Your PC is infected ,which is running for XP 7and you should remove the virus.
Please download f-secure bootable disk and clean at the time booting.
How will you confirm?
Follow the steep. Press win key +R >type gpedit .msc and soon an windows will open.
Press win key +R>ms config and soon an windows will open.
Press win key + R REGEDIT an windows will open soon.
Go to tools option >folder option >view>check on show hidden file
Check off hide protected operating system file
Check off hide extension known type file.
BUT still there are no hidden file in drive C:
Think your computer has affected by serious virus.
start>program>accessories>system tools >system restore >set earlier date. If you have the strong
virus you can not do that.
You will take more infomation click here
Hope it will help you.
Good by
((computer administrator for sharing))
You will have to be the computer administrator to change any values on any hard drive
click start control panel user accounts you should see a box with the administrator and the guest account if you have made one click on the administrator this may vary depending on which operating system you have
click start click to open on my computer you should see your hard drive usually C: right click select properties there will be an array of options select the security tab option then advanced make sure you have full control in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control. also you might
click start control panel file and folder option view place a tick in show hidden files and folders and drives
hope this helps
