JVC AV-27320 27" TV Logo
Posted on Jan 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to find JVC AV27320 headphone jack? I've plugged into the avs(red & white) in the front panel as well as the extra ones in the back. Altho - I CAN hear the sound thru the headphones, The external sound is still heard as well. How can I mute that and still hear the sound thru the headphones? thanks
  • ginie492 Jan 06, 2011
    Update: I found a way to use the headphones!
    While there are "headphone connection insturctions" in this TV's manuel.
    The instructions on pg 18 are for AV20D303 only & NOT "AV27320" (which is what I wanted).
    But after fiddling around and no Google answers, I found that
    when I plugged the headphones into the back panel's AVs, & then
    "Mute" on the "TV's" remote (as opposed to the cable remote) that it works as I needed.
Level 3:
  • JVC Master 6,688 Answers
  • Posted on Jan 06, 2011
Cindy  Wells
JVC Master
Level 3:
Answers
6688
Questions
0
Helped
3532869
Points
21745
This model doesn't have a headphone jack. The only JVC TV in the series that does is the model AV-20D202. For the JVC AV-2732, use the RCA audio out jacks with an RCA to 3.5 mm adapter to connect to the headphones. The front audio jacks are audio in (for the audio from a video camera for example).
When you use any external speakers or headphones through the audio out jacks, make sure to turn off the TV speakers. Press Menu and navigate down to TV Speakers (up/down arrows). Then use the right/left arrows to select Off and then Exit the menu. Make sure you scroll the TV volume before doing this. Note: if your headphones do not have a volume control they are a bad choice for this type of audio output.
You can find the manual for the TV here: http://books.jvc.com/booklist.asp?Model=AV-27230 .
I wish that I had better news for you.
I have a Vizio model E320-B1. Does it have a head phone jack? I’ve looked all around and can’t find one.
Modern TV sets, including the Vizio models, don't have any headphone jacks. The only audio outputs are the red and white RCA jacks, and the special optical port (used for the sound bar). I recommend buying a cable set that has the red and white RCA plugs on one end and a headphone jack on the other end. You can ask Best Buy or any audio store for it.
After you attach the plugs and can hear the audio through the headphone, you must enter the "Menu" and disconnect the on-board speakers if you wish to listen only on the headphone. Read the user manual to do this.
2answers
How to find audio fix on my LG flat screen tv to finish connecting my wireless head phones
Well Hi Maria ! Let's get you fixed up.
I want to help you with your question, but I need more information. Maria, with my wireless headphones, I have 2 types:
a)Has 2 "RCA Type" connector plugs, you can identify them simply as one is red(My memory trick is R is 'RED & R for right side, and a white one, for the left side) do you see these plug type connectors that attach to the broadcasting unit that sends the signals to your wireless headphones, so they can go without wires?
b) Or...do you have a broadcasting unit that has 2 different types of plugs, 1 is still a red "RCA type", and the other is a different type, a "BLACK" Plug type ?(It is called a 3.5mm Plug)
If you have "type a)" 1 x Red RCA &
1 x White RCA, then all you need to do is to look at your HDTV manual, an find where the "AV OUT" plugs are, make sure it is the OUT, (Caution: It won't work if there is "NO" audio from some source hooked up to at least one the HDTV's in sources, it could be AV, or HDMI, whatever you chose to use.
Carefully move the HDTV, so you can safely get behind it and locate the AV OUT (Female type) plugs at the back, remember "R" is for RED PLUG & always "RIGHT" Side, and "WHITE" PLUG is for the "LEFT" Side. Hopefully the cords are long enough to get out from behind the HDTV, andto a place where their signal can reach the headphones. If not, I get very inexpensive RCA cables, & other things at "My local DOLLAR STORE, for about $3.00" And you should be set. Remember, Start your headphones with reset, and slowly search until your audio matched the video on the HDTV.
If you have the "type b)" you have 2 options. If you plug just the "RED RCA plug into the back of the HDTV, IMPORTANT** You will ONLY get (Remember "R" red for Right hand side) you only get Right Had Sound (REALLY, who wants that, with all the nice stuff you bought ??)
Soooo... That "BLACK 3.5mm Plug means you have "2" choices
a) Unlikely Choice- If there is a 3.5mm audio OUT Female Plug receiver that accepts the Black plug, then THAT's IT. The Black plug. is like most microphones, headphones, etc, IT HAS BOTH THE LEFT & THE RIGHT SIDE SOUND SIGNALS> Again, if it's not long enough, , go buy an inexpensive extension plug (Factory Direct Store sells a 25 foot extension cable ***FOR ONLY $6.99 ****-
- I love that place !! )
b) if like most HDTVs you have the same 2 RCA type AV out Female Plugs, you will need to buy what is called a
"3.5mm (Female)to RED & White RCA PLUG SPLITTER" -
and guess where you get them reaaly cheap ??
See above !!.
When you have your RCA to 3.5mm Splitter Cable (Hey it's late & I don't remember the right name, I think this is the one !!), plug The "R" for RED to the "Right" side AV RCA plug for AV OUT, & the "White" plug" to the "Left Side" AV out plug,& the 3.5mm Black Plug (female) will plug into the Cordless Headphones Broadcaster's (Male) 3.5mm Black Plug, move the Broadcaster out front so your Headphones can pick up the signal
LAST !!!
2 things
#1- Always try to be sure that you could draw an imaginary "LINE OF SIGHT" between the Broadcaster Unit, and where you will be wearing the headphones for the best quality of signal (You want to enjoy it now, right !)
#2- BE VERY VERY CAREFU, PATIENT, when you move the HDTV back or foorward. They are EXPENSIVE !! AND !!! IMPORTANT, !! They are a LOT HEAVIER THAN THEY LOOK< AND COULD REALLY HURT YOU,if they fall on you, or you will not feel so smart if after all this, your nice, expensive HDTV, is BROKEN, OK?
PLEASE BE CAREFUL FOLKS !!!
1helpful
2answers
How do I hook up my iphone 5s to my Onkyo TX-8511
You can use a DS-A5 iPod docking station or a RCA Y-adaptor found at retailers such as APPLE, BEST BUY, RADIO SHACK, AMAZON, etc.: http://www.amazon.com/APPLE-COMPOSITE-AV-cable-ZML/dp/B004EWEX9Y/ref=sr_1_1?ie=UTF8&qid=1331155139&sr=8-1You can use a DS-A5 iPod docking station or a RCA Y-adaptor found at retailers such as APPLE, BEST BUY, RADIO SHACK, AMAZON, etc.: http://www.amazon.com/APPLE-COMPOSITE-AV-cable-ZML/dp/B004EWEX9Y/ref=sr_1_1?ie=UTF8&qid=1331155139&sr=8-1 . Connect from the headphone port of the iPhone and use the red & white RCA audio cables to connect into the RCA audio input terminals of your TX-8511.
How do i connect my jvc camcorder to my lg recorder
These instructions should be very similar to hooking up to your lg recorder Hope this helps
Instructions
    • 1 Plug the white and red audio cables into the left and right Audio OUT ports on the back panel of the DVD player. The ports should be color-coded white and red as well, but if not, connecticon1.png the white plug to the left audio and the red to the right.
    • 2 Connect the yellow plug to the Videoicon1.png OUT port on the DVD player.
    • 3
    • Plug the other ends of the three cables into the matching composite AV IN jacks on the back of the JVC LCD TVicon1.png.
    • 4 Turn on the DVD player and the JVC set, then press and release the "Input" button repeatedly on the TV remote control until the DVD screen appears on the LCD panel.
Read more: http://www.ehow.com/how_6647268_hook-player-jvc-lcd-tv.html#ixzz303ZGkASL
Headphone jack on 32d104
Hello
There is no headphone socket to this model either on its front panel or with its back. OK.
2answers
My television does not have an audio output so i connected the rs 110 to my cable box and it works fine...however i also have a dvd player connected to the tv video input and for some reason i cannot hear...
Are you using AV cables from your DVD player to your TV? (the yellow,red and white ones) If you are the is a way to do this, since you have no other outputs at all is you will have to make one. With the purchase of a couple adapters and an additional av (audio only cord which is red and white) you can do this. The first adapter you need looks like this. http://www.globalgrabber.com/product/4507930-5mm-stereo-plug-2-rca-plugs-jacks/ You will remove the red and white AV cords from the back of your TV that run from the DVD player and insert them in the adapter to their respective colors on the adapter. Then you need to purchase a double female AV adapter that looks like this .http://www.google.com/products/catalog?q=double+female+av+adaptor&hl=en&prmd=ivns&biw=1600&bih=799&bav=on.2,or.&um=1&ie=UTF-8&cid=14119505288159192113&sa=X&ei=S-V1TZPDJIKglAexv-ybCA&ved=0CI0BEPMCMAU# Then you need to put that adapter on the one you just installed so you can add the new AV cord onto it and run the new cord to the TV.That completes the sound of the DVD's back to your TV. Now for your headphones. You will need a double female 3.5mm jack input to put between your headphones and the remaining jack on the adapter. It looks like this http://www.buy.com/prod/3-5mm-female-to-female-stereo-audio-cable-coupler/q/sellerid/23962916/loc/101/216778563.html Play a movie and enjoy. This is the only way to do what you want with the current setup you have. These adapters and wires can all be purchased for less than $10 off of E-bay. If your not using AV cords then the only other way to do it with the current setup you have is --
You can purchase a reasonably priced receiver and hook your DVD, cable, and TV to it as well as your headphones. With no outputs on your TV there will be no way to hear your DVD's through your headphones. You can also purchase a very reasonably priced shelf speaker stereo. Many made in recent years have some audio inputs and of course inputs for your headphones.
Where do the red white & yellow connecters go as its not clear in the manual
Then you have to look on the television set to see where they go. There will be red white & yellow holes on the back or side of your television set. However some television sets are now being made without them. In that case there will be what looks like a headphone jack where it says av input or input #. Then you have to buy a conversion cable where one side is red white & yellow and the other side is a 3.5 mm minijack cable.
I have a JVC AV-27D501 TV, I'm trying to connect a DVD player to the TV but not able to get the Video or Audio. My DVD player has Video Out (Yellow) and Audio out (white & red). Connected the AV cables...
I'm assuming the cable was plugged correctly - the colors matched. VIDEO 3 is for the front connectors so it should have worked . Since it hasn't then one of the three parts in this setup (tv, player, cable) is defective. To find out which you must do some simple tests:
1. replace the cable and try again.
2. take your player and connect it to a surely functional tv - if it doesn't work in there then it's defective.
3. get another player that is surely functional and connect it to your tv - if it doesn't work then the AV switching IC from your tv (soldered on the mainboard) is defective and it will have to be replaced. Call a repairman, there is nothing more you can do.
How do I play my iPod touch through my 55" Samsumg led 3d series 8 tv?
You need a cable, either a headphone jack to red/white (audio), or a special headphone jack with yellow (video) and red/white (audio). They look like this: Apple Component AV Cable
No audio when connecting Aspire 5315-2326 to TV.
Use a cable out of the headphone jack with an adapter to the red and white (left and right) audio jacks of your TV.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
