming this is NOT a dsl or cable modem, try the following:
The modem settings can be managed from the control panel as follows:
•Click Start (lower left-hand of screen)
•Select Control Panel
•Click Phone and Modem Options
•Select the Modem Tab
•Select the Modem Name and click properties.
•Check the properties settings and make sure the Modem is enabled and working ok.
-Device Status should be: 'This device is working properly.'
Also, review the other tabs in the properties page (General - Modem - Diagnostics - Advanced - Driver - Details).
Make a note of any setting before changing it.
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 06, 2010 | Acer Aspire One PC Notebook
Just got new modem and router, main PC on home
Right-click the network connection and click REPAIR, see if that resolves.
If you are getting a Valid IP address (192.168.x.x) then that should help. If you are getting a (169.254.x.x) APIPA address, then you are not getting network connectivity. That may involve the Wireless Security Key, or the security protocol (If using WPA the card in a 1100 may not support that protocol)
Dec 17, 2009 | Dell Inspiron 1100 Notebook
Do laptop computers have modems to connect with a dial up service
Yes, some laptops have a modem, some don't. Just make sure when you buy. You will probably want to know also if the modem supports data/fax.
Nov 06, 2009 | Acer Aspire 5500 5570-2609 Laptop
My wireless hp says router cannot find host name
Double check your physical connection. It should be this way
Modem > connected to Internet Port of the router
PC > connected to port 1
Laptop > can be wireless
Now you must power cycle your router and modem. Turn off router first then modem. Wait for 30 seconds. Power on modem first, then the router. You must configure the wireless settings on your laptop it doesn't connect automatically.
Jun 14, 2009 | D-Link DIR-625 (790069292637) Wireless...
Problem setting up home network with d-link des-1105. Windows Vista on main PC & Windows XP on laptop. Presently, I have ethernet cable connected on main PC to d-link and usb cable connected to laptop & to...
A router is basically a mini-computer that splits up one internet connections to 4 (or whatever # of ports you have).
Basic Connections to a router:
A Router requires a internet connections, so your broadband modem must connect to the WAN port (theres only one) of the router DIRECTLY. Then Ethernet cables go from the router to the computers on the LAN ports. Don't do something weird like connecting your internet to your computer then your computer to the routers WAN port, it'll most likely mess up.
Once you have connected your router like this, it should work.
If your modem only has a usb port, I have no idea how to make that work out. Sorry. Try getting a new modem from your ISP, or check if your modem does have a ethernet port, if it does just connnect that to the routers wan port.
Also computers should not interconnect with each other with use of a router. Thats what the router is for. Everything gets connected and split up at the router, nothing connects to anything else but the router, basically.
Feb 26, 2009 | D-Link DIR-625 (790069292637) Wireless...
Getting set up
You should setup connection like this:
From ADSL modem to LinkSys Router and then your PC/Laptop should have a wireless card. It will work fine
Jan 27, 2009 | Linksys Wireless-G WRT54G Router
Belkin N Modem Router If main PC which is ethernet wired to the modem router is swtiched off, laptops cannot access the internet. Does this mean that the PC to which the modem router is connected has to...
it will as long as the modem/router is connected to a phone line, instead of the pc, the only cable connected to the pc should be a ethernet cable; or you have the pc networking set that it connects via another pc instead of through a gateway, re run the wireless network wizard.
Sep 05, 2008 | Belkin Computers & Internet
Belkin router and modems
i would suggest returning the router and/or purchase a modem router, as it does away with all the connection problems and the need to click dial to connect as a modem router is always on and does not require a main pc to be on. It will also probably be cheaper than buying a seperate modem.
Sep 13, 2007 | Belkin (F5D9230-4) Wireless Router...
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
