Question about Kitchen Appliances - Others
Zorjirushi breadmaker parts
Model BBCC-S15A dough bucket assembly replacement. Where is the most closest service center form Beaverton Oregon?
    Champion:
  • 204 Answers
Check http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Posted on Jan 13, 2009
The spindles that you attach the paddles to is leaking a black lubricant or something like that. I was making a simple sweet dough. By the way, I NEVER bake in the bread maker. I only use it to knead the...
Your machine has a lubricating grease that is under the small gasket or washer at the bottom of the pan under each paddle. After a lot of use the little gasket can fail and the grease can get get past the gasket and into your bread. The best thing to do is either replace your pan with what is called a "pan assembly which will include everything but the paddles. If you decide to do that be sure to keep your paddles. The other choice of course is to replace your machine which might not be a bad idea if your machine has been used a lot because you would have a new pan assembly but older parts may begin to fail such as the drive belt. Bread machines aren't all that expensive anymore so you may want to go ahead and replace especially since you just use your machine for making dough.
Feb 08, 2011 | Zojirushi BBCC-X20 Home Bakery Supreme...
Crust is thick and hard, paddles tear large chunk from bottom of loaf when removed from pan.
unfortunately all bread machines leave the hole in the bottom where the paddle is. some machines leave a bigger hole than others, with the exception of the cuisinart cbk-200 which allows you to remove the dough, then remove the paddle, then reshape and replace the dough....One thing you can try to have a softer, lighter crust is to replace the water in your recipe with the same amount of milk. If the hole in the big hole in the loaf really bothers you I suppose you could remove the dough exactly at the end of the final knead, remove the paddle and replace the dough in the pan...I've never done it but I've certainly considered it! best wishes and happy breadmaking...
Nov 08, 2010 | Zojirushi BBCC-X20 Home Bakery Supreme...
Zojirushi bread machine
Not sure if this is relevant to your issue, but I just completely disassembled my machine to fix a problem in which one of the paddles stopped turning under load. It would turn with no dough, but slipped uselessly when making bread. Diagnosis: if you can turn the rotor by hand (remove the baking pan and try to turn each one) it's slipping. You should not be able to turn them.
I just fixed this problem. The belts in my machine are fine, in fact so massive I can't imagine them breaking. But access? Yikes.
So, forget the screws on the bottom. They just hold on the feet. Remove all the screws around the top of the baking chamber, the two that hold the control panel on, and the remaining screws under it. There are about 12 screws. Remove the 6 at the bottom of the baking chamber, but not the 2 that hold down the element. Remove the metal sides of the baking chamber (it's one piece). All this is to get access to the screws that really hold the works to the base. They're around the perimeter of the metal chassis on which the motor and element are mounted. Remove them (get help or arrange something to keep the control panel from exerting too much pull on the wires to the element. You could unplug the control unit but I didn't need to.)
Once you lift the motor assembly exposing the belts underneath, you'll see what's loose. Each nut holds down a metal plate beneath the rotor. If it gets loose, the rotor can move more or less freely and won't turn. It looks like they applied an inadequate dab of glue to hold those in place. I should have put in a star washer to keep the nut from loosening again. Next time.
Jun 24, 2010 | Zojirushi BBCC-X20 Home Bakery Supreme...
Where do I get a Remington 16" EL8 chainsaw repaired for what seems to be a Gear Train Failure. I need a repair outlet near Beaverton, Oregon, 97007
Remington Service Center Locater
http://www.remingtonpowertools.com/service_locator.cgi
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
I think your model is 107625. A complete "SPROCKET DRIVE GEAR BEARING KIT 747" part number "122511-01" is listed at $16.99
Are you aware Remington is no longer in production and most replacement parts are exhausted? Before driving to any repair facility please contact them. If you undertake the repair your self please call 1 (800) 475-5660 (have saw within arm reach). Inspect your saw and verify my model number matches your saw.
Please do not punish my rating because you are unhappy with RemingtonPower. I provided a very helpful answer, perhaps not the one you wanted to hear. Sorry
Lou
Nov 30, 2009 | Remington 16" Electric Chain Saw
I have black spots in my bread dough
I get black smeary streaks in my dough too. I just bought a new machine because this happened in my old one. But, on about my 5th loaf in this new machine, I have little black spots and small smears. This is how my other machine started out and then the smears were thorughout the whole loaf after a month more.
Help, what is this!
Jan 07, 2009 | Zojirushi BBCC-X20 Home Bakery Supreme...
Dough does not rise
Make sure you are following the recipe very carefully. You have to have the proper type of four, and yeast. Make sure you are using flour that is called bread flour. This type of flour has higher glutent than cake flour. Cake flour would make a heavier bread.
As for the yeast, there is a special yeast for bread machines. Regular yeast would be too slow acting for most bread machines.
Jerry G.
Nov 08, 2008 | Zojirushi BBCC-V20 Home Bakery Traditional...
My breadmaker model BBCC-V20 completes the entire cycle, however the dough does not rise at all! I've tried with brand new ingredients eggs bread flour and yeast. Tried 3 times - no success at all.
Hi ravimalini,
Something is stopping the yeast from acting (fermentation creates to CO2 bubbles that cause the bread to rise). Was the new yeast you used all from the same batch? (sometimes they have bad days at the yeast factory, too). Can you watch when it runs through the cycle, and check for conditions _before_ the dough is supposed to rise? If it heats up much too quickly/soon, the heat can kill the yeast before it get to do it's job.
You might be able to get more product-specific assistance from Zojirushi.
I'd go to Zojirushi's Support page at (TinyURL'd for brevity)
http://tinyurl.com/3jmx4g
There's a Service & Support link at the top of the page - locations of service centers and the like.
You can also call Zojirushi Customer Service Department - -
800-733-6270, M-F, 8:00 a.m. to 5:00 p.m. PST.
Also here's a TinyURL for the manual download page, just so you have it.
http://tinyurl.com/z39gu
If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Nov 07, 2008 | Zojirushi BBCC-X20 Home Bakery Supreme...
Zojirushi BBCC-X20 rubber gasket breakdown
Hi D Daniel,
I'd start by getting a new part. Gaskets can be made from a variety of materials - and different types of rubber, or silicon, will have different characteristics. The manufacturer should be able to provide this information to a concerned consumer.
If these don't pan-out (no pun intended, I think), the next place I'd start hunting is eBay.
Jon
Mar 17, 2008 | Zojirushi BBCC-X20 Home Bakery Supreme...
Oregon scientific phone
Oregon Scientific is located in Beaverton, OR. Give 'em a call!
Jan 07, 2007 | Oregon Scientific WW338 Cordless Phone
Kitchen Appliances - Others Logo
127 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
