Wharfedale LCD3210AF Hi, here's hoping you can help. With reference to the above tv.It started firstly that the blue led would flash and the set wouldnt come on but now the led doesnt even flash.It has been suggested that it may be a fault on the power supply pcb or the inverter board. Any assistance would be great. Thanks in advance. Paul MY WHARFEDALE LCD 3210AF HAS THE BLUE STAND BY LIGHT ON,THE TV WILL NOT TURN ON,TRIED TURNING OFF& UNPLUGGING POWER SUPPLY .TRIED USING CONTROL BUTTONS ON THE SIDE.
  • 3 more comments
  • Anonymous Jul 25, 2008
    same as paul
  • Anonymous Sep 21, 2008
    same here sometimes works then blue light flashes and nothing
  • robwilde Sep 21, 2008
    same happened to me
  • Anonymous Mar 17, 2009
    One day it works fine ,the next no power no blue light or anything.
    Yesterday it worked today nothing
  • alfieapple Mar 17, 2009
    One day it works then the next no blue light no power. leave it a few days then it works again
Dose any 1 now how to fix this problem, i turn on my tv the light is just BLUE, the red light aint showing
Posted on May 31, 2010
I tried to program a universal remote to my Led Proscan tv and now it just flashes different colors. How do I get it to stop?
hi,
I think some how you have gone into service mode on the tv.
you may need to take it into a repair shop so the can re-set it back.
sounds like it to me.
hope this helps
May 21, 2014 | Proscan PLED5529A 55" LED TV 1920x1080,...
Problem: Westinghouse SK-32H240S HDTV has a flashing/blinking blue/red power led
hi when the colours flash again, press the menu button on the remote control and retune the tv hope it helps
regards
shaun
Mar 28, 2014 | Westinghouse SK-32H240S Television
Would like to know the codes for a LG tv, Sony tv, and a TOSHIBA DVD ?
How to Program
Remotes With SET Button
1. Choose and press a device key i.e TV. LED will flash once.
2. Press "SET" Hold until the LED Lights up.
3. Enter the 4-digit Device code (refer code list).
4. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
5. Important - Some brands use other manufacturers to make their devices if the codes available do not work the try the MAGIC search function.
Remotes Without SET Button
2. Press and hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. The LED will flash once as each number is programmed, at the end of the 4th digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
MAGIC SEARCH FUNCTION
1. The magic search function enables you to scroll through the entire code list one by one by pushing the on/off button. Each time you push the on/off button the remote automatically switches to the next code in the list and sends a signal to the device you have chosen.
2. Choose and press a device key i.e TV. LED will flash once.
3. Press and hold the SET button or if no SET button then hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. Enter the 4-digit Device code (refer MAGIC list) i.e TV is 0001.
5. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process.
6. Start scrolling by pushing the ON/OFF button as soon as your TV or Chosen device turns OFF lock the code in by pushing the DEVICE key again.
Mar 27, 2013 | Televison & Video
Hi ive just brought a new samsung led tv with wi fi and iam tying to connect it via my belkin 54g wireless router but the tv can not find the router can u help help help plse......
hi,
i think you had better to see this link : here
because i dont know what OS you are using ?
you don,t describe how you are setting the router with your PC or TV ?
so refer to above link , hope to find ano solve the problem.
good luck
gorbesia
Jun 14, 2011 | Gateway Belkin 54g Wireless DSL/Cable...
Code chunghop RM 139ES for TV Mitsubishi?
The Mitsubishi TV codes for this remote are 011 and 051.
Programming instructions:
1. Switch on the TV
2. Press the "SET" button in the top-left corner of your Chunghop remote until the LED next to the "SET" button illuminates.
3. Enter the first code above 0 1 1 using the numerical buttons on the remote.
The LED next to the "SET" button will go out if you have correctly entered a code.
4. Test the remote with the TV. If it doesn't work - or doesn't operate the TV functions as you would expect - repeat the above steps for the other code.
Please note: Not all universal remotes will work with all TVs.
If the codes above don't work please post back for further assistance. It may be that your remote wont work with your TV or you may need to run the code search feature of the remote to find the correct code.
Hope this helps.
Regards,
BElectric
Dec 30, 2010 | Televison & Video
Hi, I have a 60VS810 60inch LCD projection. Normally when i turn on the TV, theres a blue led that flashes, and when the blue led turns solid, the screen picture appears. My problem now is that the blue...
It could possibly be the power supply unit or the lamp.The power unit is HA01331. cost is about $120.The lamp is UX21514 cost about the same. Hope this is helpful.
Oct 23, 2009 | Hitachi 60VS810 60" Rear Projection...
Wharfedal DVDR24HD160F has died screen display error messge E1000
Hi did you get any resolution to this - just happened to mine?!
Regards
Mar 10, 2009 | Samsung SIR-TS160 DirecTV DTV Receiver
Wharfedale LCD3210AF Television- Digital problems!
Well there is still a problem with the TV. I found that by unplugging the power cable that the digital channels worked. But, when I turned the TV on today the problem had returned, I had to take out the power cable again!
Feb 11, 2008 | Televison & Video
Wharfedale dvdr24hd160 - Segment or split hard drive recordings
Wharfedale dvdr24hd160 I can not get the set up display on TV i have just the sound...!  Would you please help me. Thanks, Moon
Jan 14, 2008 | Wharfedale DVD-M3 DVD Player
Wharfedale DVDRHD400 Set up Issue
Hi I had the same problem. The answer is to use a scart lead on the freeview box and connect it to the input/output scart on the DVD. Then connect a scart lead from the TV out on the DVD to the TV. You then press Video source on the DVD remote until 'scart' is displayed to pick the freeview channels. Hope that helps
Jun 25, 2007 | Wharfedale DVD-M3 DVD Player
Televison & Video Logo
1,115 people viewed this question
Top Televison & Video Experts
Electro Med Services...
