SOURCE: Light bulb socket replacement for a really old Air Fare kitchen hood
The chances are that your range hood light socket was fully impacted with grease from cooking. Shut the power off to the range hood or, in many applications, simply unplug the power cord. Remove the socket. Get a spray can of electrical parts cleaner and saturate the socket through the tiny pin holes you may see at back of socket. shake out all of the cleaner fluid. Somehow hang the socket up with bulb base facing up all night. Hook it up. That might solve the problem.
It worked for me very recently on a 20 year old range hood.
DON'T USE ANYTHING OTHER THAN AN OFFICIAL ELECTRICAL PARTS CLCEANER. Most hardware stores, etc., have it.
SOURCE: Kitchen Hood Broan Nutone RM5200 Hood won't pull air.
There is definetly somthing blocking the air from escaping, either the duct is blocked or the installer did not remove the metal plate which opens the fan up for it to be able to evacuate.
SOURCE: Kitchen hood
Yes you can , usually they got hole on top too , just make sure when its done that the air is going out and it will be fine . I
SOURCE: Motor surges
http://downloads.mendingshed.com/KitchenAid_Service_Manual.pdf
See the section on repairs to speed control / motor.
SOURCE: kitchenaid hood wont allow reset of "C"
Hi Folks, does pressing the "+" button resolve the issue?
