I have a Panasonic tv model TH 42PZ80B; a Panasinic Blu-Ray dvd model DMP-BD50; a sky box (not as yet HD) and a Sony video SLV-SE 830G. I have a Satellite dish and a normal TV aerial. In the loft I have a splitter box that takes the tv signal to all rooms in the house. Sky programmes can be changed in the remote rooms via a mouse. In the room with the main TV I have two tv points - I assume one from the main aerial and one to the splitter box. I believe that I have connected the two scart sockets on the tv correctly and also the HDMI cable from the TV to the Blu-Ray. However I am having trouble with the tv aerial connections.Whilst I can obtain a picture on the main tv via both the areial and the sky box I not receiving any signal to the remote tvs. Can any one please advise me as to the aerial connections that I need to make. I have the input from the aerial and the output to the splitter box. I have one tv point on the tv -two on the video (one unmarked and one marked "tv") three on the Sky box ( excluding the cables from the dish) ( Aerial in; RF out1 and RF our 2) there are no aerial connections on the Blu-Ray. Any help would be appreciated.
  • Foston1 Jul 10, 2008
    Everything was working fine when connected to a non HD Sony tv and a non Blu-Ray DVD. I now have the HD tv and the Blu-Ray. Is there not a standard way of connecting a tv/Blu-Ray/Sky+ and Video? The only real complication that my system has over others is the splitter in the loft. However, as all the remote tvs were working before I swapped the tv and dvd I assume that I simply have some wires crossed - so to speak! I had to disconnect all the cables as I also needed to change the stand the positioning of which made it impossible to note where all the existing wires were coinnected.
    Am I to assume that in changing from a non HD tv and non blu-ray dvd to an HD tv and Blu-Ray coaxial cable connections are no longer a possibility? I had assumed that provided I connected the coaxial cables in the same configeration as previously (whatever that configeration is) the other tvs in the house would work as they did previously. Is this not the case?
  • 1,512 Answers
Hi, sounds like you have a setup where there is a loop from the aerial coming into the house(ist wall socket), then off to the splitter. The problem you will face here is the system you have is designed for analogue signals(RF) and with moving towards digital, and hdmi you can no longer distribute the signal to the rest of the system. You need to daisy chain the RF connections first sky box, then video, then TV, then back into the wall up to the loft and split to the other outputs. Try this and see how you go.
Posted on Jul 10, 2008
  • 1 more comment
  • Graeme Ross
    Graeme Ross Jul 10, 2008
    quick correction. Dont go into the TV with the RF, use the scart leads/hdmi into the TV. This means in the other rooms, you should still be able to get TV, Sky, and whatever you play on the video. The bluray will not make it into the system.
  • Graeme Ross
    You could also connect the 1st RF out off the sat box to connect to the TV, and the second out to the splitter.
  • Graeme Ross
    The standard way these days of handling the connections is with an AV amplifier. The TV will also have connectivity and switching for multiple sources, but it can be alot easier to use an amp for the switching and the TV becomes more of a monitor to the whole deal. The only problem remaining is getting the digital signal back into RF format to distribute to the rest of the outlets.
  • 2,071 Answers
Buy a sling for good multi connection;
Shopping results for multi connection sling box
  • LORETO LACARON
    LORETO LACARON Jul 10, 2008
    What devices can I connect?
    Slingbox� PRO
    • Basic Cable TV (from wall or Set-top Box)
    • Digital Cable Set-top Box
    • Digital Video Recorder (DVR) such as TiVo�, Comcast�, ReplayTV�,
      DISH� or one provided by your cable/satellite provider
    • DVD Player/Recorder
    • HD component support with resolution up to 1080i
    • Satellite Receiver such as DIRECTV� or DISH�
    • Video/Security Camera
    • Apple TV�
    • Windows
      Media Center
    Slingbox� SOLO
    • Basic Cable TV Set-top Box
    • Apple TV�
    • Windows Media Center
  • 6,487 Answers
You need to try and isolate the piece of equipment which is causing the problem.
You've already tried the aerial lead direct to the TV and this is OK.
Disconnect all scart leads and try the RF on its own.
Try the Aerial lead to video, then video to TV.
Try aerial direct to Sky box, then to TV.
Try just connecting the RF out from the Sky box to the TV (no aerial input), can you tune into a good channel 68 picture from the Sky box.
Then Try the VCR to the Sky box (no aerial input), see if you can tune into the VCR and Sky channel.
Hope that helps.......
Have a Panasonic TH-37PX60U tv - can I hook it up to a HD Satellite receiver - have a Bell hd but don't get any reception
Your plasma tv will display HD content when you connect an HD source (Blu Ray Disk, Sony PS3 / PS4 or Xbox 360, HD Cable Box, HD satellite, etc) via the TV's HDMI1, HDMI2, Component1, Component2 jacks or if you connect a UHF/VHF TV antenna (not cable box, etc.) to the "Ant" connector *and* you're close enough to a broadcaster with HD content to view.
Using any other input will produce only the lesser quality SD video signals. Review the manual - linked below - to help you connect the components you have.
http://service.us.panasonic.com/OPERMANPDF/TH37PX60U.PDF
May 13, 2015 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Panasonic TV does not play through surround speakers
so it is a connections problem I think. Check if video and audio cables are properly connected. Use color codes as your guide. Also from menu check if all settings are ok. Good luck
Dec 01, 2013 | Panasonic DMP-BDT220 DMP-BDT220
Got the error code upd ng on my DMP-BD60.....tried to upgrade firmware
Were you upgrading it over the network from the player? If you had network problems you can also download it to your computer nd burn it to a CD. then insert the CD into your player. Here is the link to the download: http://www2.panasonic.com/consumer-electronics/support/Video/Blu-ray-Disc-Players/Drivers-Downloads/model.DMP-BD60K.D#ts
Sep 15, 2010 | Panasonic DMP-BD60K Blu-ray/DVD Player
Panasonic dmp-bd50 blue ray player won't turn on. unit is getting power because optical out jack is blinking red.
There may be a service bulletin for the power supply on this model. Check with a Panasonic service shop.
Mar 21, 2010 | Panasonic DMP-BD50K Blu-Ray Player
We bought a house that came with a home theater system. We would like to connect a cable tv dvr box to it to be able to watch football games in hd on the big screen with the surround sound. The components...
1. Connect cable to cable HD DVR box, connect video out of cable box to Sony receiver TV video in, connect audio L and R out of cable box to Sony receiver TV audio in and connect TV out of receiver to video in of Panasonic projector 2. Connect Audio and Video out of DVD player respectively to DVD in of receiver. Good Luck :)
Oct 23, 2009 | Sony STR-DG800 Receiver
Cant record sky
connect it to the box with a SCART lead, select A1 or A2 with the channel up / down buttons and away you go
(select A3 if you use the phono connectors under the front panel)
Mar 01, 2009 | Panasonic DMRES20D DVD Recorder
Panasonic code
The code is 0051
on your sky remote press the TV button then
the select and Red button at the same time , hold until the led on the remote blnks twice
then press TV and enter code 0051 then press select and the remote will blink twice again to acknowledge the code
if you still have your Sky box manual all these details are in there also
im a sky engineer by the way , goodluck
Feb 15, 2009 | Panasonic TH-42PZ80B 42 in. HD-Ready...
Connections for DVD Recorder/LCD TV/ SKY PLUS
Connect the AV output of the Sky box to the AV input of the Panasonic combo.Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the Sony tv. Power up Appliances, and you should be OK.
Apr 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
206 people viewed this question
Top Televison & Video Experts
