Question about Canon imageRUNNER 400S Copier
PAPER JAM IN AN CANON IMAGERUNNER 400S COPIER. IT SAYS TO LIFT FRONT COVER AND THEN LIFT LEFT COVER. I DON'T KNOW HOW TO OPEN THE LEFT COVER.
  • Canon Expert
  • 1,326 Answers
Open the front door and do you have a sorter on it? If so, you need to move it away. The finsher has a bracket and right under the bracket there is a handle pull the handle up and find you will see your jamed paper. Also, look at the duplex area under the transfer unit. It has a green handle lift it up and maybe find a jam there. You may have found it by now
Posted on Jul 18, 2008
Halloo. Sir
I Have same problem about paper jam, but I cut the paper ,there's small pieces of paper stuck in that black box , I can touch it , but it's very small I can't clean it out ....Plz HELP ME
Posted on Oct 09, 2012
How to solve 2side paper jam its in continue but 1 side is working good...how to solve this problem? its ir 400 canon machine
open the front cover and clean the duplex rollers with alcohol and dry it.
Also, if you have stand for these copier, on the left side of the stand there is opening on top of stand where the copy is going when it copy second side, check for any opsticles in there.
Hope that helped
Aug 06, 2010 | Canon imageRUNNER 400S Copier
How to remove canon ir 400 paper feeder assembly
Why???? The unit comes out the right side of the copier. There are alot of screw to be removed. You can take the paper trays out and remove a paper jam and also replace the rollers. If the paper tray is not lifting? There is a lift gear that breaks and it is not easy to replace> I have over 20 years and it is not easy to do......
Jul 28, 2010 | Canon imageRUNNER 400S Copier
Canon machine message front cover is close but
there are switch behind the front door that are activated by the front cover. you may have a broken or missing actruator pin on the front door. look very carefully on the door for anything that seems to be missing. if ther is just use a piece of paper to actuate the switch. jaime
Jul 15, 2010 | Canon imageRUNNER 400S Copier
I have a paper jam and it says to open the front cover, put the front cover just shows the ink cartridges and there is no visible paper jam. how do i find the jam and remove it? It's a canon image...
The paper jam could be in three places.
First:
Open the cover of fixing section, its above bypass, and check for jamed paper
Second:
Open the transfer cover, these cover has handle and it goes by pulling toward you, and check for jamed paper.
Third:
In hight of first paper cassette, on left sideway of copier, beaneath the bypass are small door, open it and check for paper jams. Be sure that you closed them properly because if they arent closed the check printer cover message will arrise.
Hope that helped
Jul 07, 2010 | Canon ImageRunner 1600 Copier
I get a paper jam every time I try to manually make a copy on the second side of a copy. First side no jam. Help. Derek
hai,
Open the leftside lower cover (below the dlivery door).
i think duplex revesing area have old copied papers. if have remove it, then
Check the paper passing rollers dirt or demage, clean it, hold properly
then clean the sensor of paper reversed area.
best of luck
May 23, 2010 | Canon imageRUNNER 400S Copier
The machine indicates paper jam on all areas but no paper jam exists
open all of the paper cassettes and make sure no paer is stuck ther. then with the cassttes open. open and close all of the covers. it is possible you have a bad sensor saying a false jam
Jan 25, 2010 | Canon imageRUNNER 400S Copier
Trying to find documentation for the Canon Imagerunner 400S. Need to know how to add toner?
Did you look on the box the toner comes in? Also, when the copier needs toner, the display panel will walk you through the steps of how to install a new toner. The hardest part is getting the toner cartridge OFF. You need to press the front of the developing unit right under the blue cover on the front. The Black piece will push in to release the toner cartridge. Good Luck...
Jul 07, 2009 | Canon imageRUNNER 400S Copier
I have a canon ir 400 the machine shows close the front cover but it is already close?what is the problem?
Try to open and closed the front door several times,If the left cover and the front door are closed properly and still showing "close front door" most
probably the internal contact of door switch are not good , door switch replacement is needed
Jul 06, 2009 | Canon imageRUNNER 400S Copier
What is Front Cover?
This is the cover which is facing you, pull it without opening any screw, you will see where to pull or read the instruction manual. Even when replacing toner you have to open this cover.
Mar 23, 2009 | Canon ImageRunner 1600 Copier
Paper Jam
Did you open the smaal door on the lower left to try to remove it from there.Or is it stucked in the fixing area.
Jun 07, 2008 | Canon IMAGERUNNER 6570 Copier
Canon imageRUNNER 400S Copier Logo
191 people viewed this question
old marine
old marine
