Question about Panasonic Panafax UF-560 Plain Paper Laser Fax
Panafax UF 560 Battery
Do not have owner's manual, had power outage and have to keep resetting data, was told maybe a battery needs to be replaced, can you tell me where it would be?
  • krisv Aug 12, 2008
    I can not find a replacement battery for my Panafax UF560.
  • DF5FD Oct 04, 2008
    When ever AC is interupted, all settings have to done again!
    Are any service manuals out there?
    Genius:
  • 2,120 Answers
Upgrade your fax machine. The battery is almost impossible to replace without damaging the main board.
Posted on Aug 30, 2008
  • greenfire88 Jun 22, 2011
    The battery is easily replaced. It is behind the panel where the telephone line connects to the fax, at the back of the fax. It is in the middle of the board when you remove the small back panel - one screw only. I have never seen this type on battery, so finding another might be more difficult than replacing it. On my UF-560-AL it is green and about the size of my small (male) finger nail in length, width and height (approximately). Obviously disconnect all power, turn off the machine and you should also have a anti static line connected.
  • rardin Sep 22, 2011
    The NiCad battery is easily accessible, but may not be easy to replace, even if you can locate a suitable replacement battery. It feels like it might be soldered into the socket.
Is it possible to retrieve a journal transaction from 1 year ago with the Panafax UF-560? The manual states the last 100 entries. Our receptionist is trying to prove she sent a fax during that time frame....
Sorry but no, the unit does only keep the last 100 journal pages in its transaction log. This usually covers a time span of 2-5 days only on a machine used in a business environment.
Buddy
Corporate Computer
May 14, 2010 | Panasonic Panafax UF-560 Plain Paper Laser...
Panafax UF-560 How do I change the date and
Press
Function
71
set
key in date and military time
set
stop
Nov 24, 2009 | Panasonic Panafax UF-560 Plain Paper Laser...
Panafax UF-885 flashing UF-885 (AU) message
yes there is a batt on the board it will need to replaced i have seen this many times
Nov 18, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
We are getting Error CODE 021 on our fax machine Panafax UF-560 and can't find the owners manual to fix it...can you help?
Error code 021 indicates a bad fuser but in some cases, the error can be reset. To attempt a reset, do the following:
  1. Remove the toner cartridge and close door back up.
  2. Power down the fax (switch is on the back side lower left) for 5-10 seconds.
  3. Power on the fax and see if the 021 code is gone.
  4. Re-insert toner cartridge
If this doesn't work, there's one other thing to try prior to calling a technician.
1. Push the function button
2. Push 7 on the key pad
3. Push Monitor button 4 times (it will only beep at you)
4. Push * on key pad
You should now see the service menu option
5. Push 7 on the key pad
6. Push "Set" button
7. Push down arrow button once
You should now see the fuser reset option
8. Push "Set" button
You will be prompted for 1 for Yes 2 for no
9. Push 1 on key pad.
You should receive confirmation that the reset is *COMPLETE*
10. Push Stop button until back to the main screen
11. Power down the fax
12. Wait 5-10 seconds.
13. Power on the fax
If this doesn't work, a service call will be needed to replace the fuser. I do hope this fixes your problem.
(reset information courtesy of Eliot at howtomendit.com)
Nov 12, 2009 | Panasonic Panafax UF-560 Plain Paper Laser...
How to clear memory on Panafax UF-560 ?
Press
Function
7
monitor key slowly 4 times
6
scroll down to SHIPMENT SET
set
wait for the machine to initialize.... 3 mins.
Oct 09, 2009 | Panasonic Panafax UF-560 Plain Paper Laser...
Replacing the LCD battery on a Panafax UF-885
Open up the document feeder by pulling straight up.
You will see a white tab sticking out of the black base.
Push FIRMLY towards the rear with your thumb.
The battery is a CR-2032 as printed on it.
Feb 02, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax uf-560
To reset in service mode is function, 7, monitor x4, * key. This must be done rapidly. Scroll to ram initialization(#6), set, scroll to shipment set, set, do not reset counter, set. let it reset and then power cycle unit.
May 14, 2008 | Panasonic Panafax UF-560 Plain Paper Laser...
Change date/time on panafax 560
press function 7, user parameters, use arrow keys to sccroll through and set time date, ID, logo etc press start or set to confirm
Dec 10, 2007 | Panasonic Panafax UF-560 Plain Paper Laser...
Panasonic Panafax UF-560 Plain Paper Laser Fax Logo
733 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
