Hi i turn on my pc and my monitor will come on and show windows and then it will go black.I tried it on another pc and it does the same thing can you tell me if i can fix this. thanks anns
    Novelist:
    Scholar:
  • 96 Answers
The fact that it fails on both computers tells you that the monitor is losing power. If your monitor uses an external power supply, you can replace that. If your monitor does not have an external power suplly (or brick), then you will most likely have to buy a new one, since monitor repairs cost more than just buying a new one anyway.
Posted on Jul 10, 2008
  • 31 Answers
OK :-) I am guessing that your monitor is corrupted and I think it's the monitor's problem not the pc's. I would recommend for you to borrow a friend's monitor and test it own on your pc to make sure if it's the pc's problem. If it works fine that means you should buy a new monitor.
Hi all,my AIO OneTwo M3851 is showing only black screen when pressing power button.the fan is running power light is lit.what maybe the problem?
Dear Rei Garcia,
Simplest thing first: Check the monitor. If it is ok, then try booting into "SAFE MODE" ...Hang on Rei...just did a search on "AIO One Two M3851" & initial hits talk about a LAPTOP? You have posted in DESKTOP PC's? IF it is a laptop, then try pluging a known good monitor into the video-out socket - ( usually a VGA output); if the second monitor works ok, then you need a new monitor. If the 2nd monitor doesn't work, then it looks like your graphics adaptor may be "had it"? GBU!
Dec 27, 2014 | Computers & Internet
Black screen just after boot window from USB
Sounds like either the monitor or video card inside the computer is bad. Try connecting another monitor to the computer. Borrow a monitor from a friend, neighbor, relative or co-worker and plug it into the computer. If the borrowed monitor displays ok, then your original monitor is bad. If the borrowed monitor does the same thing and not show a display then your video card inside the computer is bad.
May 09, 2012 | Computers & Internet
VA1703wb... Monitor beeps when I turn on the pc then goes black
Please read below and look at the pictures of failed VIEWSONIC nd othe monitor before try to DIY repair.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 06, 2010 | ViewSonic VA1703wb Monitor
Computer boots up shows windows xp and start up then monitor goes black if i switch it of and on it comes on for a couple of seconds and displays desktop then goes black have tried another monitor same...
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 14, 2010 | Computers & Internet
Monitor isn't working...shows desktop screen for a second then goes black.
reinstall windows ur screen resolution is not accepted by monitor
Apr 26, 2009 | Computers & Internet
Monitor went black in seconds
oboy, One thing to try is the flashlight test. and get backto me with your findings. Tell me, does this lcd show a nice display only for 1-2 seconds and then a black screen when connected to a fully booted PC with Windows desktop displayed? Shine a bright flashlight 1-2 inches from panel and tell me if you see the WINDOWS START Button at lower left of screen even though screen is black! Get back to me if you can. I'm louie12fix on fixya or lmistyrel @ aol.com BYE for now.
Apr 04, 2009 | Niko 1920W Monitor
I boot my cpu but the monitor doesnt show anything
Hi again.
The beep codes you describe are memory issues or failure, take the system memory out, clean the contacts and the slots with a clean, soft, dry paintbrush. Re-seat the memory firmly and try boot the PC again.
please post back with the results
Good luck and thanks for using Fixya!!
Feb 23, 2009 | Microsoft Windows Vista Ultimate Edition
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Emachines model 780 monitor comes on for one second then goes blank
CANNOT COMPUTE!!!! NEED MORE DATA! Is your monitor the problem or the computer? Try connecting the monitor to another computer. You can also try connecting a laptop with an external video adaptor to the monitor to test it.
Oct 12, 2008 | E-Machines eMachines Desktop PC
Still having trouble with EMachines T3882
I feel your pain. I finally moved my pc to a room with no windows! But seriously, try a different monitor first. See if you can borrow someone's to just try it before you do anything else. If that borrowed monitor works fine, then you know what the problem is. (Which I believe is the problem.) By the way, what started all of your problems?
Aug 20, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
David Payne
David Payne
