Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Compressor noise and shutoff
Hello, I've previously posted this problem but I am still working on it. Here is my progress to date. The starting cap is good (15.5uf). The current draw from the compressor is 9.6A before shutoff. The relay does get warm for the few seconds it is on. I plan on ordering a new start relay today but I was hoping for a warm fuzzy from the experts before doing so.The fridge is 7 years old and out of warranty. Relay P/N 218721119. Thanks
  • Kenmore Master
  • 5,568 Answers
No expert here, just another victim.
Have you experienced anything like power disturbances shortly before this problem came up?
We lost a compressor some years ago due to a 'low-line' condition (~20-25 VAC) while we were gone from home and tha is not enough to start the compressor but is was enough to fry it.
It never ran again.
Can you see that the compressor shudders when trying to turn on?
This would indicate that it is starting up but if you see no movment (the suspension whould allow some) then it isn't even trying and could be seized.
The current seems about right, placing the power at ~1100 watts but all modern compressors will have thermally protected motors that will limit current in case of such a seizure to prevent fire.
The dropping out after startup kind of suggests that the current draw is monitored and limited so that if it fails to start, it can shut down again.
If used as in most normal motors, that the start capacitor supplies a phase-shift to a serarate winding that is shut off after spinup, instead of a centrifugal switch, they are just using a relay.
The effect would be the same.
Posted on Jul 10, 2008
The dryer ran for two complete cycles. the third cycle the dryer would not start. When the timer was switched it made a humming noise.
That sounds pretty typical of a motor that has tight bearing and shutting off due to excessive heat being created at the motor because of the tight bearings on the motor. What will usually happen whena motor is very tight is that it will run a few minutes (or cycles) and get too hot and shutoff until it cools down and will start then shutoff agian once too hot.Along with it not starting because of the friction of the tight bearing the motor will make a humming noise and may or may not start.
GENE
Oct 17, 2011 | Roper Dryers
THE COMPRESSOR IS IN A KENMORE ELITE TOP FREEZER/BOTTOM REF. MANF.8/2000. STARTED KNOCKING 1+YEAR'S AGO. Not all the time just when it kick's off(power's down). I've checked the level of...
Hello.
I believe that noise is coming from the compressor because one on the springs inside of the compressor shell that the motor mounts to is weak so when ever the compressor powers down the motor knocks against the casing of the compressor. While i know the noise is very unnerving the only way to fix it is to replace the compressor and that will cost somewhere around a $1000.00 and since it works fine as far as cooling the food ok perhaps that expense isn't warranted. I have heard that nosie before and know its loud but i too know it causes no harm to the compressor
GENE
Aug 31, 2011 | Refrigerators
Hello. I have this fridge-freezer, but unfortunately I can't remember when it was bought. I guess it must be between 7 and 12 years ago! It's worked fine but a couple of days ago it started making...
By your description you may have a compressor problem. The noise is makes if a buzzing noise when it struggle to start (locked up). The clicking noise would be the relay clicking out on overload to the compressor.
If your correct on the date, you will be better off replacing the unit then looking into the repair, a normal compressor change out can run over 500.00. Your best bet is to cut your losses and replace the unit before spending any more money on it.
Good Luck
Aug 28, 2011 | Refrigerators
The keyboard seems to be locked on numbers...i've unlocked the numlk by pushing fn+f11 but the keyboard still only is using numbers for instance when i push asd, i get 456
Try system restore. Go to START ICON>ACCESSORIES>SYSTEM TOOLS>SYSTEM RESTORE>CHOOSE PREVIOUS DATE THAT YOUR KEYBOARD WORKS FINE BEFORE.
If still the same, I suggest you repair the operating system using the Operating system Installer CD/DVD. Then it will back to normal.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 13, 2011 | Computers & Internet
I have a 1992 silverado 1500 with 2 problems.1st,the a/c does not work,specifically no power to the compressor,hook direct to the battery and it works,but still no a/c.2nd,when I start or shutoff the...
you have a mode door actuator failing inside but that will not interupt a/c compressor clutch.Start bypassing pressure switches and check relays for that problem...good luck
Jun 28, 2009 | 1992 Chevrolet K1500
Grinding noise about 30 seconds after starting
Sounds like starter isn't disengaging, get that checked pronto, you could be damaging the flywheel (very expensive). Could be any appliance also; a/c compressor, idler pully, alternator, etc. Don't wait.
Jun 10, 2009 | 2007 Dodge Charger SRT8 Sedan
Truck started yesterday now it wont
Check for moisture under distributer cap. If there is, leave the cap off for 1/2 hour or an hour to evaporate, reinstall cap. Please post your results.
Feb 08, 2009 | 1998 Volkswagen Jetta
Amana refridge
The humming noise is the compressor cycling on the overload protector. By the posted date I would think that you already replaced the refrigerator.
Dec 06, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Amana Model # ARS2464B Refrigerator and freezer does not work right
The problem is the compressor.  Techumseh compressors are notorious for this problem.  Pretty soon it won't start at all.  The compressor has a 5 yr warranty from date of purchase.  I replace these all the time.  The good thing is they are replacing them with Embraco compressors which are much better quality.  Would appreciate a solved rating for expert advice.
Oct 19, 2007 | Amana ARS2464B Side by Side Refrigerator
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
91 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
