Roper Washing machine model # RAX7245JQO, Serial # CK4411217 TYPE 107 isleaking water during the spin cycle. I am thinking that ahose may have a leak, and want to check it. How do I remove the cabintet, and leave ir intact enough to run a cycle to observe for leaks?
  • 1 more comment
  • mad kate Jul 12, 2008
    Thanks for getting back to me. The cabinet is off and machine is going through the cycle. I only see a green, tan and grey wire. I'll try connecting the tan and grey since they look like they are already spliced and joined. I'll let you know how I make out!'Thanks again!
    IT was the pump! Looked like stress cracks in the plastic . Hopefully it will be as easy to install as it was to diagnose! Thanks again! YYYYYEEEEEEEEEHHHHHHHHHAAAAAAAAA!
    Lumpy 826 Great Success!!!!Thank YOU!!!
  • 246 Answers
Great question, here is your answer. You have to open the console (usually 2 screws in the front or back where the console meets the top of the washer) Pull the bottom of the console towards you and swing it up. Remove the 2 brass colored clips underneath by pushing down with a large screwdriver at the point where it goes into the top of the machine and press down while simultaniously pushing towards the rear. Now there will be a connector with a white, green and gray wires in it. Unplug this connector. Now tilt the top of the washer towards you (the top, front and sides all come off as one assembly) The washer will fill with water, but you will not be able to drain it unless you install a wire between the white and gray wires on the machine side. ( I would do this with the unit un-plugged and make sure you have a good connection by spinning it before you add any water. Likely the leak will be coming from the pump (white peice of plastic in the lower front with 2 black hoses going to it). If so, pry the two clips off the pump with a screw driver. Put the pump over a bowl to catch any remaining water. Squeeze the clamps on the hoses with a pair of pliers to remove them. A replacement part is availible at a local appliance part store or on line from the manufacture's web site.
Posted on Jul 11, 2008
  • Toby Norton
    Toby Norton Jul 12, 2008
    Excellent. Glad to hear you found the problem. If you need anything else, drop us a line.
Whirlpool type 107
Sounds like the clutch may be slipping. Does it go into a high speed spin?
Aug 18, 2013 | Washing Machines
Roper washing machine type 107 won't fill up but 3
check the pressure switch, and the water level sensor
Update ma about your progress
Jul 23, 2009 | Washing Machines
Roper RAX7245JQO topoad washer will not spin.
That could very well be a broken belt. I Have a pictoral guide you might want to look at.Don't you agree a picture is worth a gazillion lame wurds?
Click HERE.
Jul 06, 2009 | Washing Machines
The agitate (wash cycle) does not engage-neither spin cycle
is it a top load kenmore washer?if so the motor coupler is broken,they brake if overloaded and just get old,let me know more-mike
Apr 16, 2009 | Washing Machines
Roper RAX7244EQ1 Vibrates during spin cycle
Dear customer
Please perform the following checks
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Please rate this,Thank u
Nov 21, 2008 | Roper RAS8445KQ Top Load Washer
Agitater spins around, water won't drain.
The model number is located under the lid.
Nov 17, 2008 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
367 people viewed this question
Top Washing Machines Experts
