To charge your Apple Watch: Plug the Apple Magnetic Charging Cable, Apple Watch Magnetic Charging Case, or Apple Watch Magnetic Charging Dock into its USB power adapter. Plug the adapter into a power outlet. You can also plug the charging cable into a USB port.13 Sep 2016
The charging socket on you phone needs to be resoldered, OR the plug on the charging adapter is faulty and needs to be replaced. To determine which is faulty, use a different charger and plug it into your phone and move the charging plug to see if the it quits charging. If it quits charging then the charging socket on the phone needs fixing (re-soldering).
You do not need to unplug the large 9 pin beau plug in the rear or the smaller 3 pin molex plug when you charge the chair. Do not unplug them or you will not charge the chair.
Use your charging cord as you describe "plug it into the front, plug it into the wall and charge, then unplug the charger cord and GO". Hope this helps.
ok,just figured it out,the plug that goes into the socket vertically is pretty much useless. As soon as you plug it into the handheld device to charge, it shuts off. I took the plug that goes into the socket horizontally and plugged it into the handheld and it began charging. So to use the product, you need to charge the handheld fully and then use the same plug to plug in the actual video camera that is pointed at baby,then you will be set to go. The company should send 2 horizontal plugs.
Are you using the car charger adapter plug? If so the plug may have a blown fuse... I would unscrwew the silver end of plug and check fuse ...its spring loaded so be careful...
If the fuse is good try plugging the unit into your computer with the usb connector to see if it charges .... its a slow charge so may take a few hours to fully charge
It fuse is good and unit takes a usb charge the car plug needs replacing
This would give it chance to actually charge as using it from dead with it plugged in does not always allow some GPS to charge properly.
You neglected to say which brand so its hard to give a 100% answer.
Most GPS should have enough charge withing 4 hours but from dead some older units require anywhere up to 18 hours according to some of the manuals i have laying around
Mine charged itself when if was plugged into the computer. I don't know if that is how you formally charge it, but it worked for me and I see no other way to charge it. Good luck. =)
