Question about Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-E50A10 When I turn on the TV, I have no picture,and green light contiunes to flash
  • rmgpmed Aug 03, 2008
    I have the same problem but the tv will come on after 20 seconds and stay on for 15 seconds, then repeat the process over and over. I posted problem on forum.
  • 320 Answers
Replace the lamp, sounds like a weak or old lamp. Use an original Sony, the replacement lamps are unreliable
Posted on Oct 18, 2008
I need help. My Sony 50 inch tv is a 2006. The warranty ran out in June 2010. I heard a pop and then it shut off. Now the green light flashes 25 times and turns to the red lamp light. I can't reference...
Pop sound was broken lamp in tv, replace lamp to solve tv issue.
Please recheck model number as KDF-50EA10 seems invalid/ incorrect model number and nearest match is KDF-E50A10
If model number is KDF-E50A10 then required lamp part number is as follows...
F93087500 ... LAMP BLOCK ASSY XL-2400
and available with Sony Accessories Store for $200
Let me know if you have addition question or tv model number is other than above said (KDF-E50A10).
Mar 10, 2011 | Sony Televison & Video
The tv will turn on but no the screen wont. and
Replace the lamp would be the first thing to try. Lamp door switch on this model is notorious for going bad. If you replace lamp and still won't turn on jumper door switch. If you take off back you can see switch board.
Nov 21, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Why does my sony vega keep turning it self off and back on again
Im guessing it is doiong this about every 30 seconds or so. Im also guessing that when the sound and picture go out, the green standby light flashes until the set comes back on. If this is the case, mine was doing the same thing. I did a bunch of research. I replaced the lamp and the tv is like new, no more problems. The lamp light on the front of the set does not come on because the lamp/bulb is noot burned out all the way. I bought my lamp from , the best price I found.
Oct 13, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
Sony KDF-E50A10 50 in. HDTV stays on for 25 - 30 minutes then shuts off by itself power stand by light flashes green and turns back on in about 20 seconds by itself. can you help?
Hi, Lamp of TV getting weaker and requires replacement. This shut off by itself will increase day by day until you put new lamp in TV. Always Buy Sony original lamp and avoid aftermarket/ cheap lamp for TV safety.
Jun 09, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-E50A10 No Picture
4 times blink error shows that any FAN is not running in TV as there are 4 fans in this TV.
Please check fan connectors and make sure all are plugged securely.
Feb 13, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-E50A10 Green picture.
For BnrMan213,
I believe your issue with Light engine.(KDf-E50A10) If you have warranty on this unit contact seller.
Good luck
Same unit different problem
Customer replaced Lamp ***'y still unit bliks, there is two reason.
1.if your lamp door not closed properli it will blink. for ballast ***"y fires the triger to on the Lamp? if not your old lamp is good repalce Ballast..
Good Luck
Jul 31, 2008 | Samsung HCN4226W 42" Rear Projection...
No Pricture just a flashing light
Sounds like it MAY be a bad lamp. It could also be that the main microprocessor is not fully initializing.
Jul 10, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-E50A10
Have the Ballast (power supply to the lamp) replaced.
Jun 23, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-E50A10 50 in. LCD HDTV Logo
338 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
