Question about Compaq Computers & Internet
My computer is having trouble charging - Compaq Computers & Internet
  • 31 Answers
Okay :-)  Id be happy to help but I need to know what kind of computer it is. Like Your category is desktop but you can't charge a desktop ( at least I think not) but if you can in some way. Your battery might be defective or it might have been charged to many times and needs to be replaced. ( if you want more info tell me specifically about your computer) :-}
Posted on Jul 10, 2008
2004 expedition want run on its own alternator is charging battery is good but all warning lights are on and dies when i take charge off
How did you test battery and charging system?
Your charging system is computer controlled. Check for applicable trouble codes. To check codes yourself, at the least you need an obd2 code reader that will check manufacturer specific codes as well as po codes.
Take wire connector loose from generator . The two wires on the left should show battery voltage, do they? What is the voltage spec? This is with key off and no charger hooked up.
The two wires on the right are to and from the computer, To check those, at least, you need a digital multimeter that has a duty cycle or frequency setting, with engine running, should activity on both wires. You have a battery temp sensor that could cause problems.
Jun 11, 2017 | 2004 Ford Expedition
My fitbit charge gets stuck on the finishing up step.
I'm having trouble setting up my tracker using ... - Fitbit Help
help.fitbit.com/.../en.../I-m-having-troubles-setting-up-my-tracker
FitbitJul 31, 2015 - I'm having trouble setting up my tracker using my computer ... If you followed the steps in How do I set up my Fitbit tracker on a computer? and couldn't complete ... Your tracker is charged. ... Or, if you'd prefer to get in touch:.
Oct 31, 2015 | Cars & Trucks
Not charging
Do be sure that you're using the USB AC adapter that came with the tablet from ASUS. I seem to be having the same trouble. I'll let you know if I find out more.
Dec 17, 2013 | ASUS Computer Vivo Tab Smart Me400c -...
Battery exhausted message no battery charged
The manual says:
Confirm all connections.
Off is selected for Charge by computer in the setup menu.
When charging by connecting the camera to a computer, battery charging stops when the camera is turned off.
When charging by connecting the camera to a computer, battery charging stops if the computer is suspended (sleeping), and the camera may turn off.
Depending upon computer specifications, settings, and status, it may be impossible to charge the battery inserted into the camera via computer connection.
So be sure you are charging the correct way. Best way to do is to remove the battery and put it on the charger for a couple of hours. If you have the battery out, you can check all connections of battery and in the camera.
In trouble shooting, more than a full page is dedicated only to the battery and the method of charging. The manual is still online, but should also on the CD you got with the camera.
Nov 16, 2013 | Nikon Coolpix 3200 Digital Camera
How do i fix a p1794
A P1794 trouble code for your vehicle is not a shift solenoid problem. It has to do with a battery circuit problem. Either you have a faulty battery or it's not fully charged or you have an open wire which is why your vehicles computer has detected no voltage. I would check battery, charging system and if both good there then you have an open wire to the PCM. Hope I was able to help...
May 12, 2013 | 1996 Kia Sephia
Acer 2920Z - The battery won't charge!
Thats Right the problem is with the battery which is not getting properly charged. Show it to a hardware engineer to resolve this problem
Apr 24, 2010 | Acer Aspire One PC Notebook
Compaq presario c552us will not charge battery
THE COMPUTER DOESN'T EXACTLY CHARGE THE BATTERY. MAYBE THE ADAPTER FOR THE C502US ISN'T COMPATIBLE WITH UR COMPUTER, OR THE ADAPTER CONNECTION AT THE COMPUTER/ MOTHERBOARD IS FAULTY.
Jan 09, 2010 | Compaq Presario C552US Notebook PC
Toshiba m300 charging trouble, stops charging when notebook is started.
sounds like the battery is showing that there is not much reserve..you may need to do a couple of deep discharge cycles..
Oct 13, 2008 | Computers & Internet
Computers & Internet Logo
13 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
