My screen starts going white at the bottom and works up the screen untill all white. I turn the moniter off and on again and it works for a few minutes then does it again.
  • 31 Answers
Hello :-) I am guessing that its your screen's problem of what is happening not the computer's. If you want to make sure that its the screens problem look down at your computers tower ( while this white screen problem occurs)  and see if the little orange/yellow light is solid ( that represents the processor ) . If the light is solid that means that it might be the computers problem. but if it isn't solid that means its the screens problem. I would recommend trying a older screen ( you or a friend might own ) and hook that up to your computer/tower if the screen doesn't do what you are describing in your problem that means that its the screen's problem and that you need to buy a new screen.
Posted on Jul 10, 2008
Sharp LC-55LE643U - bottom 3/4 of my LCD TV is shadowed and purplish. How do I fix it?
Try a reset but unfortunately I believe it is a board cratered by the power outage. Try to get things shut down when the power goes
Feb 28, 2017 | Sharp Televison & Video
Hi! and Happy New Year! Hoping you can help me with a problem with my moniter. When it starts up it says Flatron f engine for the model type. Problem: for about 2 weeks now, at start up the moniter...
I suspect your computers power setting are turning off the monitor and not reactivating it (waking up) I would suggest attempting to change your power setting to never turn off monitor and see if that fixes the problem.
Please let me know if that works if not I can go over a few trouble shooting steps with you.
Thanks
Dustin
Jan 03, 2011 | LG Computers & Internet
The moniter blacked out, blue light is saying the moniter is still on, but screen looks like there is no power. When you turn on the moniter, the screen shows up for a few seconds, then blacks out again!...
Unplug power. Unplug VGA cable. Remove back of monitor. (four small Philips headed screws along the bottom rear. Remove screws attaching Monitor to it's base. Carefully, lean the screen away from back of case. Gently unplug 25 pin cable from the screen.
Connect AC power.
Screen should power on Gray to White. Ble light comes on Blue.Flickers then changes to Amber.
Reconnect VGA cable. Monitor should work.
Close up the monitor in reverse order to opening it.
If these steps don't solve your monitor, consider replacing as cost of repairs may shock you.
Sep 09, 2010 | Proview PL926WBi 19" LCD Monitor
I have a samsung Syncmaster 2343 and I can turn it on just fine and my computer recognizes that it's hooked to a moniter but the moniter shows the screen for a few seconds and then it all goes black. It's...
If your up to opening the monitor it would do you well to look. It sounds close to what I experienced.Refer to Problems with Samsung SyncMaster 2053bw for info on opening.
Nov 11, 2009 | Computers & Internet
My moniter screen is all white when I turn it on.
Hi sir,
Its a screen issue ..screen has to replace If it is under warranty go for service centre
Sep 21, 2017 | Xerox XA7-172i 17" LCD Monitor
Monitor Display
see ur moniter is nearly dead...
dont try to on?off it again and again
take it to service center
it happened to me too
its nothing just a small thing which they will change it.
its a bit costy but not more then ur moniter
Jan 07, 2009 | Mag Innovision lt456s 14" Flat Panel LCD...
Laptop screen
Have you tried hooking up an external moniter? If so do you have video on that moniter? If you do have video on the external moniter then you most likely have a bad inverter or a bad lcd panel.I would replace the inverter first because it's not very expensive.If that doesn't work then you can replace the lcd panelAnd if that doesn't work you have problems at the system board level.
Dec 15, 2008 | Compaq Presario M2000 Notebook
My itouch screen keeps going white
push the off button and the O button and hold it in untill it fixes
Jun 29, 2008 | Apple iPod touch
Viewsonic VA712b issuses
Digital-to-Analog Converter - DAC When referring to Audio, DAC is also short for Digital-to-Analog Converter and is the process of converting a digital signal into an audio signal.
Random Access Memory Digital-to-Analog Converter - RAMDAC Pronounced Random Access Memory Digital-to-Analog Converter, RAMDAC is the ... the digital data to an analog signal to be displayed on a computer monitor.
Good Luck, Please dont for get to Vote/Thank you.
Dec 19, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
Computers & Internet Logo
133 people viewed this question
David Payne
David Payne
