Repair manual I just got a reel to reel tape deck on ebay. I'm having some trouble with it. Even when I put it on the slowest speed setting, the voice is coming out too fast. Also, the take up reel wheels seem to be slipping. That wheel hardly turns at all while the tape is on it. But when I take the tape off, it runs fine. Any help would be greatly appreciated
It is an AKAI X-1800SD reel to reel 8 track tape recorder/player.
Posted on Jul 12, 2008
  • 1,512 Answers
Hi marykohles
What model do you have there?
regards
robotek
AKAI REEL TO REAL MODEL 1700 OPERATOR'S MANUAL
Here you are Andrew. That is a blast from the past!!
Service Manual and Owner's Manual!
Akai 1700 Manual Stereo Tape Recorder HiFi Engine
Jan 23, 2016 | Computers & Internet
Is there an internal speed adjustment to fix tape speed selector that has no affect on tape speed. This is on Sony TC-440 reel to reel.
There is a cam with solidified grease on a lot of Sony Mechanisms. The deck need to be cleaned of the grease they used that solidifies and then a better grease such as Lubriplate 105 should be applied.
The Idlers need to be reconditioned as well. The Sony units can be labor intensive due to this required work but I do fix them when people want them done. I am in the Chicago area as Skywave Tape Deck Repair
Jun 08, 2015 | Audio Players & Recorders
Sony Tape Deck TC-630 D runs but the mechanisms that pulls the tape up to the heads doesn't move up when the control is turned to Forward. It moves just slightly, then stops like it's mechanically...
Commonly to all these older units and I have seen a lot of them, there are mechanical linkages that are not covered inn the owners manual as they were moving in the short term. Now after a lot of years the grease has turned to a glue or will be very thick. The mechanical links must be taken apart and regreased- I have done many but the problem is that it can take a lot of time to do this. Get a tube of Lubriplate from a Hardware store and go in and see where things do not move and that will be where the cleaning and grease will once put in make the deck like new.
Aug 19, 2013 | Audio Players & Recorders
Akai reel to reel speed adjustment
I give you a link from where the service manual can be downloaded.
On the page 17 of this manual You can find how to adjust tape speed.
Thanks, gylacz
Nov 07, 2012 | Audio Players & Recorders
Teac A 6010 reel to reel while recording my voice it echos my voice
You may be listening off tape and there is a lag of time between the record head and the play head which is what you may be concerned with. This is normal for any three head deck be it cassette or open reel.
Slowing the speed will lengthen the time of the delay and speeding it up will shorten it.
Oct 31, 2012 | Audio Players & Recorders
AKAI X-1810D LOW HUM WHEN RECORDING REELS
I am not an expert in the repair of Akai units- most of the time I refuse them, however just to put you on the right path, the hum is coming from a power supply issue in the record audio section or may be in the bias section. You may need to put new Electrolytic caps in the power supply to resolve this. You can also scope the supplies on this deck to find the cause. I commonly work on Teac, Pioneer, Otari, Studer, Sony and better made decks. Some brands are real trouble and are more costly to repair due to poor construction.
I have been doing repairs for 40 years so far.
Sep 05, 2012 | Audio Players & Recorders
A 303 cassette deck - the belt has been changed. The feed spool and capstan turn fine. The take up spool does not turn and play stops after 5 sec. Take up spool is fine in fast forward. Help !
This is a case of a failing reel motor. What happens i sthe brushes become aged and wear down and the motor has what they call a dead spot on the Commutator. The motor will work fine at high speeds as the inertia is working for it but when you use a slow speed as in play mode the motor hits the dead spot and stops. You will need a new reel motor in the most likely case- I can service the deck if you want at Skywave Tape Deck Repair Chicago area. I will most likely put a new motor into the deck.
Oct 04, 2010 | Teac V377 Single Dual Cassette Deck
I have a teac 3340 reel to reel recorder and believe it can only function in 2 speeds 7 1/2 ips and 15 ips. I have many reel to reel recordings that are 3 3/4 ips. Is there an adapter or gadget I can use...
In short, no. if you look closely you will see the Teac 3340 has a much larger/thicker capstan shaft than other Teac reel decks. This feature allows the faster tape speeds...7 1/2 and 15 ips. In order to slow down the Teac 3340 you would have to change the flywheel to one from another deck that was made to run at 3 3/4 and 7 1/2. Which is possible but some work..plus you would have to find a slower speed flywheel from another Teac deck. Also to maintain performance, the bias and Eq positions for the slower speeds would have to be readjusted from 7 1/2 and 15.
May 11, 2010 | Audio Players & Recorders
BLANK REELS AND A MANUAL FOR THE RCA REEL MEDIA CENTER?
Reels for RCA Reel Media Center and Spirit of St. Louis are 7.5 and specaility reels that will work ONLY on these (2) machines. I bought RCA Reel Media Center several years ago and it came with only (1) tape! I stocked up when I finally located a vendor that had them for sale.
I have (50) of the reels new in the box if you would like to buy them I am willing to part with some of them.
Just Email me - UpDownTheAmFmDial@live.com
Jan 27, 2009 | Novelty Manufacturing Polyconcept USA...
TEAC X1000R Stereo Tape Desk (reel to reel)
usually its a capstan drive belt. $10-18 for the belt & 30mins repair time - you'll be up &brunnin b4 you know it bigmattt@gmail.com
Nov 24, 2007 | Audio Players & Recorders
290 people viewed this question
 Grubhead
Grubhead
