Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
Power shuts off
I install a vcr tape it loads and runs about 10-15 sec, shuts down ..Whken I turn power back on the cassett ejects
  • 6 more comments
  • melmdwv Jul 15, 2008
    thank you for your comments
  • REB1149 Dec 29, 2008
    I have the same problem. I hope someone has an idea what to do as to fix this . CD works fine , no error messages. Just ejects tape after about 7 seconds. par for the course that this would happen about a year after purchase, when the warrenty runs out. Cant look to funai for any support either. Any help appreciated
    Phillips Magnavox MWR20V6 combo
  • Anonymous Dec 29, 2008
    I have the same problem as discribed. But the dvd player does the same. Unit stays on for about 7 to 10 seconds then shuts down.
    I payed 125.00 for this unit and it lasted about a year and 2 months.
    I guess its save to say that phillips / magnavox SUCKS!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • Smitty1971 Jan 14, 2009
    Power shuts off after 2 seconds
  • dlynn927 Mar 03, 2009
    insert tape, runs about 5-10 sec if lucky. shuts off. when turned back on tape ejects. a R is next on the screen. I believe this is the symbol for auto rewind. The player thinks it is at end of tape, so rewinds and shuts off. Any suggustions other than to clean heads, already tried. Did not help.
  • jwolters62 Mar 05, 2009
    I have the very same problem with my model ZV450MW8. This unit is just over a year old (out of warranty wouldn't you know) and this is very disappointing. It cost about $200. I would certainly appreciate it if someone could tell me how to solve this.
  • Anonymous Mar 24, 2009
    I have a vhs.dvd recorder. I was recording a movie to dvd when an E2 error came up on the display. Now the unit will do nothing and turns itself off after 15 sec. I called service center they told me to turn it off for 30 mins. Nothing happened
  • dananddi50 Mar 30, 2009
    Have had this vcr dvd recorder a year. When you hit play or record it stays on 5 seconds and shuts off. If you hit the power button to turn it back on it rejects the tape. Same problem as some others. Hope it can be fixed.
  • 3 Answers
Hi, I have a solution you can try.
I had exaclty the same problem. When I tried to play a tape it would load (However, I recall I had to push hard to get the tape to be accepted, which is part of the problem) but would shut off after about 12 seconds, then when I powered back up the tape would eject. Finally I took the unit completely apart and attempted to use it with the covers off. Lo and behold, I found I could play a DVD on the unit without the unit powering off, but only if the room lights were on! If I tried to play a tape it would shut down the unit. So that led me to diagnosing the infrared loading and reel sensor circuits.
Background on that is there is an infrared LED that shines up through a plastic light pipe lens. The light from that LED (you can't see it) should shine on two photodiodes that are on either side of the tap mechanism, plus down through a gear with holes in it on to the reel sensor. When there is no tape inserted the two photodiodes will be illuminated and have about 0.2 volts across them. When a tape is installed the light will be blocked and the voltage goes up to above 2.5 volts across the diodes. You have to check this with the room lights dim as the diodes will respond to that light. When you block the light on either side of the plastic light pipe with your finger (with the unit disassembled) you should see the load motor engage, and it will back off when you take your finder away. For some reason in my unit the light from the LED was insufficient to turn on one of the diodes, and also to pulse the reel sensor when the gear turned. That could be due to component aging, or even if the light pipe started to cloud due to age, I don't know. However I was able to get the thing working...
In short I got the unit working by adding 3 resistors.
To do this you'll have to remove all the covers and remove the main PCB from the bottom chassis, unplug the power supply from the PCB, and the two ribbons going to the DVD unit. But you won't have to take off the VCR assembly, which is a pain. You just need some basic soldering skills, and remember where all those screws go...
First, I adjusted the voltage across the right-hand side load sensor diode to get the diode to switch on and off. I recall that I added 1meg across the diode. So the voltage then went from about 0.5v up to 2.8v from light to dark condition.
Second, I increased the current to the IR LED. I added a 330ohm resistor across the feeder to the LED. I recall that was R511 and was originally 220ohms. That was not quite sufficient to get the reel sensor working reliably. I didn't want to stress the LED by putting too much more current through it so looked for another idea.
Third I added 56k across the reel sensor diode to bring the voltage across it down so it would switch on and off as the reel sensor gear turned.
I now have a tape playing continuously in the unit and it seems ok for the time being. Hope that might work for you too.
Craig Townsend
Posted on May 26, 2009
The problem is the reel sensor or associated cricuitry. I am an electronic tech and could not figure out what was wrong. I replaced sensor and sensor emitter with no change. It was not the micro. I finally gave up and told the customer I could not repair unit. No schematic or parts available from Philips/Magnavox
Posted on Jul 15, 2008
Ok solution 2 was great except he went all around the problem but this is the fix for the problem! ! ! Go out to the Dollar store and buy a universial remote with a clear LED showing at the frount end. Break open the remote and desoder the LED diode note the arrow (if on the curcit board) should be pointing to the larger peace of metal in the plastic. Now the hard part 3 screws remove cover, aprox 14 remove back, unclip the frount. Be cairfull of the flat cable remove if you are ok with that. Remove 4 screws from DVD unit remove cables 2 recomended. Remove a bunch of screws from Circurit board. No need to remove Cassett ***. from Ck board. Remove Ck board. Now remove one screw from plastic light guide near center of cassett deck. See down in the hole it came from there is an LED (infra Red) like the one you took out of the remote. Find it on the other side and desoder it(get soder wick or special desoder tool) If you can get hemostats great or tweesers pull the old and install the new one. Make sure you do it like the arrow points printed on the bottom of the Ck board.
Ed Pearson pearsonhouse3@comcast.net
Posted on Mar 11, 2010
This may sound very funny, but. I held the unit about 2 feet off the ground, then dropped it to the floor so it would land flat on the bottom. It now works just fine.....??????
I don't no what to say except it was toast anyway so what the hell thought i would see what happened. Now it works fine.
Go figure.......
Posted on Dec 29, 2008
I have a philips/Magnavox VRA431T23 and has simliar problems
power turns on for 7 sec and shuts off and with tape does the same thing and ejects the tape and shuts off with an error message #3. I took off the cover and notice there is a sensor
in the middle pointing straight up. there is a clear plastic
reflector that is above it has been broken.try to replace it if possible.
Hope This Helps....
Posted on Feb 17, 2010
The VCR accepts the tape and starts to play; then stops and shuts off; when you turn the power back on the tape ejects
You have a transport problem, the mechanism the plays, FF or rewinds is not working.
Someone is going to have to open and look at the unit---as simple as a belt off or broken to the idler (rubber or geared) that doe the actual work, finding a shop that will work on a VCR unit is getting hard as most of the current techs have never seen this type of unit.
What I used to do when I opened one was have a old cassette with the tape removed! but the reels inside of it still there--tape off both sides of the cassette where it opens so the sensors on either side do not try to stop the unit from allowing this.
This way with the unit open and the dummy cassette in you can see thru its top to see if the reels are moving or not and not have the tape get in the way.
Dec 06, 2012 | Magnavox DV220MW9 DVD Player VCR
My HV-MX1U is definitely over 14 years old and was one of the best electronic devices I ever bought. Nothing was ever replaced or fixed in it so, obviously whatever parts like belts or etc need to be...
Probably both. There is a mode or position switch that tells the processor what position the deck is in. If that has failed that could be a cause also 14 years for belts is a very long time. You may find a kit on fleabay but switch wise, I doubt it.
Mar 24, 2017 | Aiwa HV-MX1 VHS VCR
My vcr plays or records for 12 sec and shuts off then when i cut on the power it ejects the tape....also when i power the vcr with no tape a wheel is spinning in the back right corner whats wrong?
This can be due to many faults and need a full check up but I can fill up with few tips.
1. If the cassette loads and the take up spool does not turn then the machine will shut and rewind.
2. If the take up spool rotates but then it shuts down then the reel sensor at the bottom of the forward wheel can be faulty- there are opto devices or proximity sensors/magnetic type.
3. If the drum does not rotate it will shut down as well a fault in the SERVO section.
4. Defective HALL IC can shut the switching and so the servo will shut down the processor.
5. Fault in the power section to deliver the correct voltage to the circuits/loading servo to take up.
6. Finally if the loading is not to the MODE switch point or failure of mode can make the loading to trip as it will not complete the load to the desired point.
Sep 27, 2011 | Cameras
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
Tape loaded normally but now won't eject. The unit just powers off after a few seconds.
Unplug the power from the combo unit and give it 30 seconds, now plug back in, sometimes this will eject the tape, if not! take the top off the machine and check to see if the tape is spewed in the mechanical section and around the video head, if yes! get a pair of scissors and cut the tape carefully to avoid damaging the video head and remove all tape deb-ri, now power up and eject the main cassette. But! if you find the cassette has loaded in place and the tape is still in the vhs cassette, this would indicate a loading problem with the main carriage, broken belt, bad idler assembly and possibly sensor issues.
Feb 06, 2011 | Sony SLV-D350P DVD Player/VCR
When I put in a VHS, the power goes off and when I turn it back on, it ejects the tape.
It has a tape transport problem. It shuts off to avoid any damage. It probably is not loading the cassette all the way in.
Apr 21, 2010 | Sylvania DV220SL8 DVD Player/VCR
VCR tape loads and runs about 5-10 sec; then ejects
you need to clean the vcr with a cleaner that you can buy at a store. If that doesnt work then you need to take the 4 or 5 skrews out that hold the top on and look at the motor and gears move while you put a tape in and you should spot the problem pretty quick. It'll be with the round metal wheel that turns the tape.
Jan 02, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Vcr eject manfunction.
Sound like you have to open your VCR and help it left up to eject. I had the same problem.
Mar 14, 2008 | Philips Magnavox Learning Universal Remote
CST.IN Light
Put a tape in and eject it. It will then work. Just had this problem. CST IN means the VCR thinks it has a tape in. Trust me... Very fixable.
Jan 19, 2008 | Hitachi DV-PF2U DVD Player/VCR
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
1,381 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
