Question about Nintendo DS Console
DS Lite I swapped out the bottom board with screen intact and it still shuts down immediately. The top lcd never does anything. Do you know what the problem is?
  • 61 Answers
Bad top lcd
Posted on Jul 18, 2008
Ds lite comes on the top screen flashes then it switches off
It could also be a bad top screen due to a bad ribbon cable. If your hinge is cracked it could cause damage to the ribbon cable that passes through it, this shorts out the top screen and will shut the DS down
Jul 08, 2010 | Nintendo DS Lite Console
Nintendo ds in fully charged but when power button is turned on screen flashes on then immediately off.
needs new LCD
I bet its the bottom screen that flashes?
if it is then it needs a new top LCD
see www.dsdoctor.co.uk
Jun 29, 2010 | Nintendo DS Lite Console
I replaced the top lcd screen on my son's Nitendo DS lite and now when I turn it on the bottom screen flashes and shuts off. What is wrong with it?
Hello!
The bottom screen flashes because something is still wrong with the upper lcd
Make sure you didnt put a rip in the upper lcd. The smallest rip will mess it up.
Also, make sure the cable is in completely.. If its off the slightest cm , it'll cause the lower lcd to blink which causes the DSlite to not work
Dec 29, 2009 | Nintendo DS Lite Console
My ds will not turn on
It sounds like one of you're screens has broken. What you have discribed is generally what happens one either the top or bottom LCD screen has broken.
If it is the top screen the bottom screen will flash for 1/2 a second and the DS turns off.
If it is the bottom screen the DS should still turn on but with no reaction from the screens. (the Ds will shut down immediatley after turning on)
Sep 17, 2009 | Nintendo DS Lite Console
Potentially dead Nintendo DS lite LCD screen. (bottom)
Hey, I can help you.
Yes, the Bottom LCD is dead. You will have to exchange it.
Below I have two links you should follow through. One to purchase a bottom LCD for a very cheap price and the other will show you how to replace the bottom LCD.
REMEMBER.. To place a plastic pad under the bottom lcd so it doesn't ground out the board. Forgetting to do this could potentially blow a fuse and you will have to replace those!!
1.) http://www.amazon.com/dp/B000RWXCE2?tag=wit08-20&camp=14573&creative=327641&linkCode=as1&creativeASIN=B000RWXCE2&adid=0JJ799NSS5VV0XTY8DYK&
2.) http://www.instructables.com/id/S3ZZJPKFA0CVIFO/
May 27, 2009 | Nintendo DS Lite
Bottom screen black
Your bottom lcd is busted. It'll have to be replaced.
Look online for Nintendo DS bottom lcd replacements.. Fairly cheap
May 17, 2009 | Nintendo DS Lite
NINTENDO DS LITE POWERS ON AND THEN IMMEDIATELY OFF
The system powers on, then performs a system check. The DS is finding some sort of error More than likely the top screen was damaged. I've been told that the screen that flickers is usually the good screen. The bad one doesn't flicker because it's damaged. You can replace the top screen yorself (if you're fairly handy), or you can pay a professional to do it. You can get new screens from Dealextreme.com for around 10US dollars, with free shipping. You can also find videos about how to change out the top screen on youtube. Hope this helps
Dec 23, 2008 | Nintendo DS Lite Console
Turns on and lights up but no images on top screen
The DS top screen has two components, which are the LCD display, and the backlight. If the LCD display has gone bad but the backlight still works and the connecter is seated properly, the DS will still power on and the lower screen will be normal, and the top screen will light, but it won’t display anything.
You didn’t mention if your DS is the original DS or the DS Lite. Replacement top screens for the DS Lite are cheap on eBay, but installing the screen is a bit complex. The screen for the original DS is a different part and they are more expensive and hard to find.
I’ve never worked on an original DS, so I can only tell you about installing the top screen on a DS Lite.
First, the DS Lite has to be just about completely disassembled. You have to completely remove the top and bottom cases, pull out the microphone and wi-fi cables, and release the connecter for the top screen, which is located on the main board in the lower case. You’ll need the tri-wing screwdriver. You can leave the bottom screen/touch screen assembly attached to the main board, but be careful not to pull or tear the flex cables. Check YouTube for videos on disassembling the DS Lite.
Here’s the deal breaker for most people: The speakers are soldered to the flex cable of the top screen. I’ve never seen a replacement sold with speakers. You’ll have to unsolder your speaker wires from the old screen cable and reconnect them to the new one. If you can’t solder, you could take the screens to a local tv/electronics repair shop and pay to have it done. I got this information for you from http://wiinewz.com/forums/nds-general-discussion/72805-ds-top-screen-white-blank.html this appears to be a common problem I hope this helps
Dec 01, 2008 | Nintendo DS Lite Console
Nintendo DS Lite problem
I THINK UR DS IS SCREWED UP BUT THE SHELL DIDNT DO ANYTHING
Jul 28, 2008 | Nintendo DS Lite Console
Nintendo ds lite dark top LCD screen after replacement.
Press down on on the plastic (not the and press down on the buttons) until it remains lit
Jan 23, 2008 | Nintendo DS Lite Console
Nintendo DS Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
