Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Icemaker in ge profile refrigerator
ICE IS NOT HARVESTING. IT APPEARS THE WATER IS NOT GETTING IN TO THE TRAY
  • madamcello Jul 20, 2008
    not making ice
  • michellesala Oct 13, 2008
    our ice maker makes a knocking sound, and water is leaking behind the ice tray, and freezing on the back of the freezer, I assume that the water is leaking before it reaches the tray because our ice is also weird shapes and clumped together in the tray.
Check the back - ours was leaking in the back so water pressure did not reach the minimum for ice making
Posted on Aug 12, 2008
    Sergeant:
    Champion:
  • 330 Answers
Pull it out and push it back at the right position, see if it is working.
Posted on Jul 21, 2008
Ge profile side by side model pye22kskbss is not making ice.
Is the icemaker getting water into tray? If not>refill valve is ng
Is there ice in the tray? If so, heater element is ng and that needs replacement.
Or just get a new icemaker on the cheap at site. eBayeBay
Sep 09, 2017 | GE Refrigerators
No ice makeing
If the icemaker is getting water into the ice tray, then the easiest most cost effective thing to do is simply replace the ice making unit. You can get them for about 45 bucks new on ebay. If no water is getting into the ice tray then either the water flow to refrigerator is not present or the the water solenoid is not working. Check that out also.
Nov 26, 2013 | GE GSS22JET
GE REfrigerator PSS26SGRBSS Is there an adjustment to allow less water into the ice maker. The cube tray is overfilling.
Yes their is a adjustment wheel on the side of the icemaker as pictured here in the red circle
Aug 26, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
How can I stop my icemaker from making a block of ice? At the front of the ice bin, a block of ice is forming as though wateer is drippping into the bin.
Open the freezer and remove the ice bucket. You should now see the tray were the ice cubes freeze, check to see if it is fractured or leaking and the position of the water outlet pipe to the ice tray. If the water pipe is firing water out of the tray just readjust it.
hope this helps you.
Jun 23, 2010 | GE Profile PSW26P Stainless Steel Side by...
Home from vacation--no ice.
Check the fill area of the ice maker for an ice blockage.
- make sure the tube on the back of the Ref. is connected to the white rectangled block of the fill tube.
- check to make sure the water filter in the bottom of the unit was not kicked and has popped out or is not seated / locked in place.
- Check to see if water is actually getting to the unit.. from the 1/4 inch supply line.
If your icemaker is the common one there here is a way to test it:
(I noted GE Profile but not an exact model number)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
Last question... does water in door work?
Thanks for using FixYa.
Kelly
Apr 03, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
GE Fridge icemaker is not working - Help!!
I installed a new icemaker (cost approx $100) and its making ice. Very easy to install yourself (remove 4 screws holding part below icemaker, then unplug icemaker, and unscrew the 2 screws holding it in place.). Good luck-
Jan 28, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Ice maker water line doesnt shut off
If the icemaker did not stop right in the spot where the water fills the tray, without completing the cycle, you have an icemaker problem, but that is highly unlikely. More likely is that the water fill valve (the part right where the water line hooks onto the refrigerator) will have to be replaced.
Jul 07, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile icemaker will make ice but won't dump into the tray
GE uses an electronic icemaker that is not field serviceable. if the Icemaker is getting water then something in the icemaker has failed and the complete icemaker must be replaced. the part number is wr60x10093 I believe and can be purchased online and many different places or thru local appliance parts supply house. thanks peyton
Feb 18, 2009 | GE GSS25LGM Side by Side Refrigerator
Ice maker not working
So your not getting water from the dispenser either??? Yes the water filter can be the source of your problem. Let me know if the water is coming from the dispenser.
Nov 19, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
have you felt water in the ice maker or ice cubes thats the only way you know for sure.. just cause water in doors works doesnt mean icemaker getting water.. got different valves giving water to different places Is your freezer temp. right.. has to be right temp for icemaker to work.. check back wall in freezer make sure no frost buildup and if fan working
Sep 02, 2007 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
108 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
