Question about Amana NTW5400TQ Top Load Washer
Amana NTW5245TQ1 Topload washer....water draining out from basket...
Okay, to start with, I have to lift the lid to the washer, then shut it again to get the spin cycle started. This has been going on for a few months. Today the cycle stopped completely. After waiting for over an hour and doing the lifting the lid thing again nothing happened. I finally got it to spin on spin cycle, only the water was coming out of the bottom of the washing machine, not draining during a spin cycle. I finally got it to spin out the water, and drain out the tube, but water is still slowly leaking out the bottom of the washer. I already turned off the cold and hot water. We NEED the use of this washer, but are unsure of what to do to get it to NOT leak again. I don't care if I have to be home, listen for the spin cycle, lift the lid open for a few seconds and then shut it again to get it to go, so long as I don't end up with a tiny laundry room with an inch or more of water in it again and all my laundry and available towels soaked from cleaning it up.
Help?!
tsjwheeler@verizon.net
Stacy from Clearwater, FL
  • 246 Answers
Unfortuneately, I think you have two seperate problems. Fortuneately, this is easy to verify. As far as the not spinning, it is generally caused by loose hinge screws on the lid. There is a arm that sticks off the back of the hinge to press on your lid switch. If the screws are loose, the arm generally wont be able to press the switch. Just tightening ther screws on the right and left hand sides of the lid corrects this. You can verify this has corrected the problem by setting the washer to spin without adding any water. As far as the leaking. Well, there are multiple sources for this, but the most common is the water pump. To verify this, unplug your unit and pull it out from the wall. Tilt the top of the washer back towards the wall until it rests by itself at about a 45 degree angle. You are looking for a white peice of plastic towards the bottom front of the machine. There will be 2 black hoses going into it. run your finger across the front side of it feeling for bumps. You may have had something get lodged in there and poke a hole. If you can not find any moisture on the pump (yes it can leak from the hoses of back of the pump also)look for any signs of water having leaked. (you generally get water spots just like in your dishwasher when you don't use a rinse agent). If you still can't see anything, tilt the unit back forward and add 1 cup of water to the machine. Tilt it back again and see if it's leaking. Continue adding water until you can get your leak then trace the water back. However, if you do in fact have a bad pump, they are availible from local appliance parts suppliers (in the phone book) or on-line from the maunufacture. Any troubles or other problems? Drop me a line back. Otherwise,
Posted on Jul 11, 2008
My amana washer barely spins but makes a jackhammer sound in spin cycle
The "jackhammer" sound is that the load (and hence, the "basket" it's in) is out of balance, causing the basket to spin in an eliptical motion.
Some washer (like mine) will momentarily shut off when it senses this, and restart when the basket slows down enough to make the out of balance condition go away, unless it starts in again, then it'll shut down again and restart.
If this is what is happening, the washer keeps shutting off and restarting, making it appear that the basket is spinning slowly, as it never gets up to full speed.
Try redistributing the load when this happens.
Also, the usually is a spring arm with a rubber "snubber" on the end that presses against the top of the basket, to help dampen an out of balance condition.
The spring over time weakens, and the dampening action is lessened.
Sep 08, 2013 | Amana Washing Machines
Why wont my amana washer start at all?
My washer will notwork it will not let the lid lock are fill with water
Jan 20, 2013 | Amana NTW4501XQ Top Load Washer
I have an Amana Top Load Washer Model Number ntw4800vq1 The washer shakes violently during the Spin Cylce. It will walk across the floor. I took the console off and removed the outer shell. I checked...
Hi
for the question of water comming in the spin cycle, yes its normal we call it a spray rinse. For the shaking check your leveling and also make sure that the back leveling feet when lifting back of washer up and down that the foot mechanism is functining.
Hope this helps
Mar 27, 2011 | Amana Washing Machines
How do you diagnose a bad washer pump vs a cloged line?
Amana ALW480DAW seems to be not completely draining. When I start a new load water in basket becomes dingy and smells. Washer smells when it has not been used for a couple of days. We have checked the outflow and inflow drain tubes found no problems. It seems to spin and agitate normally, it drains to a point and leaves water in it, not visible in the basket. When we blow on the outflow tube when it is done draining there is still water present, we can hear it bubble.
Feb 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Washer will not drain
By lifting the lid you are performing the job of the timer. In your unit you have a neutral drain transmission and the timer is programmed to end the washing cycle by stopping the motor. When it starts back up, it reverses and the transmission is in the neutral state. The water drains and after about 3-4 minutes, the timer is suppose to disconnect power to the motor thus stopping the transmission inducing the transmission to shift into spin. When it starts back up, it spins. So when you lift the lid, you pause the motor and the transmission shifts. Close it and it spins. Replace the timer and you will be fine. If I can help further.....
Waiting to hear from you,
Eric Campion
Feb 13, 2009 | Washing Machines
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Washer will not start. Water will come in. Will not spin or agitate.
new washer? whirpool is manufacturer lift lid do you hear clicking sound left corner of lid if not ck screws in hinge that corner possible lid switch is not being struck properly when lid is shut also may need to adj hinge by pushing contact lever back a little ..older unit? possible same thing different location also ck wiring to motor
May 28, 2008 | Amana Washing Machines
Amana NTW5400TQ Top Load Washer Logo
375 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
