Question about Epson RX595 Photo All-In-One Printer
Paper jamed my printer the paper jamed, it pulls to the right and crumbles and jam's plain paper
  • 2 more comments
  • RayH6 Jul 17, 2008
    Paper goes part way in, then crumples up and pulls to right..when I finally get the paper pulled out, I can see something has blocked the paper and was pulled around it. Can't get inside to fix it
  • nav_takhar Aug 02, 2008
    same thing on mine. just out of the box and paper crumples up
  • grneys803 Aug 28, 2008
    same thing here. mine pulls to the right. while printing, it printed the first page then suddenly started making a loud noise as if something was blocking it and now pulls to the right every time....won't feed properly. Looked down there, and there is a piece of plastic on the right side that is not on the left, however, it appears to be attached and feels as if it is attached to a spring of some sort. No foreign objects have been dropped in there. This thing isn't even a year old. And do you think I can find my receipt??? Of course not. Not to mention, Comp USA, where I bought it, has gone out of business in my area.
  • cozmo213 Sep 28, 2008
    the rollers dont all roll thay are all independint its just a bad design.if you have the time contct epson
    for recall info.i dont think thair is a recall as of yet, or just smash it right in the trash and start looking for a good all in one. this product just sucks!
now it work
i opened it then cleaned it and let the parer got stuck i pulled it with a twizor and it cleared the jam
Posted on Oct 03, 2008
Well, as it turned out, the piece of plastic that I saw crammed into the roller area WAS a foreign object that had apparently fallen inside there. I have no idea what the object was....have never seen it before. And the color of it was the same color as the white plastic paper feeders on the roller inside the unit, so I assumed it was a part of the unit.
I got especially upset with it one night before leaving on a trip when I realized I couldn't print out my boarding pass for my flight. So I removed the 2 screws from the back of the printer so I could get closer to the roller area and had to use some MacGyver tactics to get the stinking thing out of there. It is not "repairman friendly"....there is no easy access to the area where the roller is, and this plastic piece had been wedged down in there pretty tight.
Long story short, I got it out and the printer is working like a charm again. Thanks for your funny comment about shoving it in the garbage, Cozmo. I guess I will hold onto it for now. :-)
Posted on Sep 28, 2008
Plain paper jaming in fuser unit
must be fuser unit, look for these signs :
1- upper roller damaged
2- does not have a "polished " finish
3-lower roller has ripples /waves on it
Apr 08, 2014 | HP LaserJet 1320 Printer
Jamed paperc86 paper is jamed
Epson Stylus InkJet Clear a paper jam in printer
Jan 05, 2012 | Epson Stylus C86 InkJet Printer
Kodak printer esp.3 ...paper jammed
u should only use kodak inkjet papers with size plain paper, coated paper, photo paper, iron-on, transparency film, label media, greeting cards, 20 to 24 lb. plain paper. open back access door of printer by pulling out the latch on back of printer. remove paper-jam from the rollers. u can find manual for ur printer
Jul 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper is being pulled in on the right side and getting crumbled
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Apr 26, 2009 | Canon PIXMA MX310 All-In-One Printer
MF5750 All-In-One Laser Printer DOES NOT PRING indicate paper jam I check and there is no paper jamed in the printer. It starts as it will pull the paper to copy document and then indicates in the display...
It starts as it will pull the paper to copy document and then indicates in the display that the paper is jamed.
Can anyone explain what the problem my be?
Please assist me.
Jan 19, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Paper jammed in printer - need to remove paper tray
1 This works from HP help link in error message:
Turn off the HP All-in-One.
2 Press in the tab on the rear door to release the door. Remove the door by pulling it away from the HP All-in-One. icon_caution_color.gif Caution Trying to clear a paper jam from the front of the HP All-in-One can damage the print mechanism. Always access and clear paper jams through the rear door.
Jul 28, 2008 | HP Photosmart C6180 All-In-One InkJet...
Paper jam
If it crumbles just before the exit, then the problem is with the fuser unit, there are 4-6 claws/teeth/scrapers that are supposed to help guide the paper out, when they wear out the catch the paper and turn them into accordions. Replace the claws, and check the heat rollers.
Jul 22, 2008 | Panasonic DP-150A Copier
A paper jam error message will appear if the printhead is not correctly installed. Try removing and reinstalling the printhead again, but make sure it snaps into place. Try loading a sheet of plain paper and press at the same time copy+cancel; hold them down until the printer feeds the paper. The paper will go through the rollers and come out blank.
Apr 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Different kind of paper jam....
Hello I have an x6170 when I go to print the paper is going in side ways, crumbling the paper. I did not do anything different from before. I tried taking it apart but I do not see any screws or if it is just snap in I would like to see the assembly manual so I can open it...maybe fixing it.
Please HELP
''James B.
Nov 28, 2007 | Lexmark X6170 All-In-One InkJet Printer
Epson RX595 Photo All-In-One Printer Logo
173 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
