Question about GE WSM2480DWW Large Capacity Washer & Gas Dryer Combo in White
Wsm2480dww laundry center(combo)
Won't spin until lid is raised and lowered during the spin cycle. Pumps ok.
  • 1 more comment
  • bd_123us Jul 11, 2008
    Thank you for the reply. The lid switch is tight and has a very distinct click. I have heard of a timer issue makes a washer act like this. In the case I've heard of, the washer needs to see a pause before activating the spin cycle, and by opening the lid, you force a pause on the washer. I belive that's what I'm looking at here, it is very consistent and simply opening and closing the lid remedies it. If it was a flaky lid switch, it would work some of the time, and sometimes not. Just want to make sure I'm not barking up the wrong tree, and replace a timer for nothing.
    Every heard of the above senario?
    Thank you much for your efforts!
  • bd_123us Jul 13, 2008
    Thanks for your time!
  • Toby Norton
    Toby Norton May 11, 2010
    Sounds like you may be having a lid switch problem. Have you tightened the screws on both the hinges on the lid and the screws on the lid switch on the right hand side in the top as you open the lid?
  • 246 Answers
The washer drains the water durring the neutral drain. (water drains out but the basket does not spin). Then the timer will hit a "pause" (basically removes the power momentraily so the gear case can change gears). So if you are not getting the pause durring the cycle, lifting the lid does the exact same thing. I would agree with you from your last comments that you do have a timer issue. They can be ordered on line from the manufacture or more readily a local appliance parts store.
Posted on Jul 11, 2008
  • Toby Norton
    Toby Norton Jul 23, 2008
    Your most welcome. I'm glad we were able to get that take care of. Thank you for the great reating too.
  • Toby Norton
    Toby Norton Aug 10, 2008
    Just adding a comment on this one to get it off my work que. Please dis-regard.
Frigidaire FFLE2022MW washer dryer combo beeps twice and stops during all washing cycles after it fills with water and lid is still locked. Does anyone know how to correct this? Thanks
Thank you for your inquiry, Criss Ard!
From my understanding you are having issues with your Frigidaire laundry center not starting a cycle. You stated that the washer fills with water then locks. It sounds like your timer is not advancing and that could be due to a faulty timer or wiring harness. You may want to perform a reset on your laundry center and you can do that by disconnecting the power cord for roughly ten minutes. If this troubleshooting step does not help resolve your issue you may want to consult with a professional technician for proper repairs. I hope this information is helpful. -Matt
Feb 20, 2015 | Frigidaire White Electric Washer And Dryer...
My model GLET1041AS2 Frigidaire Laundry Center fills/agitates, but does not pump or spin. The timer would make a slight buzzing/timer sound when it hits the spin cycle, but nothing else.
The circuit board has a Cycle generator and sequencer that accepts commands when you manually do a setting. When the sequence enters the spin phase a block occurs and discontinues further action. It is not the timer, but the command center on the circuit board. Because the board has many functions, it is like a set of Christmas Tree lights in series, and when one bulb fails, so goes the set. You will no doubt need a new command board for that model.
Mar 12, 2014 | Frigidaire Genuine Washer Timer 134049600
Washer won't drain or enter spin cycle
SHOULD BE THE LID SWITCH... THERE IS TWO SWITCHS INSIDE, ONE THAT STOP THE MACHINE, AND ONE TO LOCK THE DOOR. YOU SHOULD SEE THERE IS TWO PAIRS OF WIRES THAT CONECT WITH THE LID SWITCH, ONE PAIR IN THE FRONT, AND ANOTHER PAIR IN THE RIGHT SIDE, THAT RIGHT SIDE IS THE PROBLEM, INSIDE THE LID SWITCH MUST BE BROKEN. TRY TO MOVE THE PLATED LOCKING PIN IN THE DIRECTION THAT LOCKS THE DOOR, AND IT MIGHT DRAIN AND SPIN. IF THAT THE PROBLEM, YOU SHOULD GET A NEW SWITCH (MODEL 134101800), AND YOURE DONE.
GOOD LUCK
MARIO
May 07, 2013 | GE Spacemaker Washer and Dryer Electric...
Kenmore 27 in. laundry center won't spin out
The lid may not be mechanically closing the switch even though the switch was replaced
Apr 11, 2013 | Washing Machines
Whirlpool Thin Twin randomly skips agitation during the cycle.
Did you ever figure this out? Mine agitates but instead doesn't start spinning and draining unless I open the lid. It then "clicks" and starts but it is strange that I have to do this to get it to spin.
Dec 20, 2012 | Whirlpool LTE5243DQ 24" Thin Twin Electric...
Frigidaire washer won't drain or spin
Hello - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. Supposing that it does not, I would suggest contacting a professional to move forward accurately. The unit could possibly have a faulty pump, timer, or door lid (if it is a laundry center).
Oct 11, 2012 | Frigidaire Washing Machines
Kenmore laundry center model 92702 burning smell during spin and water doesnt drain
mine does this regular easy job if your desent at diy are you missing socks or wires from bra's as it probably the pump blocked take the pipe of the pump and see if there is any thing stuck in the pump remove it as long as pump not damaged should be fine probably get some loose change as well lol
Aug 17, 2012 | Kenmore 92702
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
Water comes back in and stands after cycle is run
I'm not sure what washer you have but a lot of washers have an additional spin cycle. If you left the lid open, then it would only fill with water then sit until the lid is closed. Try making sure the lid is closed next time you empty it and see if the water is in there the next morning. I hope this helps. Good luck!
May 25, 2009 | Washing Machines
Humming noise during spin cycle
Strangely enough, the electronics in the motor drive circuits are quite hardy. Suggest if motor does agitate but not spin, check the motor brushes and see what length and condition they are in.Have had to replace brushes on many occasion.If you have a motor that has a capacitor then check the cap. It could be defective.
Feb 08, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
GE WSM2480DWW Large Capacity Washer & Gas Dryer Combo in White Logo
95 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
