Question about Frigidaire Refrigerators
Model FRT18G4AW2 is leaking - Frigidaire Refrigerators
  • 254 Answers
You possibly have glogged defrost drain line.
Posted on Jul 10, 2008
Water leak from model 110 washer
Good Afternoon Doris, thank you for your post!
I understand your washer model 110 is leaking. However, it appears above-listed model number is invalid. The serial tag, which lists your model number, is typically located on the upper front, as you open the door.
Is your washer leaking through the back, from the side, underneath? With this information I can better address the issue at hand. Thank you!
Nov 25, 2013 | Frigidaire ATF6000ES Front Load Washer
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Jul 09, 2013 | Bosch Nexxt Platinum WFMC640SUC
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Jul 11, 2012 | Whirlpool Refrigerators
1. Water is leaking out from the bottom of the machine. 2. Also, wanted to know if you are suppose to manual pipe in water for this model........................thank you.............ong
The first part is that you need to check at the following for leaks.
1. Check for leak from the inlet due to poor water connection. check leak at the inlet valve.
2. Check for leak from the tub.
3. Check for leak from the drain pump/valve or the drain hose.
The second part is not clear but a connection for water and an outlet for drain is needed.( make/model not seen.)
Feb 19, 2011 | Washing Machines
My model 603 filter pump leaks at the top under cap
It could be the o-ring on this model. There is a seal on these pool filters that looks like a rubber ring inside the lid. You might need to replace this ring if your pump is leaking here.
Apr 30, 2010 | Intex 2500 Gal Easy Set Swimming Pool...
Kenmore model is leaking on full load but not
Leak maybe coming from the tub (higher level water) need to take the shell off the machine to see where exactly it is leaking from
Mar 25, 2010 | Washing Machines
EWDW6505GS0 Model Electrolux dishwasher 10 months in service has Error Code 01. Leak. What to do?
Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
Feb 14, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
Water leaks from bottom.
This model is OLD , time to get a new one
May 22, 2009 | Kenmore 42822 Front Load Washer
Refrigerators Logo
167 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
