Question about Whirlpool Washing Machines
Cabrio: Purchased on 11/18/06 600$ to fix it??? Have called and e-mail a couple of times about it not working right! Finally got a Tech. said he had seen F7 but never a F51, A two year old washer with your company name should last a lot longer. Surley something can be done to help in the matter! I know you are the Tech. but can not find a e-mail for just comments. Thanks! Pat Judd e-mail cannjudd@cox.net
  • 254 Answers
F51 on Cabrio is a bad RPS sensor part retails for about $76.00
Posted on Jul 10, 2008
Have f1 code at times and lights around knob of settings flickers
Hi
Thanks for using FixYa. Error code F1 indicates primary control failure and to resolve this you'll have to replace the machine control assembly. Yes you are right, this error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
We are having the F1 problem everyone else seems to be having. However there is NO serial number tag in our washing machine. We purchased it at Lowe's; I have called them and they don't keep serial...
As a service tech I ran into this several times.I do not know what the law is but I know as a service tech we were not allowed to perform any warranty work on any unit that did not have a valid serial number.In all my cases the customer went back to where they purchased the units and demanded that they make it right ,and in 90% of the cases they exchanged the units (but not without some dissagrement) obviously you need to work this out this is not a cheap repair
Sep 17, 2010 | Whirlpool WTW6400SW Cabrio Washer
Setting f1 code all the time
Hi
Thanks for using FixYa. Error code F1 indicates primary control failure and to resolve this you'll have to replace the machine control assembly. Yes you are right, this error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Randomly flashes F1 during various stages of washing & machine stops working
Hi
Thanks for using FixYa. Error code F1 indicates primary control failure and to resolve this you’ll have to replace the machine control assembly. Yes you are right, this error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Lid will not lock and just click click click (trying to lock but can't)..then "lid" is displayed and then f1.. sometimes I can (after trying different things finally get it to lock) Something like this...
Hi
Thanks
Rylee
Aug 26, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a cabrio purchased in dec of 2007.. model
Hi
Thanks for using FixYa. Yes you are right you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Error F1 means primary control failure and to resolve this you’ll have to replace the machine control assembly. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 05, 2010 | Whirlpool WTW6400SW Cabrio Washer
F1 error code on cabrio washer
Call Whirlpool at 800-253-1301 in USA. There is a recall on this washer for the F1 code. Service call and parts are free. I just did it today.
Jan 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio Washer LD error code
Is there water in the bottom of the tub? If yes then open back of washer and remove drain pump (on left side) and pull off of tub and clear whatever is blocking its impeller.
If the water is all gone and drained but pump stays on for several minutes and then gives "LD" fault then open back and check the small clear tube that is attached to the tub. Make sure is not blocked with debris and check tube and tub for anything that could block the small clear tube. If these are ok then remove 3 screws in back of the control panel, pull open control panel and check the clear tub all the way up from the tub to the washer controller board (computer) make sure it is not kinked or disconnected. If not then the problem is most likely the pressure sensor on the (computer). This unit will have to be replaced.
You can test the sensor by doing the following: 1. When the "LD" fault comes on start by pressing the pause button. then pull the clear tube off of the computer board. Then attach a tight fitting drinking straw over the sensor. Press the start button and wait for 60 seconds - If the washer does not start the spin cycle on its own after the 60 seconds then **** on the drinking straw that you attached to the pressure sensor earlier. The sucking action should reset the sensor thus telling the computer that the water is drained and it will start the spin cycle. Just remember if you have to do this to get the washer to spin - that means the sensor is damaged most likely from moisture traveling up the tube over time. The computer board will need to be replaced. I believe it costs $205 without shipping. Hope this helps.
Oct 13, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Voice mail indicator light is always on
I recently changed my number and when I did, I received the same problem. It appears that AT&T didn't add the Message Indicator Light service to my new number. Once they did, the message light works!
Try calling your phone service provider and asking if they have a Message Indicator Light function.
Apr 28, 2008 | RCA 25414RE3 Corded Phone
Washing Machines Logo
132 people viewed this question
Dan Webster
Dan Webster
prem mathew
