Question about Canon imageCLASS MF8180C All-In-One Laser Printer
Laser cavity were is the laser cavity in this machine, and how do i access it
Printing half the page only
Posted on Sep 25, 2008
How can i repair phaser without frontcover
One way would be to take the front cover from the OKI B2540 machine (they are identical). If that isn't possible you would need to make a jig to hold in the interlock microswitch, a restraint to keep the cartridge from moving, and a light sheild to prevent light from entering the cartridge cavity.
Jun 26, 2014 | Xerox Phaser 3100MFP/S Laser Printer
My IBM Infoprint 1552 is leaving gray spikes at
Check your toner cartridge (most print quality problems are toner cartridge problems) if that is not the problem (and it probably is) then check the fuser for toner buildup matching the defect you have. There is also a small possibility of the laser being deflected and causing this (unlikely) but clean the small mirror above the toner cartridge (it is small in height and as long as the machine is wide and up in a cavity)
Feb 08, 2010 | IBM Infoprint 1552 Laser Printer
Toshiba e-studio 3511 has printing issued on one
These copiers have serious toner dust issues. Light copies are usually caused by dust in the optics (the mirrors) and on the laser glass.
Take off the main copy glass and gently clean all the mirrors and scan bulb underneath it - be careful.
If you remove the drum unit and look inside the cavity you took it out of you will probably find a huge toner mess. the laser glass is situated in this cavity and needs to be cleaned - just clean whatever you can see...
Feb 01, 2010 | Toshiba E-Studio 3511 Color Copier
The paper was stoppped into the machine, now it's free but it doesen't work and call me on display: 200 paper into the machine
Sounds like one of the sensor flags has been dislodged. Look inside the cavity for a little black sensor arm and make sure it is moving freely. It should have a coil spring that moves it back when you flip it. Also check the back door for a flag.
Dec 30, 2009 | Lexmark E342n Laser Printer
Lexmark laser printer leaving a white streak 2-3
take a q-tip and clean the scanner window. this is located in a 3/16' opening on the roof of the printer cavity it will be about 8inchs long. pull the toner cartridge and feel with your fingers on the roof of the cavity this will be located above the transfer roller slightly towards the front of the printer. white lines like this mean the laser is being blocked usually by a bit of toner or other dirt of some kind
Nov 30, 2009 | Lexmark E232 Laser Printer
Check Display
usually it's a paper jam. remove cassette, and look inside...there may be a piece of paper stuck inside. Also remove, and re-seat all paper in the cassette. Also, remove toner cartridge, and check inside the machine cavity for jams..
re-post if problem remains.
Jul 15, 2009 | Ricoh FAX2050L Plain Paper Laser
Panasonic Panafax UF-880 Plain Paper Laser Fax - Info code 011
Remove the paper cassette completely, look in the cavity for a broken magnet or crumpled up paper. The machine thinks that there is no paper tray installed
May 08, 2009 | Panasonic Panafax UF-880 Plain Paper Laser...
Paper jam
Look into the cavity at the back of the fax machine with a flashlight. Very difficult to remove a jam from this area. Repost if you want to try.
Nov 28, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Toner cartridge
Look for a piece of the old cartridge down in the cavity.
May 11, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
Door Hinge Replacement
remove spring that holds the rubber bellows to front of machine
peel back and fish out plate from inside cavity of machine
then refit plare and reverse process
Mar 10, 2008 | Hotpoint Aquarius WD63 Front Load...
Canon imageCLASS  MF8180C All-In-One Laser Printer Logo
52 people viewed this question
old marine
old marine
